Old Jan 18, 2015, 03:55 PM
Thread Crapper
JohnVH's Avatar
Lynden, WA
Joined Nov 2000
Ladybird is 7mm motors and works fine.
JohnVH is online now Find More Posts by JohnVH
Old Jan 18, 2015, 04:19 PM
Antisocial Curmudgeon
Fyathyrio's Avatar
United States, CA, San Diego
Joined Sep 2013
I think you're asking if the FC can handle a 500mah battery? If so, yes, mah does not matter to the FC as it'll only draw what's required. You could run a 5000mah battery if your setup could lift it.
Fyathyrio is offline Find More Posts by Fyathyrio
Latest blog entry: LED lighting for living spaces
Old Jan 18, 2015, 04:43 PM
JIMJAM's Avatar
Columbia, South Carolina, United States
Joined Feb 2000
No , its the total weight and the draw from the 7mm motors on a board designed for the light Nano with 6mm motors I am concerned about.
Can the board handle it and if so is it within its limits or is it pushing it? If its putting a strain on it I will then decide to either order a spare or seriously consider moving up to maybe the 180.
JIMJAM is online now Find More Posts by JIMJAM
Old Jan 18, 2015, 05:09 PM
Team WarpSquad
Daryoon's Avatar
San Diego, CA
Joined Dec 2010
The NQX with 7mm direct drive is a totally different quad than a 180QX with it's gear driven props.
I feel the NQX with 7mm will have the speed to play outside in the wind. And retain the characteristics of the Stock NQX.
However, the 180QX BNf is on sale right now right? HH likely going to discontinue that quad.
Daryoon is online now Find More Posts by Daryoon
Old Jan 23, 2015, 11:55 AM
Thread Crapper
JohnVH's Avatar
Lynden, WA
Joined Nov 2000
the beast in action, and a couple crashes, haha
Pico FPV on a Walkera Ladybird V2, Blade NanoQX Flight Controller (4 min 4 sec)
Old Jan 23, 2015, 12:23 PM
Joined Feb 2008
https://www.youtube.com/watch?v=NHxM...ature=youtu.be
Nice video! What kind of range and battery life are you getting?
Zoide is online now Find More Posts by Zoide
Old Jan 23, 2015, 12:31 PM
Thread Crapper
JohnVH's Avatar
Lynden, WA
Joined Nov 2000
Thanks, I get over 5min of hovering on a 300mah battery, going to try 500-800mah packs in the future. Range, The last crash was about 600' away, I think the battery dumped on me, the weather has been too poor to go for another range run on a fresh charge, so Ill update with that info soon. I know the video system goes beyond 2000' very easy
Old Jan 23, 2015, 02:28 PM
Joined Feb 2008
Wow! Could you please share some more information about the build (components, etc.)?
Old Jan 23, 2015, 02:34 PM
Thread Crapper
JohnVH's Avatar
Lynden, WA
Joined Nov 2000
I already had a nanoqx I wasnt flying, but other than that its just the $49 ladybird V2, RMRC Pico FPV setup, 1.3G (thats why the range issues for me, 5.8G probably wouldnt have the same issues and wouldnt NEED the nqx FC, I only did because 1.3G made the devo4 range go to null)
Ill get some more details pics later. Hover time stock with no fpv gear is over 7 min
Old Jan 23, 2015, 03:20 PM
United States, FL, Melbourne
Joined Mar 2012
I have that same problem. My 1.2g slaughters my Lemon/Devo/DSM setup. I've installed a 5-minute Notch filter, and it helps, but just barely.
cyberbillp is offline Find More Posts by cyberbillp
Old Yesterday, 03:25 AM
Joined Nov 2014
I just built a 100mm woods turning nano qx fc quad. I'm getting a constant beep under throttle (at all throttle levels it seems). I don't believe it is coming from the motors, instead from the fc itself. The quad seems to fly ok, but it seems underpowered. It has the stock nano qx motors. The battery connector attachment is covered by some white gunk that looks like elmers glue. What is that? I did the quick and dirty wire to wire solder method to change to a losi connector. Maybe the beeping has something to do with power?
IntoTheFlyer is offline Find More Posts by IntoTheFlyer
Old Yesterday, 04:06 PM
Joined Nov 2014
I got help over on another thread:
http://www.rcgroups.com/forums/showt...36987&page=154
If anybody has anything to add, head on over. Otherwise, no need to further clutter up this thread with my newbiness.
Discussion Whats a good FC board for quad copter? bigheaded5 Multirotor Electronics 1 Mar 27, 2013 07:06 PM
Discussion Blade MQX or Walkera QR Ladybird. RaymondM Multirotor Talk 2 Jun 27, 2012 11:10 AM
Discussion Walkera Ladybird vs Blade MQx Thetis Multirotor Talk 13 Jun 19, 2012 10:37 PM
Video Blade mQX on-board video Mike_Then Electric Plane Talk 4 Mar 27, 2012 05:16 PM
Sold Complete quad copter needs fc board $90.00 shipped thefokker Aircraft - Electric - Multirotor (FS/W) 2 Oct 06, 2011 10:36 AM
