Old Jan 19, 2015, 06:23 PM
MisterVikter's Avatar
Australia, NSW, Sydney
Joined Oct 2013
Originally Posted by Stringer View Post
Good flying! The 6x4.5 is way a lot better than any of the 5" or the 6x3.
Cheers man! Yep, there is no turning back from 6x4.5 if your setup can run it. Can't wait to get more props so I can tune out the wobbles!
MisterVikter is offline Find More Posts by MisterVikter
Old Jan 23, 2015, 09:08 PM
Su-27's Rule!
Su-33's Avatar
Philippines, NCR, Pasig City
Joined Nov 2012
Anybody interested in a naze 32 (full/with baro and magnetometer)here in the Philippines? PM me
Su-33 is online now Find More Posts by Su-33
Latest blog entry: A cheap way to measure Kv
Old Jan 24, 2015, 09:57 PM
Philippines, NCR, QC
Joined Apr 2014
Not happy with it or is it an extra?
alexraz is offline Find More Posts by alexraz
Old Jan 25, 2015, 10:19 AM
Su-27's Rule!
Su-33's Avatar
Joined Nov 2012
bnew extra, i'm so happy with the naze 32 just literally plug and fly
Old Jan 26, 2015, 08:47 PM
Joined Apr 2014
Question:
When we increase the throttle, does the voltage increase or the amps?
Old Jan 26, 2015, 10:00 PM
Philippines, Calabarzon, San Pedro
Joined Jul 2012
Amps i guess. I know that if you draw too much current, the voltage will drop. Consequently, the lower the voltage the more current you'll need to power the ESC so you end up with things getting hotter.
Hajile is online now Find More Posts by Hajile
Old Jan 26, 2015, 10:55 PM
Joined Apr 2014
I see. This is good info.
Would you say that this works somewhat in a similar fashion where in it controls the amount of amps that come from the batt and goes to the motors?
I'm using what I learn from RC in building a wind and solar power grid tied system and I need to control the amount of amps (or watts) that goes to the grid tie inverter.
Old Jan 26, 2015, 11:16 PM
Su-27's Rule!
Su-33's Avatar
Joined Nov 2012
actually i think same voltage just at shorter pulses so RMS voltage becomes lower volts on average.
Old Jan 26, 2015, 11:33 PM
Defies Logic & Common Sense
speedactyl's Avatar
Philippines, NCR, Makati City
Joined Jun 2012
Guys what do you think for a all around stable airframe
for light weight application
two of which are in the works.
900mm wing and 1200mm Glider.
as for the glider my bet is to lift an action cam and a small fpv gear. with a fraction of the Power
requirements of similar size planes.
speedactyl is online now Find More Posts by speedactyl
Old Jan 26, 2015, 11:38 PM
Joined Apr 2014
Oh... I was hoping there was a device that can vary the amperage from a DC source to a load but maintain the same voltage output.
Old Yesterday, 12:55 AM
Joined Jul 2012
I've seen one on the workbench of RCModelReviews but it's huge and meant for troubleshooting. Maybe there's a smaller version.
Old Yesterday, 01:44 AM
Su-27's Rule!
Su-33's Avatar
Joined Nov 2012
alex, Amps is determined by the load not by the ESCs, brushless or brushed..
yes as Halile that's a desktop dc power supply that can LIMIT the amount of amps in order not to destroy the circuitry if there was a short.
Those things are usually expensive and have low amps, look for PC PSU although no limit on amps if you have a short circuit it would just blow the PSU up :P
In most applications the voltage is varied to control speed or brightness (if light emitting) but those can also vary the amps imagine it like this _-_-_-_-_-_-_-_ the "minus" is .5 volts and the underscore is 0.0 v avarage voltage would be .25V amps only half of full .5 v (because half the time it's " off")
Old Yesterday, 09:44 AM
Joined Apr 2014
Great explanation!
So it's like turning the power on and off very very fast. That would likely burn the grid tie inverter and probably my house. I have to rethink the system design.
Thanks guys. I knew I could count on your tech/engineering knowledge. This forum is the best!
Old Yesterday, 10:32 PM
Su-27's Rule!
Su-33's Avatar
Joined Nov 2012
welcome alex anytime
Discussion RC flying in the Philippines neoradix 3D Fuel Heli Flying 22 Dec 20, 2014 08:54 PM
Discussion Philippine Aerial Photos mykmaspogi Aerial Photography 16 Aug 18, 2012 02:06 PM
Discussion Our Flying Field (Philippines) mykmaspogi Your Plane Photos 3 Aug 20, 2008 04:28 PM
Question RC Frequency Band in the philippines athrun4211 Radios 1 Apr 21, 2008 11:47 AM
Flying field in Manila, Philippines??? Any one? Butch777 Electric Plane Talk 2 Sep 26, 2004 09:14 AM
