Old Oct 17, 2014, 10:14 PM
hbollier's Avatar
Joined May 2013
I got one of these power supplies off eBay for under $100. No wiring, super stable power, just plug in and it makes 1500W at 24v. Voltage is adjustable from 19-29v by adjusting a dial with a screwdriver.
http://www.amazon.co.uk/gp/aw/d/B003...&robot_redir=1
hbollier is offline Find More Posts by hbollier
Old Oct 17, 2014, 10:39 PM
inverted-i-fly
3drcparts's Avatar
United States, CA, Petaluma
Joined Mar 2011
Originally Posted by jk6672 View Post
Can you take that to the field and use DC?
no, but we have AC at each table, at my other field it takes about 30 mins on a solar station at 20amps for 2 5000amp 6s
3drcparts is online now Find More Posts by 3drcparts
Old Oct 18, 2014, 06:48 AM
Honeybadger don't care...
Luv3d's Avatar
Orlando, FL
Joined May 2010
Guys- just to step back for a second, here is some math you can do to help determine what works for you, in terms of your charging needs:
Watts= Volts x Amps.
Charging at 1C means charging at the proper voltage for the pack (x) the total capacity of the individual battery pack (or the sum total of capacities if you parallel charge). For example- a 4s battery is 14.8v. If that battery is a 2700 mAh, a charging rate of 2.7 Amps is 1C
Watts= (14.8v) x (2.7A)
39.96 Watts = 14.8v x 2.7A
A 50 watt charger will allow you to charge a 4s 2700 battery at 3.37A max, or 1.25C before it hits its limit.
Use that formula with your battery pack voltage and capacities to help determine what Wattage charger would work best for you.
As a data point, a 50W charger will only charge a 6s battery at 2.25A max. If you have a 3300 mAh battery (very common in 60" class airplanes), you would be charging at .7C.
Luv3d is online now Find More Posts by Luv3d
Old Oct 18, 2014, 05:37 PM
United States, LA, Walker
Joined Jan 2014
I maiden my new Edge this morning and wow! This thing is awesome, it floats around almost like my foamies( on the low and slow stuff anyway). I really really like this bird.
Tippit is online now Find More Posts by Tippit
Old Oct 18, 2014, 05:41 PM
John
jk6672's Avatar
United States, CA, Heber
Joined Sep 2012
Puts a big grin on your face doesn't it
jk6672 is online now Find More Posts by jk6672
Old Oct 18, 2014, 05:44 PM
Joined Jan 2014
I'm still grinning from this morning!
Old Oct 19, 2014, 11:56 AM
TEAM EXTREME FLIGHT
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
Doc Austin is offline Find More Posts by Doc Austin
Old Oct 19, 2014, 01:38 PM
Sideslip's Avatar
United States, MI, Parchment
Joined May 2004
Nicely done Doc, looked like you were really enjoying the flight.
Sideslip is offline Find More Posts by Sideslip
Old Oct 19, 2014, 04:58 PM
TEAM EXTREME FLIGHT
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
Yes, this plane is an absolute sweetheart to fly.
Old Oct 19, 2014, 05:25 PM
Build carefully, fly reckless!
United States, CA, Portola Valley
Joined Aug 2013
Well done Doc! Haven't seen a video from you in a while, wow you've seriously improved!
Charlie Tilney is offline Find More Posts by Charlie Tilney
Old Oct 19, 2014, 06:01 PM
TEAM EXTREME FLIGHT
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
Thanks. We haven't seen you at all for a few months. Where have you been and what have you been flying?
Old Today, 10:29 AM
LeeB72110's Avatar
United States, AR, Morrilton
Joined Oct 2011
Anyone know when the Edge will be back in stock? Kind of thinking that to be my next 60 size plane.
LeeB72110 is offline Find More Posts by LeeB72110
Old Today, 11:18 AM
TEAM EXTREME FLIGHT
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
If you can't wait the 60" Yak is incredible, and the Edge is only a little more stable. The Yak has really close the gap.
New Product Extreme Flight 48" Edge 540T EXP! hemituda 3D Flying 10899 Today 02:05 PM
Wanted Extreme Flight 48" Edge 540T EXP FD Pilot Aircraft - Electric - Airplanes (FS/W) 7 Jul 02, 2010 11:52 AM
Discussion Daniel Holman puts the new Extreme Flight EDGE 540T EXP through the wringer! EXTREME FLIGHT 3D Flying 21 May 30, 2010 01:17 AM
Discussion 42" AJ Slick or 48" Extreme Flight Edge 540T-EXP LeeJ 3D Flying 13 Mar 26, 2010 08:26 PM
