Old Jan 16, 2015, 04:57 PM
bailbonds's Avatar
United States, VA, Hopewell
Joined Apr 2012
Originally Posted by Bigster View Post
Ooo I like that. Cold weather is a good time to be making these kinds of tweaks! Thanks!
I like that idea too! Thanks
bailbonds is online now Find More Posts by bailbonds
Old Jan 17, 2015, 11:26 AM
United States, WI, Milwaukee
Joined Sep 2008
Anyone have a spare set of axles they would sell?
Mine are shot and I can't find any that fit. The Dubros (5/32) are huge and heavy and I don't want to drill out the landing gear.
Brownie433 is offline Find More Posts by Brownie433
Old Jan 17, 2015, 05:48 PM
bailbonds's Avatar
Joined Apr 2012
I think 3DHS posted on FB that they have a bunch of spare parts "on the water".
I would send you some if I could.
Old Jan 17, 2015, 06:26 PM
Joined Sep 2008
Thanks! I sure hope so, that would be awesome. I'll check it out.
Brownie
Old Jan 18, 2015, 12:36 AM
Surrey, B.C.
Joined Feb 2004
I might have a set of spare axles off my 1st 57" that I totaled hitting a post
Mach3 is offline Find More Posts by Mach3
Old Jan 19, 2015, 08:32 AM
Joined Sep 2008
PM Sent. Thanks!
Old Jan 19, 2015, 01:18 PM
maxx4wd's Avatar
United States, CA, Thousand Oaks
Joined Feb 2013
Originally Posted by SteveT. View Post
The motor I listed is a 4S motor, if running on 6S, you would need a pretty small prop...
SteveT.
Oh you're totally right - I had mine re-wound to 500kv for 6S...forgot to add that to the last post..
maxx4wd is offline Find More Posts by maxx4wd
Old Jan 20, 2015, 11:54 AM
More Motors, More Fun... :-)
nioa's Avatar
Phoenix, AZ
On the good side, losing an aileron might not have been fatal - just would have been "strange" flying with only one. Now losing the elevator arm ....Loktite is bad for plastic so it depends what you're using for servos.
metal gear servo's?
I think that's fine, just be sure not to get any on the arms (unless you're using aluminum arms).
Originally Posted by bryansifsof44 View Post
A little dab of hot glue on top of the screw after installed has worked great for me... Doesn't effect plastic either. Just dig out with a screwdriver when you need to remove.
Hot glue is good, I also use canopy glue (Pacer formula 560). No digging needed, and holds firmly, but can be disassembled easily.
nioa is offline Find More Posts by nioa
Old Jan 20, 2015, 08:44 PM
Time to Fly AJ's Best!
heritageflyer's Avatar
Hills of Eastern Ohio
Joined Nov 2008
Winter Sunset flight, 2nd of two. Was 40F late afternoon. Not bad for mid-late January! First time out with the 57 SC in awhile.
Watch and listen on the first KE Slider pass.... Seems I'm missing some covering and balsa on the corner.... Also got it home and out fell one of the two prop adapter nuts I use (double nutted). Wondered what the strange new sound was on the first flight. Vibrated loose I guess, seen this before. That's why I double nut on this one.
3DHS 57 EXTRA 330 SC WNTER SUNSET (4 min 37 sec)
heritageflyer is online now Find More Posts by heritageflyer
Old Jan 20, 2015, 09:07 PM
↓↘→ + (punch)
theKM's Avatar
central PA.
Joined Sep 2004
https://www.youtube.com/watch?v=Rvl2...ature=youtu.be
nice! a solid touch indeed
theKM is offline Find More Posts by theKM
Old Jan 22, 2015, 08:08 PM
bailbonds's Avatar
Joined Apr 2012
with the new 61 coming out, I wonder if the existing stock of the 57's will go on sale. I just may stock up on a couple of them; then fly them like they are stolen.
Old Jan 22, 2015, 08:35 PM
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
I would bet that it is going to be a while before the 61's are available...
SteveT.
SteveT. is online now Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Jan 22, 2015, 08:39 PM
bailbonds's Avatar
Joined Apr 2012
I can wait. Gives me more time to save up my hobby bucks
New Product 3D Hobby Shop 47" Edge 540 #BUILD VIDEOS ADDED# ipsmotors 3D Flying 3960 Nov 23, 2013 08:39 PM
Video 3D Hobby Shop 57" Sukhoi sukhoi26mx Electric Plane Talk 7 Sep 17, 2008 09:33 AM
Sold NIB 3D Hobby Shop SHP Extra 300 *Blue* Version 2 thomer Aircraft - Electric - Airplanes (FS/W) 7 May 04, 2008 02:31 PM
Build Log 3D Hobby Shop 55" Katana LIVE Build Log Jeremy Sebens 3D Flying 54 Oct 12, 2007 04:39 PM
