Old Jun 18, 2015, 03:20 PM
Megalite is offline
Find More Posts by Megalite
Joined Apr 2013
Help!
UMX F4U Corsair loses connection?
On my maiden flight I tested that everything worked the flaps etc... When it got in the air it flew fine for 15 seconds and after flying for about 15 seconds in it was around 30 feet away and it just lost connection and fell to the ground. I broke a wing and the tail but I fixed those with some tape.
​On my second attempt yesterday I took it out and tested everything again and once it was around 6 feet away it just lost connection every single time and would become 2-3 feet airborne and fall.
​Today I tested it out and I noticed that it works only about 6 feet away from my transmitter that I got with the Corsair. Once it goes more than 6 feet away it will just lose connection and it will go full speed and wont respond to anything until i bring it back in the 6 feet range.
If someone could help a newbie out on how to fix this, please
Megalite is offline Find More Posts by Megalite
Old Jun 18, 2015, 03:57 PM
timmybeetle is offline
Find More Posts by timmybeetle
No Guts, No Glory
timmybeetle's Avatar
Nederland, LI, Helden
Joined Sep 2010
Range Check XMTR / RCVR
Range Check
When you are new too this hobby you better go to a flying club for help.
You have to perform always a range check with yours gear.
If not than you get yours experience..
grts Hans
timmybeetle is offline Find More Posts by timmybeetle
Old Jun 18, 2015, 04:09 PM
Megalite is offline
Joined Apr 2013
Originally Posted by timmybeetle View Post
Range Check
You have to perofrm always a range check with yours gear.
grts Hans
I flew it in a range of maybe 30-40m in the 15 seconds that it actually did fly which I doubt is the flying range.
Old Jun 18, 2015, 04:21 PM
No Guts, No Glory
Joined Sep 2010
If you want help and advise
Hello
A xmtr should have a range between 1000-1500 meters....
Good luck
grts
Old Jun 18, 2015, 04:45 PM
Megalite is offline
Joined Apr 2013
Hello
Good luck
grts
Apparently its a antenna problem, going to have to call Horizon Hobby.
Old Jun 18, 2015, 06:08 PM
JonCM is online now
Find More Posts by JonCM
Joined Aug 2014
check to make sure your transmitter is not in range test mode. if it is in range test mode what you will see is losing connection at very short distance.
a lot of low end transmitter have dead spots if you point the tip of the antenna right at the model.
JonCM is online now Find More Posts by JonCM
Old Jun 21, 2015, 01:34 AM
Megalite is offline
Joined Apr 2013
How do I check if its in range test mode? The transmitter is pretty basic not too many fancy controls and really didn't see any other buttons on it.
Old Jun 21, 2015, 08:16 AM
JonCM is online now
Joined Aug 2014
without knowing which tx you have its kinda hard to say
Old Jun 23, 2015, 02:42 AM
Megalite is offline
Joined Apr 2013
2.4gHz 4-channel DSMX transmitter
Old Jun 23, 2015, 06:43 AM
JonCM is online now
Joined Aug 2014
What brand and model number
Old Jun 28, 2015, 05:01 PM
Megalite is offline
Joined Apr 2013
I'll check and post here ASAP.
New Product E-Flite UMX F4U Corsair BNF w/ AS3X ChuckTseeker Micro Ready-to-Fly 531 Jun 28, 2015 08:30 AM
Wanted UMX Corsair F4U Wing marblekit Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 1 Jun 09, 2015 10:30 PM
Sold UMX F4U Corsair BNF with AS3X dizzane Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 1 Jun 08, 2015 10:02 PM
Help! What battery should I get for my E-flite UMX F4U Corsair Megalite Batteries and Chargers 4 Jun 08, 2015 12:22 PM
Sold Brand New UMX F4U Corsair BnF vacahtu Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 3 Jun 01, 2015 10:50 PM
