This thread is privately moderated by Spadplanter, who may elect to delete unwanted replies.
Old Jan 09, 2016, 04:52 PM
JakesNell is offline
Find More Posts by JakesNell
Correx IS Always The Answer!
JakesNell's Avatar
South Africa, WC, Langebaanweg
Joined Jul 2015
The Black Beauty
Mugi Evo that I just finished building, going to maiden it tomorrow, does the prop look correct, its a 6x4E? and the wing spacing? should the CG be EXACT or can it be a bit nose heavy?Final weight is 590g
JakesNell is offline Find More Posts by JakesNell
Old Jan 10, 2016, 10:09 AM
MrClean is offline
Find More Posts by MrClean
Somewhere near Parkville, Mo.
Joined May 2004
Prop backwards. Put it on the motor so that any lettering on it faces forward. The rest looks pretty good though.
MrClean is offline Find More Posts by MrClean
Old Jan 10, 2016, 01:31 PM
JakesNell's Avatar
Joined Jul 2015
Thanks man i did that and had my first flight ever today with a mugi, flew quite successful on the third try at launching (other two where nose dives ) Butt i noticed it kept flying with its nose almost 15 degrees upwards and i had to lean on the up elevator to keep it going straight. What might that be?
Old Jan 13, 2016, 06:10 AM
MrClean is offline
Joined May 2004
First off, flying wing so you must have a little up in it to fly level. But 15 degrees means you arer nose heavy. Move the cg back a bit at a time. What I always noticed was with a nose heavy plane you pull back on the stick, the tail rotates down and then the plane starts arcing up a bit whereas when the CG is close to correct you move the stick, the plane rotates (not just drops its tail) and the flight path changes immediately.
Too far back and you will have your hands full. Do this.
Find a point in your house where you can hang a loop of cord. You want to wrap a the loop arond a wing, up over the suspension point and back down to the wing. It's alittle hard on a wing as they like to tip forward. I usually loop around the nose to the opposite side wing, anythign to get it to hang level. Then put a nut on a piece of kite thread or sewing thread, something lite. I use just a 1/4 x 20 standard nut out of the junk drawer, just need something with a little weight to make a plumb bob, hang that from the same point you hang the plane from. You've made two plumb bobs, they both hang from one point and the center of mass of each is in between that point and the center of mass of the earth SO the plumb bob points to the CG of the plane.
Add weight to the tail to move that slightly back . I like between 15-19 percent of the MAC on my wings. I've had a wing at 21% and it weren't fun. You can calculate where this falls on the plane by going to the Palos RC CG calculator page and entering your dimensions. I think the Mugi plans have the CG range on them, follow those if they do. I bet your closer to 11% that's where it was when I last flew mine nose heavy.
Old Jan 13, 2016, 09:15 AM
JakesNell's Avatar
Joined Jul 2015
Thanks man that really helped alot! Here's a vid of me flying, ill post more soon
Beginner Mugi Evo Flight (0 min 58 sec)
Old Jan 18, 2016, 10:20 PM
MrClean is offline
Joined May 2004
Lands rather abruptly but other then that looks good. Hard to tell the difference in top and bottom with an all black plane.
Old Jan 21, 2016, 11:35 AM
JakesNell's Avatar
Joined Jul 2015
Lol yeah the landing was the hardest part but it was my first real full mugi flight .Yeah it is pretty hard, going to make the bottom all yellow and see how that goes :P
Old Jan 25, 2016, 05:59 AM
MrClean is offline
Joined May 2004
My first Mugi wasn't. It was called something else and it was made out of DTFB that you peeled the paper off of. Basically the same construction though and ended up with a Mugi that weighed nothing. I coupled a bunch of rubber bands together to make a 6 foot bungi and wrapped that around a pitchfork that I stuck in the ground. Shot it out of my backyard, up over my neighbors house brought it back around over another neighbors yard and back to my hand to do it again and again. The next Mugi I built I took to lake Wilson for MWSC days. Got out of the car and the wind was blowing gently and decided I'd give this a test glide. It was heavy but balanced right. I gave it a casual toss and you'd think it was the foam one it floated almost 100 yards up to the cliff edge. I walked up fully prepared to give it a good flying and the wind died for the next 4 days. Never got back with it darn it. I don't have a worthy slope for one though I suppose I could power it like yours. Just another project to do.
