Old Nov 23, 2015, 12:33 AM
MT3003 is offline
Find More Posts by MT3003
Joined Dec 2012
Available: Pixhawk Lite firmware supporting audio signals (passive & active)
The existing Pixhawk Lite (PHL) board does not provide any standard audio signaling output or buzzer support via the regularly released ArduCopter firmware.
APM:Copter V3.3.2-rc2-lw-rc1 is a custom version of APM:Copter (based on Arducopter V3.3.2-r2) which provides support (via Pixhawk Lite pins AUX1 through AUX6) for both passive audio devices (e.g. passive piezos that can play arbitrary tones) and active audio devices (e.g. buzzers that play a fixed tone).
Full info at:
Signaling melodies/patterns are separately optimized for passive and active audio devices, rather than duplicating Pixhawk "standard" tone sequences. The type of audio device installed is specified via a settable parameter.
Melodies (for passive piezos) and buzz sequences (for active devices, e.g. buzzers) are provided for the following events:
System initialization
Prearm fail
Prearm OK
GPS 2d lock
GPS 3d lock
GPS dgps lock
Loss of GPS lock
RC status change (transmitter on/off)
Lost flyer
The user can enable and disable the audio signaling, indicate whether they are using a passive or active audio device, select the AUX pin number to be used for the audio device, indicate whether the audio device has a "low" or "high" logic level off (silent) state, and choose a "limited audio signaling" mode with fewer audio signals if desired.
MT3003 is offline Find More Posts by MT3003
Question In Cleanflight, any way to set it up so buzzer activates if RX loses signal? Wayno-san Multirotor Talk 6 Sep 29, 2015 05:39 PM
Article Active and Passive Alarms Review DismayingObservation Electric Plane Talk 24 Jul 11, 2012 05:09 PM
Discussion PIXHAWK pxIMU v.2.5 Open-Source IMU now available! pixhawk UAV - Unmanned Aerial Vehicles 4 Apr 30, 2011 04:47 AM
Discussion Passive Sonar and Signal Processing mj_ Submarines 3 Apr 09, 2011 06:17 AM
Question Passive signal radiator for 2.4 Ghz? Accu157 Radios 1 Jun 09, 2009 02:49 AM
