Old Jan 17, 2015, 05:28 PM
Joined Jun 2014
Question
Ar6400 plane question
I would like to find a home for one of my ar6400 and p51 gearbox and motor. The foam I have is a sheet of 12x36 in of 6mm epp and about 10x36 in 3mm epp sheet.
I want it to be able to fly outside in low wind conditions and inside to. Could I take one of flite tests might minis and scale it to about 15 in? Or maybe something else? It can only be 3 channels as I don't have any spear servos laying around. No balsa please. Or maybe a peanut scale plane converted to foam?
Olmouse
Olmouse is offline Find More Posts by Olmouse
Old Jan 17, 2015, 05:47 PM
Mikeofthenorth's Avatar
United States, MI, Oxford Charter Township
Joined Dec 2012
In the micro indoor plane forum there is a whole tread on planes built using AR6400 brick, I would start there to get ideas.
http://www.rcgroups.com/forums/showthread.php?t=1146395
Mikeofthenorth is online now Find More Posts by Mikeofthenorth
Hot glue held together by foam
United States, WA, Vancouver
Joined Aug 2010
Olmouse
You may get better results asking in the micro indoor scratch built forum
http://www.rcgroups.com/scratchbuilt...cro-models-85/
balsa or carbon is online now Find More Posts by balsa or carbon
Old Jan 17, 2015, 06:33 PM
Joined Jun 2014
ok thanks
Old Jan 17, 2015, 08:54 PM
Joined Jun 2014
Anything else
Old Jan 17, 2015, 09:13 PM
KC
Registered Loiterer.
KC's Avatar
United States, FL, Orlando
Joined Sep 2006
Any of the plans that you find can be scaled down for the ar6400. It all depends on the type of planes you like to build/fly.
Maybe if you gave some more info as to the type of planes you like, perhaps you'll get more responses.
KC
KC is offline Find More Posts by KC
Gallery show off those ar6400 planes! the riot Scratchbuilt Indoor and Micro Models 4653 Jan 20, 2015 05:16 PM
For Sale (2) new 3A 1s Bl esc with ar6400 servo connector will trade for ar6400 brick nemoskull Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 0 Jul 08, 2014 09:39 PM
Sold ***TRADE*** as3x ar6400 with aileron servo for normal ar6400 microairman1 Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 4 Apr 23, 2014 10:19 PM
Discussion Non-AR6400 Indoor Bi-Plane swimmer Foamies (Scratchbuilt) 7 Oct 10, 2013 09:26 PM
Discussion ar6400 3d planes glen Scratchbuilt Indoor and Micro Models 6 Sep 02, 2009 07:16 AM
