Old Apr 14, 2015, 03:11 PM
Mr.frankenjet is offline
Find More Posts by Mr.frankenjet
eat, sleep, FLY FLY FLY
Mr.frankenjet's Avatar
Charlottesville, VA
Joined Jun 2005
Originally Posted by paladin-34 View Post
frank, I accomplished this by putting a second set screw behind the factory set screw. I picked the second set screw so it stuck out of the hole, prairie dogged if you will. once all was tight I carefully loc-tited the prairie dog. getting none in the gear trunion or the allen.
the reason for this is the size of the allen with loc-tite the wrench will strip. so if I have to remove it I can dremel flats on both sides to remove it.
between my fw190, me109, and son's me109 we have close to 300 flights with no problems from a loose strut. we have the mechanism come unscrewed from the plate that is screwed to the wing.
Good luck
Joe
thanks Joel,
If my patch does not hold I'll try your fix, thanks again
Mr.frankenjet is offline Find More Posts by Mr.frankenjet
Old Apr 15, 2015, 07:45 PM
baddley is offline
Find More Posts by baddley
United States, WV, Salem
Joined Mar 2006
Hi
I have finally got around to finishing this bird up. When balancing with retracts, I want the bird slightly noise heavy with the retracts up and at about neutral with them down is this correct ?
Also the only way to get my cg is with my battery all the way forward on the top shelf tray. Is there a better method besides using double sided Velcro and stuffing some foam in there to make it tight ?
Scott
baddley is offline Find More Posts by baddley
Old Apr 16, 2015, 01:49 AM
dambit is offline
Find More Posts by dambit
Most people are stupid!
dambit's Avatar
Australia, QLD, Gold Coast
Joined Oct 2011
There probably is a better way, but not an easier one. ; )
You could get a bigger battery.
dambit is offline Find More Posts by dambit
Old Apr 16, 2015, 07:37 AM
Charlottesville, VA
Joined Jun 2005
I'm going to glue some foam blocks on both sides of the fuse to center it, just have not gotten around to it. I think that and a more forward Velcro strap will keep it secure
Discussion FMS 1400mm FW-190 Owners Thread Orion Pax Electric Warbirds 6988 Apr 02, 2015 09:31 AM
Discussion fms warbird owners thread warbird_cowboy Electric Warbirds 126 Mar 11, 2015 08:13 PM
New Product GAUI 500x/ GU-INS GPS Owners Thread - Tips, Problems And Experiences sap_2000 Multirotor Talk 231 Aug 05, 2014 04:32 AM
New Product FMS Messerschmitt Bf109F 1400mm Beltpilot Electric Warbirds 1299 Mar 30, 2013 09:24 AM
Poll Choose the paintscheme of the new FMS GIANT Bf109F Beltpilot Electric Warbirds 41 May 31, 2010 05:44 AM
