Old Jan 24, 2016, 08:23 AM
scole is offline
Find More Posts by scole
Joined Feb 2014
durafly p40n prop balancing
how to balance the prop?
scole is offline Find More Posts by scole
Old Jan 24, 2016, 09:19 AM
gnats82 is offline
Find More Posts by gnats82
Coy, peruser of worlds
gnats82's Avatar
Augusta, KS USA
Joined Dec 2007
Best to direct all questions about this plane here http://www.rcgroups.com/forums/showthread.php?t=2488619, no need to start a new thread on each question.
gnats82 is offline Find More Posts by gnats82
Old Jan 24, 2016, 11:56 AM
aymodeler is offline
Find More Posts by aymodeler
aymodeler's Avatar
United States, CT, Hartland
Joined Jul 2011
I am not familiar with this particular plane, but I can't imagine that there would be anything unique about balancing the prop for it.
Pick up a prop balancer at your LHS (or Amazon). Here are a couple of options:
http://www.amazon.com/ZJchao-Precisi.../dp/B00CLX8JRA
http://www.amazon.com/Du-Bro-499-Tru.../dp/B0006N72Y8
Just remove the prop, put on the balancer. One blade will dip, that's the heavy one. Sand lightly near the tip of the heavy blade to thin the blade slightly. It does not take much to make a difference.
aymodeler is offline Find More Posts by aymodeler
Old Jan 24, 2016, 12:46 PM
gnats82 is offline
gnats82's Avatar
Augusta, KS USA
Joined Dec 2007
Post #3 - "I am not familiar with this particular plane, but I can't imagine that there would be anything unique about balancing the prop for it."
There is something different - three blades - and it is likely well covered in the dedicated thread for the airplane as to assembly and balancing, which will include the spinner cone. Go to the "attachments in thread" tool to locate posts by relevant images and you can open the post from there at the bottom. If there are none, just ask for help with a new post there and someone will lead you through what it takes.
Scole, is this your first warbird..? Important question..
Old Jan 24, 2016, 05:43 PM
aymodeler's Avatar
Joined Jul 2011
Ahh ... It seems like you could still follow standard balancing process though, just on the assembled unit (assuming that the shaft on your balancer is smaller in diameter than the center bolt that runs through your spinner).
As you say though, the thread specific to this model should be the place to learn any unique tips or tricks ...
Old Jan 24, 2016, 05:55 PM
gnats82 is offline
gnats82's Avatar
Augusta, KS USA
Joined Dec 2007
I don't have it for easy reference, even have one large electric plane flying with a three blade and I've forgotten the method....at the moment..!
Here's one video showing a method, there are several more videos..:
3 Bladed Prop Balancing for RC Aircraft (3 min 55 sec)
Discussion durafly p40n prop scole Electric Warbirds 1 Jan 23, 2016 03:21 PM
Mini-HowTo Balancing props without a prop balancer Jacktstone Electric Plane Talk 29 Jan 22, 2016 06:04 AM
Discussion Durafly P40N receiver Rhys Nicholls Electric Warbirds 0 Oct 17, 2015 08:57 AM
Sold NEW Dubro Prop Balancer and Orion Balance rod for self tightening props avril Aircraft - Electric - Multirotor (FS/W) 2 May 26, 2015 06:33 PM
Discussion 1100mm p40n durafly Ddogxxx HobbyKing 3 Mar 28, 2015 11:59 AM
