Old Nov 28, 2015, 03:02 PM
FlyingNiko is offline
Find More Posts by FlyingNiko
FlyingNiko's Avatar
Joined Oct 2011
Build Log
Depron/ balsa PW1211 plank
My PW51-plank flies okay, but still I noticed some room for improvement looking at flight-envelope in less than perfect circumstances.
Chord -> 30cm (actually 26cm - 28cm would be perfect)
Wingspan -> 100cm
Airfoil -> PW1211
Materials: Depron 6mm, Balsa 1mm, carbon-boom 8mm, glue UHU POR.
FlyingNiko is offline Find More Posts by FlyingNiko
Old Nov 28, 2015, 03:05 PM
FlyingNiko's Avatar
Joined Oct 2011
With hindsight... 30cm wingchord is a little too much and causes some challenge getting CG enough to the front.
I started with selecting this beautiful airfoil:
Old Nov 28, 2015, 03:08 PM
FlyingNiko's Avatar
Joined Oct 2011
Then I cut out Depron wingsections, and I mean a lot of them. This took me approx. 30 minutes, so it is doable. I left space for elevons:
Old Nov 28, 2015, 03:09 PM
FlyingNiko's Avatar
Joined Oct 2011
... I was really optimistic about getting CG right/ my light-weight-building skills for the rear-sections of this flying plank .
Old Nov 28, 2015, 03:11 PM
FlyingNiko's Avatar
Joined Oct 2011
First piece of 1mm balsa is applied (thank you, rainforest, for this great piece of wood):
Old Nov 28, 2015, 03:13 PM
FlyingNiko's Avatar
Joined Oct 2011
A few evenings of using UHU POR and applying 1mm Balsa (1000mm x 100mm), easy does it, as helps my relaxed nature:
Old Nov 28, 2015, 03:14 PM
FlyingNiko's Avatar
Joined Oct 2011
... as you can see, I got suspicious about getting CG right and elonguated the nose by several inches.
Old Nov 28, 2015, 03:16 PM
FlyingNiko's Avatar
Joined Oct 2011
Some GFK (49gr/m˛) and 24-hours-epoxy-resin was applied. The result is not perfect as it is all done by hand, not using vacuum-technique or so...
Old Nov 28, 2015, 03:22 PM
FlyingNiko's Avatar
Joined Oct 2011
After a little sanding, primer and another round of sanding I followed my instincts and did what I like most, spraypainting this contraption:
AUW: 500gr
Wingarea: 30dm˛
Wingload: 16.6gr/dm˛ = 6.3oz/sqft
Old Nov 29, 2015, 11:10 AM
eric_laermans is offline
Find More Posts by eric_laermans
The Netherlands, OV, Kamperveen
Joined Oct 2011
Nice colour, Sir! I don't think it will fly nice on the slopes, though. I think the wing will generate way too much lift and provide too much forward resistance for high-speed slope-manouvres.
eric_laermans is offline Find More Posts by eric_laermans
Old Dec 05, 2015, 11:47 AM
FlyingNiko's Avatar
Joined Oct 2011
Well, hoping for the best then :-).
Old Dec 17, 2015, 09:53 AM
FlyingNiko's Avatar
Joined Oct 2011
Early this morning, I decided it was time for a maiden. I like a counter-intuitive approach and threw it of what looks like a slope with 3-4Bft:
Little expo here:
Flew great, set CG from 18% -> 20%. The wing picks up height quickly and it speeds up where needed. So far so good .
Do the more-experienced builders on this forum see some quick-wins? Is the reflex a good thing at all (apart from that it works). I would be happy with some answers/ remarks, anything!
Old Dec 21, 2015, 11:36 PM
FlyingNiko's Avatar
Joined Oct 2011
PW1211 plank (1 min 20 sec)
Old Dec 22, 2015, 07:41 AM
ChuckGlider is offline
Find More Posts by ChuckGlider
Silent but deadly!
United Kingdom, Bettws
Joined Jul 2015
Well done FlyingNiko, it flies! Yayyyyyyy
ChuckGlider is offline Find More Posts by ChuckGlider
Old Dec 22, 2015, 10:51 AM
Steve 0 is offline
Find More Posts by Steve 0
Slope-a-Dope
Steve 0's Avatar
United States, UT, Draper
Joined Dec 2012
What he said!
congrats on your build and successful maiden.
Your plane is a plank in the truest sense. Very little if any wing taper.
I have used several of Peter Wick's airfoils with great success on my builds but mostly they have been more tapered wings and mild chevron shaped wings. The Weasel and its clones are a great plan form to build and fly.
The reflex in the foil is needed as you mentioned. It replaces the horizontal stab on a conventional airframe. Without the reflex the flying wing or plank would be so unstable and pitch sensitive as to be unflyable. It would simply tuck the leading edge over and roll under or go into a rotor effect like when you toss a long narrow strip of balsa up and watch it go into rotor mode.
Your plank build is more ambitious than what I would do - cutting all those ribs and sheeting them with balsa. I have done it but am now lazy and use a hotwire cutter and a PW airfoil template to cut two wings in less than 5 minutes. Then I can sheet it or usually just iron 74 micron laminate on them to make them crash proof. Super easy and fast which is especially good for me to build, fly, crash, build another. Plus I have found free foam sources and filled my garage with lots of EPS and XPS foam sheets.
Keep building and flying! and sharing video!
Steve
Steve 0 is offline Find More Posts by Steve 0
Build Log PW51 Depron GFK-skin slope plank FlyingNiko Slope 12 Nov 28, 2015 02:55 PM
Discussion Depron/balsa Fly Boy3 Electric Plane Talk 13 Nov 13, 2015 08:22 AM
Build Log Minute Plank-Light lift depron Plank for travel - w/ Video Marcos Quito Slope 40 Jan 06, 2009 09:53 AM