Old Mar 28, 2016, 07:19 PM
STEVE150 is offline
Find More Posts by STEVE150
STEVE150's Avatar
south fl
Joined Jul 2010
Hello I have a new condition OS FP 35 would like to try it on DPS.
Think it will work with sticking to plans?? I have 1 piece of
Canadian pipe.
THANKS Steve
STEVE150 is offline Find More Posts by STEVE150
Old Apr 03, 2016, 08:29 AM
Phoenix51 is offline
Find More Posts by Phoenix51
Phoenix51's Avatar
USA, OK, Locust Grove
Joined Jul 2010
First one ever built myself. I couldn't stay a balsa snob any longer, just had to try it. Built yesterday
Phoenix51 is offline Find More Posts by Phoenix51
Old Apr 08, 2016, 02:46 AM
Y.P.F. is offline
Find More Posts by Y.P.F.
Young Poor and Fun
United States, TX, Austin
Joined Sep 2012
Looks really solid. Reminds my of the ol' LT-40.
Y.P.F. is offline Find More Posts by Y.P.F.
Old Apr 08, 2016, 06:44 PM
Phoenix51's Avatar
Joined Jul 2010
First time up at level flight, the rudder began to flutter at more then 3/4 throttle and it was tail heavy, so touchy. I added some weight up front, then a guide wire to the tail. Second flight was beautiful, it flies like a stick, and that is NICE very NICE. Ground handling with a skid is not going to work and the wire gear was to short so prop strikes were EASY. I have now added a steerable tailwheel, and put some new bends in the mains and 3.5 inch wheels. I will take her up again in the morning around 8 if I can escape home lol. It did fly really nice and lands nice and slow. I am gonna be addicted to coro now...I can tell
Old Apr 19, 2016, 05:57 AM
Stretch1 is offline
Find More Posts by Stretch1
Happiness is a warm ESC.
Stretch1's Avatar
Ballarat Vic. Australia
Joined Jun 2008
Mini Mongrel
Fresh off the building board, just needs final balancing for maiden.
Turnigy 2836 2350kv Outrunner
Turnigy Plush 80A ESC
TGS Sport 6x4E Precision prop
Turnigy 2200mAh 30-40C 3S Lipo
2 X HITEC HS-65MG servos
Spektrum 6 channel Rx
910mm wingspan.
5mm Corflute fuse, elevons and vertical stab.
3mm Corflute wing and hatches.
2 x carbon fiber arrow shaft spars.
Stretch1 is offline Find More Posts by Stretch1
Old Apr 19, 2016, 10:17 AM
AERIAL MADMAN is offline
Find More Posts by AERIAL MADMAN
just about Anything can fly
AERIAL MADMAN's Avatar
Australia, NSW, Coffs Harbour
Joined Aug 2012
Looks cool, go the flaming mongrel... Lol
AERIAL MADMAN is offline Find More Posts by AERIAL MADMAN
Old Apr 19, 2016, 07:19 PM
Stretch1 is offline
Stretch1's Avatar
Joined Jun 2008
Thanks, still an untested design but I reckon she'll fly ok.
Baby steps with the Flaming Mongrel.
We've had a really dry summer and still haven't had much rain.
Don't want to make the national news by starting a bushfire with a plastic missile.
Gallery Let's see your boats flailing Scale Boats 350 May 26, 2016 07:47 AM
Idea Let's see your sloper pics! Ben74 Slope 161 Aug 04, 2005 05:44 PM
Let's see your pilots! DennisG Electric Plane Talk 39 Jun 09, 2003 06:05 AM
Let's see your Pumkins! Troy Life, The Universe, and Politics 27 Nov 07, 2002 11:00 PM
Hey Doug! Let's see a T-6 Texan!!! CheeseWing Parkflyers 9 Oct 13, 2002 01:51 PM
