Old Jun 30, 2015, 02:55 AM
aeo-tiffany is offline
Find More Posts by aeo-tiffany
Hubei Province
Joined Sep 2009
AEO Water-cooling ADS500M send out for testing for free !
Hi,Guys
Another new water-cooling motor ADS500M has ready to march into market now.It is excellent for motor structure and innovative cooling wayCool the stator inside motor directly,Ultra-high heat sink efficiency.
With wide range,suitable for all the 800mm length boat
With the heat sink on the surface,which enlarge the surface area and increase heat dissipation
With a filter nozzle
Dimension: 36*45mm
Length of shaft: 20mm
Diameter of shaft: 4mm
Weight: 149g
KV: 1700
No-load current :10V @3.5A
Max.power : 60A 750W
In order to obtain the professional test data and feedback,we decide to pick up 2 hobbyist for testing free of charge.
Following are the requirements for candidates:
1.Active hobbyist on RCGroup forum,promise to supply test report.
2.Specializes in the electric-powered rc boats,and pls supply your own boat picture if possible.
3.With professional knowledge for motor,and could give the professional advice such as test data,photo,data analysis etc.
Because the quantity and time is limit,pls be hurry to sign up and
write your name,delivery address and telephone NO. here.Or you can write directly via email to :info@aeorc.cn
The final candidate will be published here two weeks later.
What are you waiting for? Come to get it now!
aeo-tiffany is offline Find More Posts by aeo-tiffany
Old Jun 30, 2015, 02:59 AM
pompebled is online now
Find More Posts by pompebled
Boaters are nice people.
Sneek, Netherlands.
Joined May 2004
Me, me, me!
Hi Tiffany,
I'd like to sign up for a test, as I also run boats with the smaller ADS400L and that's a nifty little motor
Having a larger one to race with would be awsome.
I'll get back to you with the details (at work right now).
Regards, Jan.
pompebled is online now Find More Posts by pompebled
Old Jun 30, 2015, 03:22 AM
Hubei Province
Joined Sep 2009
Here i would like to supply more advantages for our ADS500M motor as below:
1.Patent water-cooling skill,with the innovative cooling way,directly cool the stator inside,which bring ultra-high heat dissipation efficiency comparing with the common motor at same size.
2. With air duct design brings the better dissipation effect.
3. With wide range,suitable for all the 800mm length boat.
4. With the heat sink on the surface,which enlarge the surface area and increase heat dissipation
5. With a filter nozzle
Hope your guys could know more about it before enroll for testing.
Old Jun 30, 2015, 07:13 AM
Dennis Manning is offline
Find More Posts by Dennis Manning
RcBoater
Joined Feb 2014
Dennis Manning is offline Find More Posts by Dennis Manning
Last edited by Dennis Manning; Jul 09, 2015 at 07:20 AM. Reason: My reply was typed and no longer needed.
Old Jun 30, 2015, 05:32 PM
boilo56 is online now
Find More Posts by boilo56
Joined Jun 2015
If you need someone to test the reliability and endurance of your motor, send one to me! the bigger is better! my boat is a Pursuit t180 ESC. Presently running a 3974-2200kv inrunner.
Regards, Andre.
boilo56 is online now Find More Posts by boilo56
Old Jun 30, 2015, 10:48 PM
Hubei Province
Joined Sep 2009
Originally Posted by pompebled View Post
Hi Tiffany,
Regards, Jan.
Hi,Jan.
You are so quick
Nice,would you pls show me our ADS400 test report here,too?
Old Jun 30, 2015, 11:02 PM
Hubei Province
Joined Sep 2009
Originally Posted by Dennis Manning View Post
Jan would be the perfect boater to test as he helps MANY rc boaters on this site.
Thanks for voting for Jan.
We will check and consider
Old Jul 01, 2015, 01:43 AM
Hubei Province
Joined Sep 2009
Regards, Andre.
Andre
Would you show me your boat photo?
I need to confirm whether your boat could suitable for our outrunner motor.
Old Jul 01, 2015, 02:55 AM
Sneek, Netherlands.
Joined May 2004
A Pursuit has a similar underwater hull as the Arowana; I've tested outrunners in my Arowana and could spin very large props using a 1600Kv 3654 outrunner.
Unfortunately that outrunner only had a watercooled mount, so it overheated rather quick (5 minute runs max).
The acceleration with a 52mm three blade prop (to keep the torque roll as low as possible) was awsome though.
@Tiffany; can this motor run on 5-6S?
Reason I ask, is the fact a relative small prop (40 - 42mm) can be used and still have enough rpm/speed.
5S would be right in the sweet spot.
Regards, Jan.
Old Jul 02, 2015, 08:31 PM
Joined Jun 2015
Originally Posted by aeo-tiffany View Post
Andre
Yes, sure! This was my first setup, worked great! Now i have what i said, T180/3974-2200kv in it.
Old Jul 06, 2015, 01:57 AM
Hubei Province
Joined Sep 2009
Andre,
That's a great boat!
Will you tell me the length of the boat?
Old Jul 07, 2015, 03:08 AM
Hubei Province
Joined Sep 2009
Regards, Jan.
YES
It can use on 5-6S
Here we test with prop D38,but it can also use on your dia. 40-42mm
Old Jul 08, 2015, 02:55 AM
Hubei Province
Joined Sep 2009
So is there any other person would like to have a tryout?
The estimate date will close soon,pls be hurry if interest.
Old Jul 08, 2015, 03:08 AM
f.a.r.m.e.r is offline
Find More Posts by f.a.r.m.e.r
Farmer
f.a.r.m.e.r's Avatar
United States, CA
Joined Oct 2011
I'm more interested in Jan's (pompebled) results then wanting to test one, looks like a great motor though.
f.a.r.m.e.r is offline Find More Posts by f.a.r.m.e.r
Old Jul 08, 2015, 10:05 PM
Hubei Province
Joined Sep 2009
That's ok!
Which you all prove that Jan. is a professional hobbyist.
And pls wait for his feedback after testing.
Discussion AEO New Water-cooling motor ADS400L will send out for testing for free ! aeo-tiffany Racing Boats - Electric 114 Oct 04, 2014 09:34 AM
For Sale Riva aquarama special - wooden hull for rc - water-balance tested - free shipping tantrasway.com Boats (FS/W) 0 Jul 26, 2014 12:30 PM
Cool Free try-out---FPV System 1.0:Expanded function for AEO XGYRO-1000(Video updated) AEORC FPV Talk 269 Jun 15, 2011 12:35 PM
Cool Free try-out for the head tracker--XGYRO-1000 from AEO AEORC FPV Talk 224 Sep 08, 2009 04:23 AM
