Old Oct 18, 2014, 06:51 PM
We can rebuild it!
djdavies83's Avatar
United Kingdom, Wales, Swffryd
Joined Apr 2010
I've searched hard for them pins but no idea EXACTLY what they are called or where to get them, any ideas?
djdavies83 is offline Find More Posts by djdavies83
Old Oct 18, 2014, 07:02 PM
We can rebuild it!
djdavies83's Avatar
Joined Apr 2010
Found it through the blog link thanks.
Old Oct 18, 2014, 07:38 PM
WZ9V, AMA 409852
United States, VA, Alexandria
Joined Jan 2007
Cool, that's why I posted the link. I built one of the modules in the blog and it worked great.
dfruehwald is offline Find More Posts by dfruehwald
Old Oct 18, 2014, 07:50 PM
We can rebuild it!
djdavies83's Avatar
Joined Apr 2010
I don't fancey the £12 shipping fee on 3 connectors.
Did you get yours from the product link in the blog?
Does this look like a suitable alternative?
http://uk.farnell.com/jsp/search/pro...sp?sku=9732349
Old Oct 18, 2014, 08:36 PM
WZ9V, AMA 409852
Joined Jan 2007
I'm in the US and was buying a bunch of other parts at the same time so shipping wasn't that bad. I think you will have to see if you can find an equivalent from a European source in order to not have shipping be ridiculous.
That does look like it would work.
Old Oct 20, 2014, 04:40 PM
Spain, Madrid, Madrid
Joined Feb 2008
Hi goebish,
I'm definitely interested in getting one PCB,
Thanks!
Originally Posted by goebish View Post
Note this is for Taranis X9D(+) Only !
Better safe than sorry so, here's a rev2 with a LDO.
R1 = R2 = R3 = 1K (0805)
R4 = R5 = 5.6K (0805)
Q1 = 2N2222 (SOT-23)
C1 = C2 = 10 µF / 10V tantalum (1206), expensive, probably not mandatory, but better have them, at least C2.
IC1 = AMS1117-3.3 (SOT-223)
headers:
(2x) 1x7 2.54mm pitch male
1x5 2.54mm pitch female
1x9 2.00mm pitch male
requires:
1x Arduino pro mini, any version, goes on bottom
1x A7105-D03 RF module, goes on top
I attached a zip archive with eagle files and .hex firmware (8 & 16MHz versions)
A few things about the firmware:
- plug & play, no need to revert any channel or adjust endpoints on the X9D
- AUX1 controls LEDs
- AUX2 controls flip-ability
- AUX3 controls the vTX channel for the X4 FPV version (H107D), so you can use it with your fatshark goggles or any other vRX, it's split in 8 "zones", by default it uses ImmersionRC/Airwave compatible frequencies:
5740, 5760, 5780, 5800, 5820, 5840, 5860, 5860
connect pins 10 & 11 together on the arduino to use Boscam band E compatible frequencies instead:
5705, 5685, 5665, 5645, 5885, 5905, 5925, 5945
- telemetry: there's battery voltage telemetry sent via smartport, openTX can display it, you can also set an alarm directly in your TX. note that the value reported by "RPM" is the current vTX frequency actually.
I can make a small batch if enough (at least 5 or 6) people is interested.
sanper is offline Find More Posts by sanper
Old Yesterday, 02:36 PM
Switzerland
Joined Sep 2008
Hello,
I received my promini today.
I have assembled everything.
My hubsan is binding with the tx but nothing happen.
When I increase the throttle, the prop are not spinning
I have uploaded the soft Hubsan_V2_M328_8Mhz.hex
As it is binding, I believe that the problem comes from my ppm signal. How can check it ? I can check the voltage between "3" and ground
Cid156 is online now Find More Posts by Cid156
Latest blog entry: Miniquad WSk250
Old Yesterday, 02:42 PM
midelic's Avatar
Joined Apr 2012
Yes check the voltage..do you have resistor in series with PPM signal?Which Tx do you use?Which channel order?Should be AETR channel order...with that hex.
midelic is offline Find More Posts by midelic
Latest blog entry: DIY Multiprotocol TX Module
Old Yesterday, 02:48 PM
Switzerland
Joined Sep 2008
I am using 10k resistor like the schematic below
Between ground and "3", I have 1V
Yes I am using a Futaba 7cp and it is AETR
I have also inverted the throttle but still nothing
Old Yesterday, 02:53 PM
midelic's Avatar
Joined Apr 2012
That is the problem..The original design was for Turnigy 9X which have 4.6V on PPM signal...Which voltage you have on Futaba before that 10 k resistor?..If it is around 3 V remove the 10k resistor in series one or put a smaller one 1K resistor in series with PPM signal..Before start throttle should be zero,.. if not hubsan, not starting...lower also throtle trim.
Old Yesterday, 03:01 PM
Switzerland
Joined Sep 2008
I have 2.7V
Just to be sure that I understood.
I must remove only 1 resistor. The one just after my tx and I should leave the "bridge" with the 10k between gnd, 3 and ppm signal
Old Yesterday, 03:03 PM
midelic's Avatar
Joined Apr 2012
In that case you can remove both.....2,7V is good voltage for PPM signal.Those 2 resistors was for a voltage divider to reduce voltage to 3.3-3.6V ,max on PPM signal.
However if you use the module with other tx ,,with higher PPM signal keep in mind ..to use one resistor in series 1-2K...or the some other voltage divider(calculate voltage drop) if voltage is higher than 5 V.
Old Yesterday, 03:16 PM
Switzerland
Joined Sep 2008
It is flying !!!!!!!
It did not work until I put the trim totally down... do you think that I must retry with the two resistors and the trim down ? For safety ?
Old Yesterday, 03:22 PM
midelic's Avatar
Joined Apr 2012
My suggestion is to put only one 1.5-2.2K resistor in series PPM...and that's it.Thers is no need of second resistor(paralel)...The PPM pin is set as input is high impedance ...so I think only one resistor in series is enough.
Old Yesterday, 03:30 PM
Switzerland
Joined Sep 2008
Ok thank you
Mini-HowTo DIY "FlySky" TX/RX module midelic DIY Electronics 2086 Yesterday 10:33 PM
Found WANTED: FUTABA TP-FSM 72MHz Synth RF Module svjerk Aircraft - General - Radio Equipment (FS/W) 1 Jun 28, 2013 09:44 AM
Discussion DIY Telemetry System base on TI CC110L RF BoosterPack spy004 DIY Electronics 2 Mar 06, 2013 07:58 AM
Discussion FrSky 2.4G DIY RF Module into JR XP 7202 kriss poppe DIY Electronics 5 Jun 04, 2011 08:39 PM
