Go Back   RC Groups > Regional Forums > South Africa
Old Oct 19, 2007, 05:44 AM   #16
spacey's Avatar
Thanks Aragon, I'll look into it! Kinda keen to get this thing on the bench soon...the whole deal is still a mountain in front of me though.
spacey is offline Find More Posts by spacey   Reply With Quote
Old Dec 12, 2007, 01:50 AM   #17
loamy foamie
Drusky's Avatar
Ziggx has found a Goop alternative made by Alcolin:
Originally Posted by Ziggx
...Went to the local hardware to day and found a new product by alcolin. The product is called Ms 37.
http://www.alcolin.com/data_sheet.asp?id=170
It is clear and remains elastic. (Sole save is not so elastic but I have found that the dents pull out with heat)
Is paintable so it is not a silicone.
280 ml tube R75.00
Drusky is offline Find More Posts by Drusky   Reply With Quote
Old Dec 12, 2007, 07:43 AM   #18
bruceswd's Avatar
EPP in SA
Hi guys
What do you use as an EPP replacement and can I get it in CT ?
Bruce
bruceswd is offline Find More Posts by bruceswd   Reply With Quote
Old Dec 12, 2007, 07:53 AM   #19
spacey's Avatar
I don't think such a thing exists. Not yet anyways.
Old Dec 12, 2007, 08:00 AM   #20
bruceswd's Avatar
Thanks Spacey...
Another question... Scuse my ingnorance, I'm new to building... What is CA ???
Old Dec 12, 2007, 08:10 AM   #21
CA = Cyanocrylate
ie. super glue
Drusky, I'll try test that MS37 sometime and compare it to my genuine Goop. I noticed it doesn't have any solvents so should be interesting to compare...
aragon is offline Find More Posts by aragon   Reply With Quote
Old Dec 12, 2007, 08:12 AM   #22
spacey's Avatar
Cyanocrylate...not sure of the spelling. Super glue for the most part but I think this is the original patented pure form/name for the stuff. In a puny useless off the shelf in Pick&Pay brand super glue tube there will be CA, and maybe some other nonsense.
Old Feb 11, 2008, 06:19 PM   #23
goop
If you are looking for orignal goop.
You can use a Zap product called Zap a dap goo. I think it is called.
Cheers
Dion
ziggx is offline Find More Posts by ziggx   Reply With Quote
Old Feb 20, 2008, 01:50 AM   #24
loamy foamie
Drusky's Avatar
Is the Zap a dap goo a South African product Dion?
Old May 17, 2008, 06:03 PM   #25
Chris (aka Woodstock)
cvanscho's Avatar
I doubt it, as it seems to be feely available in the UK....
Chris
cvanscho is offline Find More Posts by cvanscho   Reply With Quote
Old Feb 13, 2009, 08:02 AM   #26
All this adhesive and covering stuff is cool, but I want to know where we can get EPP in SA?
I'm keen to design and cut a few models rather than just import kits.
Anyone know of a source of EPP?
Internut is offline Find More Posts by Internut   Reply With Quote
Old Feb 13, 2009, 08:31 AM   #27
There are no EPP sources in SA. The best alternative is extruded polystyrene from isoboard.
Old Feb 13, 2009, 02:16 PM   #28
Try MAD models in Johannesburg for depron and EPP. The only problem is that it is expensive to ship and expect to pay around R100 a sheet. When the shops get depron or EPP in stock, they are usually sold out in days. So when I find the stuff, I buy in bulk!
I use hot glue when I work with depron or EPP. Way better than Cyano or Epoxy. Hot glue is firm, yet rubbery enough to bend with the plane when you prang it. The best is that you dont have to wait for it to dry!!
snarf007 is offline Find More Posts by snarf007   Reply With Quote
Old Jun 01, 2009, 03:07 AM   #29
loamy foamie
Drusky's Avatar
EPP available from Automa Multi Styrene. Talk to Eli Silberg. www.automa.co.za
Old Jul 13, 2009, 07:10 PM
Agapitos
An infraction has been given for this post.  Infraction type: Excessive advertising (Spam)
Discussion Plan for "Prop in a slot" profile Epp jet model ? dekan Pusher Prop Jet Models 0 Jul 11, 2007 02:36 PM
Discussion Building F3P with EPP? They do in Japan. dawsonh Indoor Pattern/F3P 39 Dec 25, 2006 06:07 PM
go halves on leg model in the uk southern soarer uk Slope 5 Sep 06, 2005 12:50 PM
EPP 3D model Needed in UK CHEF-UK 3D Flying 11 Aug 02, 2005 01:23 AM
Which model in "Endless LIft"? jschrader Electric Sailplanes 13 Jul 02, 2001 06:25 AM
Bored? Want to fight?
Join the RCGroups clan!
