Closed Thread
Old Sep 12, 2014, 10:43 AM
Joined Feb 2014
Question
Horizontal position of wing on fuselage
Hi Everyone!
While in the process of making stick rc planes with foam wings, rudder, elevator, etc... I ran up with a question on wing position.
Assume the fuselage (ie. stick) is 27". I made an RET plane with the following characteristics:
Wing chord: 5"
Leading edge of wing: 9" in back on fuselage.
CoG: 10" back on fuselage.
I chose the wing's leading edge to be 9" back (which is 1/3 of the fuse length) - that seems to be about where most trainer planes have their wing location.
The plane flew just ok since - I had some issue with the control surfaces and since I'm almost a newbie.
Is there a "suggest" horizontal location of the wing on the fuselage??? Would the same plane be able to fly if I put the wing's leading edge closer to the front (off-course the CoG would change:
Wing chord: 5"
Leading edge of wing: 2" back on fuselage.
CoG: 4" back on fuselage.
Also does the CoG have to be located somewhere on the wing?
Thanks.
dropout is online now Find More Posts by dropout
Closed Thread
Discussion Theoretically, can I create a horizontal & vertical position lock w/ 3 sonar sensors? FitSystems Multirotor Electronics 1 Aug 08, 2014 08:17 PM
Discussion Topsky 3.0 D horizontal stab position? GORT000 Hand Launch 3 Dec 21, 2013 05:55 PM
Discussion Using AR6400 and wing servo on a AS3X fuselage Hawk600 Scratchbuilt Indoor and Micro Models 4 Oct 16, 2013 07:09 AM
Sold NIB Venom F-86 Wings and Horizontal Stab MikePS Aircraft - Electric - Jets (FS/W) 4 Oct 14, 2013 08:09 AM
Question Motor Mount Positioning on Delta Wing THOMASJONES Flying Wings 3 Oct 04, 2013 02:12 AM
