USA, ME, Ellsworth
Joined May 2008
Sometimes a motor will do that stuttering thing because of the prop being a load that it couldn't push through the magnetic fields at first, so it bounces back. Then the ESC sees it is going the wrong direction on the bounce back and reverses it again to get it going the right direction. On the next try the prop has sort of like a running start and then it carries through the slightly opposing magnetic field and starts. And the gear box might be contributing something to that too.
A possible solution might be a "harder" start when it applies more current to the starting forces. According to the manual for the Pheonix ESC's you choices are Very Soft, Soft, or Fast start and Soft is the default. So trying the other start settings may change things. I'd think the Fast start might be the one that would help but I would try them both to see the effect. Jack |
| Thread Tools | |
| Discussion Starmax Salamander - motor runs backwards | Turbobearcat | Foamy EDFs | 1 | Mar 11, 2013 08:12 PM |
| Help! V120D02S motor stutters on start-up | trouble0667 | Micro Helis | 2 | Feb 28, 2013 07:51 PM |
| Discussion Gaui motor works then doesn't [just stutters on throttle] then does ... | turnbui | Micro Helis | 2 | Mar 17, 2009 06:48 AM |
| Discussion Motor starting backwards, then forward?? | Ralph Weaver | Power Systems | 5 | Jun 30, 2008 02:04 PM |
| Motor runs backwards, stalls, then forwards?! | Red 61 | Power Systems | 6 | Apr 13, 2005 10:47 AM |
