Old Jul 24, 2015, 05:07 PM
acesimmer is online now
Find More Posts by acesimmer
acesimmer's Avatar
United States, NV, Fernley
Joined Oct 2011
More work on V2 and V3 between building the A6. Retract box built for V3 and ready to install. Canards for both V2 and V3 built and ready from new molds. V3 parts build is complete and ready for assembly next month.
V2 is in the shop to have battle damage repaired and also get all the new updates. Monday V2 gets a whole new nose then have it grafted to the rear fuselage. I am so glad that I took the time to make multi-part molds. It allows me to repair any section of the Euro without loosing the entire aircraft.
More to come next week........
acesimmer is online now Find More Posts by acesimmer
Old Jul 27, 2015, 03:14 PM
acesimmer's Avatar
Joined Oct 2011
Repairs are almost completed on V2. Due to the paint thickness it doesn't quite fit the molds perfectly. So I added a couple of levers to push it into place. I also added magnets inside and out to help pull the skin into the molds.
When I repaired V1 this way I laid up the cloth the normal way which is resin coat then buildup with cloth. I had a little under bleed of the thin resin between the mold surface and the outer skin of the jet. This time I did the above and first applied a bead of thickened goop to create a barrier between the outer skin and mold. Hopefully the resin will not bleed so much.
I then laid up 3/4 oz, 2 oz and finished with 6 oz cloth which is the same schedule like the original. This will be enough to fix the breakage and I'll add more cloth across the seam when joining front to back. I also laid up the nose section. I'll join the front and back tomorrow morning.
Old Jul 29, 2015, 04:35 PM
acesimmer's Avatar
Joined Oct 2011
V2 is all repaired. Just waiting for some laser cut repair parts to finish building it out. I'm thinking to change the color to the Battle of Britain memorial version. I'm also repairing some crash crease damage to the wings. So with all the effort I may as well just change the color.
I'll get Calli to cut two sets so that I have an option to do a super detailed V3 in same scheme.
Old Jul 29, 2015, 04:44 PM
Tumbler is offline
Find More Posts by Tumbler
Tumbler's Avatar
New Jersey
Joined Feb 2003
Awesome!
Tumbler is offline Find More Posts by Tumbler
Old Jul 30, 2015, 02:37 AM
shoey is online now
Find More Posts by shoey
shoey's Avatar
Australia, SA, Adelaide
Joined Jan 2009
Great recovery Ace! Impressive how you can use the mould to repair like that. Nice one
shoey is online now Find More Posts by shoey
Old Jul 30, 2015, 04:19 PM
Dmerino is offline
Find More Posts by Dmerino
Pollock Pines, CA
Joined Aug 2002
Incredible job, Ace....................... Damn, you "Brits" are good.
Den
Dmerino is offline Find More Posts by Dmerino
Old Jul 30, 2015, 10:04 PM
acesimmer's Avatar
Joined Oct 2011
Thanks lads
Den.... You nailed that one. Yes, we brits are good... laugh.
LasercuttingbyJohn just dropped off the replacement parts for V2. So now I can move ahead. I have repaired the surface creases in the wings but will have to redo the rivets. Kind of hard to fix with a few thousand rivets on the wings.
I also got the final canopy for the A6 ready for layup. Maybe tomorrow. The weather just got super hot once again and driving me out of the shop by 10am.
Today I received some new high voltage batteries. I thought to try out the new Turnigy Bolts. Instead of 5000 packs these are 5400 and a few grams lighter. Hopefully I can get a little more poop and a little longer flying time. If not then its time to go 7 or 8S per side. I designed in the capability for four 6S packs if needed. I just like the way it flys on 6S x 2. Very docile
Build Log Scratch Build Composite UAS System parri0923 UAV - Unmanned Aerial Vehicles 8 Jun 16, 2015 03:33 AM
Discussion Looking for a composite lightweight 90mm jet? firehawkzach Electric Ducted Fan Jet Talk 21 Jan 25, 2013 06:26 PM
Discussion Scratch Build RQ-7 Shadow Composite/Balsa parri0923 Balsa Builders 2 Jan 17, 2013 04:17 PM
Sold Stearman PT-17 scratch-build from Barron's Scale Classics Plans 1/6th Scale spitfire1999 Aircraft - Fuel - Airplanes (FS/W) 5 Jan 06, 2013 10:01 PM
Discussion Euro Fighter Typhoon scratch built for 90mm fan Lboogie Electric Ducted Fan Jet Talk 56 Jul 22, 2009 12:59 PM
