Old Jan 20, 2012, 08:09 AM
United States, WI, Mukwonago
Joined Nov 2011
Build Log
Gloster Meteor Build
OK I'm going to try to start a build thread on Jim Youngs Glostner Meteor. I am by far a novice at flying and really a novice at building other than one kit a small Gee Bee and a couple of ARF's. So if your more experienced builders can offer suggestions it would be helpful. Jim's plans and directions are great but me being a novice you may see some mistakes I have made and if you can help me before proceeding it would very helpful.
dfsmith is offline Find More Posts by dfsmith
Old Jan 20, 2012, 08:27 AM
I eat glue
Canada, NS, Yarmouth
Joined Jul 2006
Are you referring to the angle on the leading edge of the elevators where the hinges join it to the stabilizer? That will indeed need to have the angles to allow it to provide up and down elevator. I usually use straight angles rather than sanded round because a rounded leading edge on the elevator will bind if it doesn't have enough clearance. With a more pointed leading edge you can have tighter hinge lines with less gap.
baldguy is offline Find More Posts by baldguy
Old Jan 20, 2012, 08:45 AM
Joined Nov 2011
More Pics
Old Jan 20, 2012, 08:49 AM
Joined Nov 2011
Elevator side veiw. Maybe this diagram may help me explain.
Old Jan 20, 2012, 08:59 AM
Joined Nov 2011
more pics.
Old Jan 20, 2012, 09:20 AM
I eat glue
Joined Jul 2006
Yep, that's what I figured you were referring to. That should work. I usually run the sheeting just up to the thick leading edges, then you only have to shape that piece without any glue on it.
Old Jan 20, 2012, 09:55 AM
turbonut's Avatar
upland CA
Joined Dec 2004
Hello,
it looks like you are off to a good start so far..What glue are you using..looks like tight bond maybe...make sure its sandable when dry..nothin like trying to sand soft glue...
Old Jan 20, 2012, 09:58 AM
The Hun in the Sun
vonJaerschky's Avatar
Canada, BC, Comox
Joined Nov 2003
Lookin' Good! I really like the old jets. I think they have a bit more character than the modern rocket ships. (psssst..... it's "Gloster")
vonJaerschky is offline Find More Posts by vonJaerschky
Old Jan 20, 2012, 11:48 AM
Joined Nov 2011
Turbonut, yes titebond the aphitic. I was reading up and everybody was giving there opinions on glue I built my Gee Bee with gorilla and some arf's with CA. Whats your opinion? CA on some of this just seems brittle and fragile JMO seems like the titebond or gorilla is how can I say more durable. I soak an mount holes with thin CA that works great.
Von i like the older jets also T-39, F9F thats why when i seen the glostner it like a no brainer you can't out the 86 sabre's
Old Jan 20, 2012, 02:06 PM
turbonut's Avatar
upland CA
Joined Dec 2004
Hello...yep I use the same...was using the G.P. alpthatic but seems out of stock so now its titebond2..CA I use as the nail to hold while the TB dries...I remember havin to wait a day after each step for the glue to dry...took for ever to build a wing...now can kick a frame out on one night
Old Jan 20, 2012, 04:54 PM
http://roys-rc-tv.webs.com/
Basingstoke Roy's Avatar
United Kingdom, England, Basingstoke
Joined Oct 2005
Hi Dennis
I've found your thread. Looks like your off to a good start , 100% more than I've done on mine.
As for glues I go alone a similar route as Turbonut. Where parts are CNC cut and jig fit together I tend to go for thin CA & no kicker. For skinning & butt joints Deluxe Materials (DM) Aliphatic or DM Super'Phatic, and small spots of medium CA to hold the parts if needs be. If the joints are out of site & wont need sanding I'm not adverse to a PVA.
Keep it coming
Roy
Basingstoke Roy is offline Find More Posts by Basingstoke Roy
Old Jan 20, 2012, 06:00 PM
Sports scale builder
Tonybuilder's Avatar
Joined Jan 2012
Hi Dennis, looking good. I started mine today, got the stab all done and
I will work on the elevator tonight. I like the CA, fast and keeps me moving. I will use the slow glue when I need time to get things all lined up.
TB
Tonybuilder is offline Find More Posts by Tonybuilder
Old Jan 20, 2012, 09:20 PM
Joined Nov 2011
Tony, Put some pictures up of your progress.
Old Jan 21, 2012, 09:04 AM
Joined Nov 2011
Last nights work tail skinned needs to be trimmed, glued all the ribs for the rudder and have to elevator linkage and one elevator skinned and angle for hinges trimmed
Old Jan 22, 2012, 08:01 AM
Designer/Builder
Jim Young's Avatar
Brighton, MI USA
Joined Jun 2000
Looking good Dennis!
FYI... I posted a construction manual for the Meteor on my website. It is pretty much the same text as the MA article, but it has more photos.
Jim Young is offline Find More Posts by Jim Young
Discussion Nitroplanes Concept X or Meteor? jackheli Foamy EDFs 4 Oct 01, 2011 02:49 AM
Discussion Dynam Meteor EDF Jet Build By Jeff nitroplanes Nitro Planes 1 Jan 31, 2011 12:41 PM
Mini-HowTo Dynam Meteor EDF Jet Build By Jeff Part One + Two NitroD Nitro Planes 0 Jan 27, 2011 12:19 PM
Discussion Dynam Meteor - build video? erudited Electric Ducted Fan Jet Talk 8 Jan 23, 2011 03:19 PM
Meteor Scratch Build scratchandbash Electric Ducted Fan Jet Talk 32 Nov 04, 2005 10:59 AM
