Old Aug 21, 2015, 06:11 AM
CV12Steve is online now
Find More Posts by CV12Steve
United States, CA, Sacramento
Joined Apr 2014
Ferrite clamps.
CV12Steve is online now Find More Posts by CV12Steve
Old Aug 21, 2015, 09:36 AM
Revector is offline
Find More Posts by Revector
Joined Jun 2014
Originally Posted by CV12Steve View Post
Ferrite clamps.
Yup ferrite clamps
Revector is offline Find More Posts by Revector
Old Aug 21, 2015, 01:38 PM
dfruehwald is offline
Find More Posts by dfruehwald
WZ9V, AMA 409852
United States, VA, Alexandria
Joined Jan 2007
Originally Posted by Revector View Post
Hi guys,
I completed my Taranis mods/rebuild and I am very happy with the results and that I managed to not fry my Taranis during the process
I made the following mods to it:
- custom paint job (front, back, battery cover, module cover)
- gimbal upgrades (replaced cross bars with alloy ones, replaced springs with futaba heavy duty springs, lubricated with silicone grease, tension adjustment)
- installed 6 position switch S3 switch on top
- removable antenna upgrade with 2db, 5db And patch antennas
- speaker upgrade (replaced 1/2W speaker with 2W 36mm speaker, 3 printed adaptor and backing)
- static reduction mod for when external module is in use (ferrites on main cables)
- silicone covering for stand
- gforce Gravity bar
- upgraded to latest opentx
- custom sounds
- custom splash and model graphics
Everything works as expected. Field tested. Way more time and effort then I thought it would take but most of my projects usually turn out that way.
What do you guys think? Good or bad?
Attachment 8170917
Attachment 8170918
Attachment 8170919
Attachment 8170924
Nice, what paint did you use?
How did the Ferrite clamps work out? I a plus on the way and was thinking of doing that mod. On my old B model I just di the separate teh audio wire and hot glue it method which won't work on the plus.
I did my B-Model (non-plus) with the Testors metallic blue and then a clear coat. If came out a bit darker then I wanted because of the silver base underneath. I then went with Metallic Green which I think came out nicer (more contrast with the black parts). My next try might be a lemon yellow or a bright red.
dfruehwald is offline Find More Posts by dfruehwald
Old Aug 23, 2015, 04:36 AM
frater is online now
Find More Posts by frater
Joined Aug 2014
Originally Posted by Gordysoar
Hi,
I have a taranis, have three, and would like to add the LED mod that shines when the TX is on. I did some digging in the threads but didn't find any detail about which LED's and where to connect.
I don't care about the charging LED since I charge outside the TX.
I use a 3 cell lipo.
I have two B models and a Plus with Speaker mods.
Gordy
I fly comp sailplanes mostly
Thanks!
The problem is that I did an amplifier mode before.
I'm juicing the on-board amplifier with 5V instead of the regular 3.3V
I do this by tapping into the raw battery power that's after the main switch.
In this thread I did a howto for that.
In the end I chose for using that 5V for driving my LED, but it could well be the RAW power with a larger resistor.
Of course I did the proper calculations at the time, I believe I used 330 ohms but not sure. If you tap into the RAW battery it has to be somewhat higher. You need to limit the current going through the LED and for this you need to know the range the NiMH is going to be. Focusing on the highest peak, which is 8.4V
I have a picture of that mod I did.
Be aware the focus of the mod is getting the amp to work on 5V
In the picture you can see an 7805 Voltage regulator which I connected to the switched raw battery output.
The input of the 7805 is the outer pin. The middle one is connected to the grounds. You can use that same pin to drive your LED
frater is online now Find More Posts by frater
Old Aug 25, 2015, 02:56 PM
everfree is offline
Find More Posts by everfree
Joined Dec 2013
Originally Posted by Dimitris76 View Post
Hej Thorvald,
was this the 70mm long pigtail?
From Aloft hobbies?
http://www.alofthobbies.com/rf-coax-assembly-70mm.html
/Dimitrios
can i use this antenna with this mod ? http://www.hobbyking.com/hobbyking/s..._Modules_.html
everfree is offline Find More Posts by everfree
Old Aug 25, 2015, 03:18 PM
Adilson is offline
Find More Posts by Adilson
Discovering the joys of flying
Adilson's Avatar
Brazil, SP, Campinas
Joined Aug 2012
As long as the connectors are correct, sure.
Adilson is offline Find More Posts by Adilson
New Product FrSky Taranis - 16 Channels, Full Telemetry, RSSI Rotozuk Radios 44618 Today 06:44 AM
Question FrSky Taranis - assimilating web info mcshaz Radios 7 Jun 16, 2015 10:30 AM
Discussion is the FrSky Taranis next step after Turnigy 9X 9Ch tormodnt Radios 3 Nov 30, 2014 06:58 PM
Wanted FrSky Hack module, Flydream Hack or JR module Fentonflyers Aircraft - General - Radio Equipment (FS/W) 5 May 28, 2014 12:33 AM
