Old Jan 20, 2015, 12:18 AM
United States, CA, San Diego
Joined Oct 2014
Soldering— what am I doing wrong? (Tinning)
Not sure if this is the right area to post...
So I turn on the iron, let it heat up, then I directly apply solder on it in an attempt to tin it. There's a lot of smoke (not sure how much is normal), and whatever liquid that's supposed to be there wasn't present, just turns brown and piles up. When I tin at a cleaner part of the tip, I can see shiny-ness but it just rolls up into a ball on the soldering wire.
Have never soldered before, what should I keep in mind?
I don't have the budget for a $100 iron though I know that it's worth it.
Description:
seikurou is offline Find More Posts by seikurou
Old Jan 20, 2015, 04:05 AM
Staffs, UK
Joined Nov 2003
What type of solder are you using ? Does it have flux in it ? Are you using a separate flux, if so what type ?
The tip has to be clean. It's normal to wipe it on damp sponge BEFORE applying the solder. And you need some flux either built into the solder or applied separately.
Steve
slipstick is online now Find More Posts by slipstick
Old Jan 20, 2015, 05:15 AM
Learn to build with wood.
Tucci's Avatar
United States, NC, Newport
Joined Sep 2012
Clean that tip!
Tucci is offline Find More Posts by Tucci
Old Jan 20, 2015, 07:21 AM
United States, TX, Van Alstyne
Joined Dec 2014
you can clean it till the cows come home. ... sometimes - most always actually - the tip will have areas that oxidize, and wont "tin".
Don't worry to much . Wipe it on sponge, then tap it on the bench before every solder joint.
When you solder you do not apply the solder to the iron anyway, but to the work. well, in theory.
speedyb_tx is offline Find More Posts by speedyb_tx
Old Jan 20, 2015, 07:45 AM
Canadian Bacon
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
Also make sure your solder says Resin core and not Acid core.
You can also buy solid solder with no flux.
Gord.
flypaper 2 is offline Find More Posts by flypaper 2
Old Jan 20, 2015, 09:35 AM
Joined Oct 2014
I'm using Kester pocket pack solder from Amazon. When I clean it the solder just turns black.
Also what is flux and how do I use it?
Old Jan 20, 2015, 10:44 AM
Canadian Bacon
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
Should say on the label ( 44 Rosin Core Solder)
It coats the parts to keep it from oxidizing
Gord.
Old Jan 20, 2015, 11:28 AM
KC
Registered Loiterer.
KC's Avatar
United States, FL, Orlando
Joined Sep 2006
Got to use flux. The flux helps the solder to flow. It's applied to the surfaces that is being soldered. Lots of 'how to' videos on YouTube. I can't imagine soldering without it.
Rosin solder paste flux from RS.
http://www.radioshack.com/2-oz-non-s...EARA&gclsrc=ds
KC is offline Find More Posts by KC
Old Jan 20, 2015, 02:41 PM
homo ludens modellisticus
Ron van Sommeren's Avatar
The Netherlands, GE, Nijmegen
Joined Feb 2001
Several (English) youtube solderings videos, tips and tricks, do's and don'ts in this thread
translate...www.modelbouwforum.nl/forums/model-elektronica/152358-solderen-dos-donts.html
And
Soldering discussions - RCG
Vriendelijke groeten Ron
Ron van Sommeren is offline Find More Posts by Ron van Sommeren
Old Jan 20, 2015, 07:58 PM
Doug Bartley's Avatar
Canada, ON, Owen Sound
Joined Oct 2008
Your soldering iron may not be powerful enough to do the job either. A 30W iron will barely solder 16gauge wire, and likely not with a pencil point. I use a 40W for small stuff up to 20 gauge, and an 80W for everything up to 8Gauge wire. As mentioned the solder has to be for electrical connection, and should be rosin cored, along with the right size solder wire for the job. My solder wire for most jobs is less than 1/16". Too much diameter will pull the heat away faster than the iron can melt it, resulting in blobbing, no fusion. Both wire and connector must be tinned along with the iron to transfer the heat effectively. fwiw Doug B
Doug Bartley is offline Find More Posts by Doug Bartley
Old Jan 20, 2015, 09:01 PM
Joined Jan 2007
Attachment 7488026
What size wire are you trying to solder?
This tip looks like it got overheated, with burned flux on it. Take a magnet near the tip and determine if it's magnetic or iron plated.
If it's iron plated, do not file it with a file. That iron plating is thin, and removing it screws up the tip.
If the tip is bare copper, you can trim it up with a file, and immediately "Tin" it with rosen core flux. Un regulated irons can hit 900 or 1000 degrees F, and burnt tips are the result.
If you're soldering heavy wires on the order of #10 or #12 or so, a 100 watt temperature regulated iron can be purchased for about $65 or so, and that will last a long long time. This iron will easily solder just about anything that would be used on our electric models. It also has smaller 3/16 inch wide tips for the smaller stuff.
SOLDERING IRON 100 W
http://www.wattflyer.com/forums/showthread.php?t=59884
vollrathd is offline Find More Posts by vollrathd
Old Jan 20, 2015, 11:16 PM
Joined Oct 2014
Thanks for the info guys
I'm using a 40w iron from Amazon
http://www.amazon.com/Weller-SP40NKU...soldering+iron
I realized that this area is for airplanes; I'm more worried about building multirotors. Not sure about the quality of above iron, but I'll have to stick to it for a while.
Are there any recommended fluxes I could get from a third party seller from Amazon/Ebay?
Old Jan 21, 2015, 06:18 AM
Canadian Bacon
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
The Kester brand you have is very popular, just get it where it says '44' Rosin Core Solder on the label. A popular size for small stuff is 1mm or .039 " thou. If you can find just rosin flux while you're looking for solder, get a tin of it so you can use the solder you have. Just dip your solder in it and smear a bit it on the piece your soldering.
Welding shops and Radio shack carries it.
Gord.
Discussion Okay I need help with this what am I doing wrong? UM p51d ApexpretadorGT Electric Warbirds 24 Nov 24, 2014 02:20 PM
Discussion Control Board Setup-What am I doing wrong? Simdor Multirotor Electronics 3 Nov 23, 2014 06:42 AM
Discussion First build, what am I doing wrong?? InterestedParty Scratchbuilt Multirotors 2 Feb 02, 2014 11:04 PM
Discussion GoPro 2 video cable not working? What am I doing wrong? Demo7 FPV Equipment 4 Jan 26, 2014 11:53 AM
