Old Today, 10:58 AM
Tom Frank is offline
Find More Posts by Tom Frank
Dance the skies...
Tom Frank's Avatar
United States, MA, Walpole
Joined Dec 2003
Originally Posted by angelo.p View Post
Thank you for you help...but nothing yet :-)
- the mobius run well as webcam (if I remove the SD)
- the mobius let me browse de SD contents (so I suppose the reader is ok)
- I formatted the card with internal routine
- I used another card
BUT when I press REC the yellow led remain fix and I cannot stop or record.
It's very strange!
When trying different cards, it's recommended that you use cards with CL4 speed class, and avoid CL10 cards. You didn't say, so just mentioning.
To test the shutter button as Janke suggested, you can just us a wire to short across the solder point on the button tab corner to an adjacent corner solder point. I forget if doing this in the shooting direction or sideways direction creates the same action of the button (sideways I think is correct, the other direction won't hurt anything because its already a direct short to the test pin). So try both ways to see if that triggers a recording.
Tom Frank is offline Find More Posts by Tom Frank
Discussion Heli Pad Review Series: SYMA X3 Quadcopter Review Heli Pad Mini Multirotors 121 May 28, 2015 04:30 AM
Discussion Olypic II is under construction now Texas Buzzard Sailplane Talk 16 Aug 10, 2014 01:54 PM
Video Quad filming roller coaster under construction Brian_ Multirotor Talk 1 Mar 04, 2013 02:19 PM
Todd's Tiny under construction Tres Wright Parkflyers 30 Jun 24, 2002 12:20 AM
