Espritmodel.com Heli Air
Old Jan 23, 2013, 06:36 PM
Joined Sep 2006
good tubing cutter
Hey guys I see some of you cut tubing and make your own portholes I have a tubing cutter but it isn't suitable for cutting small rings. I am just wondering what you guys use.
hazegry is offline Find More Posts by hazegry
Old Jan 23, 2013, 06:39 PM
---o-O-o---
blutoh's Avatar
United States, NJ, Livingston
Joined Mar 2012
I use a jeweler's saw.
Pete
blutoh is offline Find More Posts by blutoh
Old Jan 23, 2013, 06:43 PM
tghsmith's Avatar
Raleigh NC
Joined Jul 2008
http://www.micromark.com/tube-cutting-plier,10220.html is one option, but something like this could be made at home.. I had many to cut for a project and put a cut off disc on my harbor freight minni cut off saw.. it worked great..
tghsmith is offline Find More Posts by tghsmith
Old Jan 23, 2013, 06:52 PM
---o-O-o---
blutoh's Avatar
Joined Mar 2012
I usually secure the piece in the panavise, then cut with the jeweler's saw.
Pete
Old Jan 23, 2013, 07:30 PM
Tim Brown
Tim B.'s Avatar
Oakland Ca.
Joined Aug 2009
TG is on it, saw Gravman use this tool to make THIN rings ...
Gotta get one myself next order.
Tim B. is offline Find More Posts by Tim B.
Old Jan 23, 2013, 08:16 PM
One apostrophe may be too many
patmat2350's Avatar
Motor City
Joined Dec 2004
Or turn your portholes on a lathe!
http://www.rcgroups.com/forums/attac...mentid=1686104
patmat2350 is offline Find More Posts by patmat2350
Old Jan 23, 2013, 09:11 PM
Joined Sep 2006
I would love to have a lathe but the cheapest one I have found is 600 and that's a bit much for me at the moment. I am hoping once I get to the ship I can talk to the mr's and get access to the machine shop there.
Old Jan 23, 2013, 09:46 PM
Nickel Belter
ZZ56's Avatar
Northern Ontario
Joined Jun 2009
get a drill bit that fits snugly inside the brass tube and use that as a mandrel to prevent crushing with a conventional tubing cutter.
I use this with styrene tubing to make my portholes.
ZZ56 is online now Find More Posts by ZZ56
Old Jan 23, 2013, 10:02 PM
Joined Sep 2006
great tip zz56 thanks
Old Jan 23, 2013, 10:37 PM
Joined Sep 2006
well I went and tried mine and it just mangled the end still maybe I need a new cutting wheel for it
Old Jan 23, 2013, 11:17 PM
oldtribefan
oldtribefan's Avatar
Walnut Creek, CA
Joined May 2007
Pete
That's the way I do it, too.
oldtribefan is offline Find More Posts by oldtribefan
Old Jan 24, 2013, 12:01 AM
United States, TX, Tomball
Joined Jan 2006
I picked up one of these with a 20% coupon
http://www.harborfreight.com/bench-t...saw-42307.html
Can get pretty thin just have to de-burr once done.
Only limitation is the built in vise is good for a max of ~3/4 inch
mitchlandry is offline Find More Posts by mitchlandry
Old Jan 24, 2013, 12:54 AM
Predreadnut's Avatar
Joined Jul 2007
I was going to get one of those and then I read all the negative reviews..
Predreadnut is online now Find More Posts by Predreadnut
Old Jan 24, 2013, 05:31 AM
tghsmith's Avatar
Raleigh NC
Joined Jul 2008
I have run the crap out of mine with no problems, I did do a bit of filing and cleaning up to make the vise section a little tighter.. when cutting small brass rings the saw blade was replaced with a cut of disc(micromark) about 50 of two different diameters were needed.. had to rig a box around the cutting area to stop the rings from flying away..
Old Jan 24, 2013, 12:16 PM
Olympia WA
Joined Nov 2004
Tghsmith, I also have had mine for many years, bought three extra blades and have never had to change it yet. The box is a great idea, I have been just chasing parts all over the bench. I am going to go out right now and design something. jerryj98501
jerryj98501 is offline Find More Posts by jerryj98501
New Product Good enough boom block / tube holder Rufio Multirotor Talk 38 Apr 19, 2013 01:37 PM
Sold K&S Tubing Cutter paysonhobbies Aircraft - General - Miscellaneous (FS/W) 2 Jun 06, 2011 07:06 AM
Tube Cutter / Balsa Cutter Gunny Aircraft - Sailplanes (FS/W) 0 Mar 20, 2004 03:07 AM
Perfect Groove "Cutter" for CF tubes Model Aero 3D Flying 2 Feb 09, 2004 04:26 PM
Perfect Groove "Cutter" for CF Tubes Model Aero Foamies (Kits) 9 Feb 08, 2004 09:47 PM
