Old Apr 08, 2015, 03:40 PM
parajared is offline
Find More Posts by parajared
helis, boats, cars and planes
parajared's Avatar
United States, AZ, Prescott
Joined Oct 2013
overwatting but not overamping, what happens?
What happens when you overwatt a brushless motor but are well below the max amperage specs?
I am planning on using 6s and propping the plane to draw 40 amps on a motor rated for 500watts and 50 amps. In other words I am supplying 880watts to a 500 watt motor.
parajared is offline Find More Posts by parajared
Old Apr 08, 2015, 03:43 PM
Mad_Mike is online now
Find More Posts by Mad_Mike
Be safe son - Fly low and slow
Mad_Mike's Avatar
Canada, ON, Lyn
Joined Feb 2015
You can't get there from here.
If you limit the current, the voltage will drop, and the power will drop as well.
Mad_Mike is online now Find More Posts by Mad_Mike
Old Apr 08, 2015, 03:53 PM
parajared's Avatar
Joined Oct 2013
Its my understanding that larger gauge copper can carry more current. If the copper is large enough to handle the current (or shall I say amperage) that I am supplying why would extra voltage be a problem? Does high voltage heat things up somehow too?
Old Apr 08, 2015, 04:06 PM
parajared's Avatar
Joined Oct 2013
Maybe to put it more simply, why do manufacturers label their motors with both an amperage and a wattage limit? Why don't they just put max amperage in the specs?
Old Apr 08, 2015, 04:36 PM
Mad_Mike's Avatar
Canada, ON, Lyn
Joined Feb 2015
Voltage and current go hand in hand. More voltage results in more current.
I think they specify a maximum current.
And specify a rated power(wattage) that you can expect.
And specify a recommended voltage (1S, 2S, 3S etc.)
It's all just information, there are things beyond their control. If you change prop, weight, wing area, etc. it affects motor load.
Don't exceed the max. current and you won't burn out the motor(probably).
If you get it all right, you extract the most efficiency out of the system.
Old Apr 08, 2015, 04:46 PM
slipstick is offline
Find More Posts by slipstick
Staffs, UK
Joined Nov 2003
Without knowing WHAT motor you're talking about and WHAT you're using it in here are a few guesses:
Basically you're planning on using twice the voltage that's specified. So you're turning the motor twice as fast as the maximum rpm it's designed for and using a very small prop to keep the current down. So because of the small prop you won't have very much static thrust but you will have a ridiculously high pitch speed.
It's possible the plane will still fly in some fashion. And the motor might still hang together even if you are abusing it but then again the excessive rpms might cause it to throw the magnets or the bearings might seize up or it might just get very hot and melt the windings.
Good luck testing it .
Steve
slipstick is offline Find More Posts by slipstick
Old Apr 08, 2015, 05:20 PM
Lnagel is offline
Find More Posts by Lnagel
Senile Member
Lnagel's Avatar
Moab, Utah, USA
Joined Apr 2003
It's quite simple. The amount of heat generated by the motor has to be taken into consideration. Let's be conservative and say the motor is operating at 80% efficiency. At the max power rating of 500 watts the motor will have to dissipate 100 watts of heat. When running the motor at 880 watts, even though the current is under the max current rating, the motor will still have to dissipate 176 watts of heat. Are you willing to take the chance?
Larry
Lnagel is offline Find More Posts by Lnagel
Old Apr 08, 2015, 05:26 PM
parajared's Avatar
Joined Oct 2013
ah, ok that makes sense. I knew there was a reason
Old Apr 08, 2015, 06:24 PM
balsa or carbon is offline
Find More Posts by balsa or carbon
Hot glue held together by foam
United States, WA, Vancouver
Joined Aug 2010
My question is .....WHY ?
What result do you want , and why not acquire and use what you need to get that result ?
balsa or carbon is offline Find More Posts by balsa or carbon
Old Apr 08, 2015, 07:18 PM
parajared's Avatar
Joined Oct 2013
I want to build a non-edf high speed jet. I am thinking either skyfun or funjet. Instead of buying a new motor I am considering using a motor that I have lying around from a previous attempt to make a Tek Sumo go really fast, a NTM propdrive 1400kv 500watt.
I think 800+ watts could scoot a funjet along at a respectable speed.
Old Apr 08, 2015, 08:30 PM
Joined Aug 2010
You haven't mentioned prop selection - for more speed , use a prop with higher pitch .
And instead of jumping to 6S right away , you might want to work your way up to 6S ( first 4S , then 5S , then 6S ) , checking motor/ESC temp each time .
My personal experience with trying something similar to this was a toasted motor , and the specs for the motor indicated it could handle 5S . In the video , you can hear the motor self destruct at about 2:40 .
Simple Dollar Tree Jet on 5s battery (4 min 13 sec)
Old Apr 08, 2015, 10:05 PM
Glacier Girl is offline
Find More Posts by Glacier Girl
Kamikaze Ace
Glacier Girl's Avatar
USA, FL, Lakeland
Joined Jan 2010
Motor quality will have a lot to do with it too.
I used to fly some stupid fast Strykers, running 50+ amps through a 23 amp rated motor.
But then I was using a Mega motor. High quality motors and you paid for it.
NEVER had a motor electrical failure.
With something like what you are planning on using, I don't see the same happening.
But you never know till you try.
And if it wasn't for folks pushing the limits, we'd never know what something will do.
Glacier Girl is offline Find More Posts by Glacier Girl
Old Apr 08, 2015, 11:36 PM
dacaur is offline
Find More Posts by dacaur
Heli's rule!
dacaur's Avatar
Midvale, Utah, USA
Joined Mar 2005
Part of a motors voltage rating has to do with bearings. If the mfg specs bearings good for 20k rpm, and you run it at 30krpm, bad things are bound to happen....
dacaur is offline Find More Posts by dacaur
Old Apr 08, 2015, 11:58 PM
Hussle is offline
Find More Posts by Hussle
Joined Apr 2015
Larry
Ah but inefficiency from ohmic heating is P=RI^2, so heating is proportional to current squared (as resistance is constant). So the limit to burning your motor out is to do with current, not wattage. The ohmic heating melts the insulation on your coils and the motor shorts out. You get more efficiency by increasing the voltage and hence decreasing the current (V is inversely proportional to current) because inefficiency is dependent on current. That's why high voltage power lines are used to shift electricity from the generator to the substation. Over that long distance, so much energy is saved by minimising current.
I think slipstick may have it right in that the power limit given by the manufacturer may be effectively an rpm limit, simply in an easily measurable form.
Hussle is offline Find More Posts by Hussle
Old Apr 09, 2015, 12:28 PM
Tepid Pilot is offline
Find More Posts by Tepid Pilot
Built For Comfort
Tepid Pilot's Avatar
South Central Texas
Joined Aug 2009
It's your money.
TP
Tepid Pilot is offline Find More Posts by Tepid Pilot
Careful! What happens when your ESC timing mode does not like your high KV motor TheLeabres Power Systems 7 Nov 26, 2014 08:17 AM
Discussion Not really sure what happened CD10390 3D Electric Heli Flying 13 Jul 17, 2014 12:42 AM
Discussion horizontal stabilizer-wing alignment not perfect. What happens? FloBau Electric Plane Talk 33 May 29, 2014 04:32 PM
Help! first build crash - not sure what happened... andElectrons Multirotor Talk 47 Apr 26, 2014 09:19 PM
Bug Not sure what happened, but.... Kmot Site Suggestions / Complaints 4 Sep 20, 2010 12:39 PM
