Old Jan 06, 2012, 03:41 PM
Tailwind1's Avatar
Casstown, Ohio
Joined Sep 2010
Question
DT750 motor bearings
Does anyone know of a good quality replacement bearing for the Hobby King "hextronik DT750" motor. I had a bearing fail after the 7th flight on my quad.
Tailwind1 is offline Find More Posts by Tailwind1
Old Jan 06, 2012, 03:53 PM
LoS sUAS AP/V is not a crime.
W,,,,,,,,,,,,,,,,,,,,'s Avatar
Grass Valley, CA
Joined Feb 2008
My LHS has parts for Blade helis.
Part number EFLH1215 includes two 4x8x3mm bearings that work.
W,,,,,,,,,,,,,,,,,,,, is offline Find More Posts by W,,,,,,,,,,,,,,,,,,,,
Old Jan 06, 2012, 03:57 PM
CrazyLittle's Avatar
United States, OH, Brilliant
Joined Sep 2011
Thanks for this. I just discovered one of my DT750's running really rough and it would be great to be able to fix it quickly instead of just junking the part.
CrazyLittle is offline Find More Posts by CrazyLittle
Old Jan 06, 2012, 04:22 PM
Tailwind1's Avatar
Casstown, Ohio
Joined Sep 2010
Thank you Wayne!
Just for kicks, I measured the bearing out of the DT-750, all the measurements line up with the description of the EFLH1215 except the I.D., I came up 3.86mm, they must consider this 4mm I.D.?
Old Jan 06, 2012, 04:33 PM
Grass Valley, CA
Joined Feb 2008
I measure the shaft OD at 3.96mm.
I cannot measure the ID of the old bearing.
Old Jan 06, 2012, 04:38 PM
Destroyer of G-10
askman's Avatar
United States, OR
Joined Jul 2004
newer dts are 4-8-3. older dts are 4-7-2.5s. you can get them at both bocabearing and vxb if you need more than couple.
askman is offline Find More Posts by askman
Old Jan 06, 2012, 04:42 PM
Tailwind1's Avatar
Casstown, Ohio
Joined Sep 2010
Right on! I should have checked the O.D. first. Thanks again!
Old Jan 06, 2012, 04:50 PM
Joined Sep 2011
How old is "older?
Old Jan 06, 2012, 05:03 PM
Tailwind1's Avatar
Casstown, Ohio
Joined Sep 2010
Just ordered a 4 pack of bearings (MR84-UU Radial Bearings) from Boca Bearing, $13.90 including shipping. The 4 pack is not on their web site, but I spoke with a gentleman named "Teddy" and he hooked me up.
Thank you Askman!
Old Jan 06, 2012, 05:05 PM
Tailwind1's Avatar
Casstown, Ohio
Joined Sep 2010
On the subject of DT750 parts, anyone know where to get the set screws that hold the motor into the mount?
Old Jan 06, 2012, 05:10 PM
Joined Sep 2011
Metric 3mm grub screws, aka "M3 x 3" or "M3*3"
Here's M3x4 (slightly longer) for $0.99: http://www.hobbyking.com/hobbyking/s...idProduct=6204
Or, these:
http://www.hobbyking.com/hobbyking/s...dProduct=14127
http://www.hobbyking.com/hobbyking/s...dProduct=14282
http://www.hobbyking.com/hobbyking/s...dProduct=16099
Old Jan 06, 2012, 05:18 PM
Grass Valley, CA
Joined Feb 2008
I swap all my grub screws out for M3x5. The wrench goes in deeper and resists stripping plus the locktite won’t fill up the end if you use too much.
Old Jan 06, 2012, 11:02 PM
Destroyer of G-10
askman's Avatar
United States, OR
Joined Jul 2004
I retapped mine to 6-32, but the originals are 3mm. longer ones work better.
for older ones, I believe the change in bearing happened last year. I have some from 3 years ago and they are all smaller bearing. (and curved magnet instead of flat magnet on the newer ones) I like the newer version because it has thicker tube/bigger bearing. I also like the curved magnet on the older bell though. when my old ones get retired, I will mix and match
Old Jan 07, 2012, 02:32 AM
Joined Sep 2011
Okay, because I was at work when I purchased 2 pairs of 4x8x3 bearings, and didn't have the ability to measure the motor in question.
Old Jan 07, 2012, 03:14 AM
Joined Apr 2011
[img][/img]
caaraa is offline Find More Posts by caaraa
Reply With Quote  (Disabled)
Discussion Hextronic DT750 motor's and high timing? TheZero Multirotor Talk 6 Apr 11, 2012 05:31 AM
Question Has anybody ran a DT750 motor on a 4S battery? Dave8888 Multirotor Talk 6 Feb 18, 2012 04:57 PM
Question What timing to set for DT750 motor Dave8888 Multirotor Talk 1 Dec 06, 2011 01:34 AM
Discussion dt750 replacement motor mounts needed? rcta15 Multirotor Talk 11 Nov 10, 2011 09:29 PM
Wanted HexTronix DT750 Motor bamabaxter Aircraft - Electric - Power Systems (FS/W) 0 Nov 08, 2011 08:11 PM
