Old Oct 20, 2014, 08:08 PM
United States, VA, Harrisonburg
Joined Oct 2014
Data
Phantom 2 Central Board Schematic
Had my Phantom 2 central board die on me while looking into the battery pack communication, so instead of binning it, I figured I'd at least get some useful info from it for any future repairs or projects that I or anyone else may get into with this thing.
New PCB for comparison.
Top of the PCB with all components removed. (bottom side has no components)
How I've laid out the component designators.
PCB stripped (50%) overlay on original scan, to double check the top layer tracing. NOTE: The PCB is 4 layers, so not all of the traces can be seen.
..and BGA connections used, which is less than half, only 43 out of 100.
Lo resolution version of the schematic. Hi Resolution version is attached. (Note the GPS and Compass are not done, only shown as modules.) I may do the ESC later, but that will go into the Phantom 2 ESC thread.
CONNECTORS
SMB 2 pin, COMP 5 pin, CAM 6 pin, ZENMUSE 8 pin - Molex PicoBlade 51021
ESC 4 pin, CAN 4 pin, EXP 6 pin - JST GHR-xxV-S Series
CAN Connectors (Accessories) - Molex Micro-Fit 3.0 43640 - 43645
RDCF550 is offline Find More Posts by RDCF550
Old Oct 25, 2014, 09:42 AM
pawelsky's Avatar
Polska
Joined Jan 2012
Nice work, is that a 2 or more layer board?
pawelsky is offline Find More Posts by pawelsky
Old Oct 25, 2014, 09:56 AM
Joined Oct 2014
Thanks. I haven't stripped it down to verify, but from what I see it's just a 4 layer PCB. Top, Inner 1, Inner 2 and Bottom.
Old Nov 01, 2014, 01:17 PM
Joined Oct 2014
You sir, are The Man! Thank you for putting this info together!
SeeTeeZee is offline Find More Posts by SeeTeeZee
Old Nov 26, 2014, 04:47 PM
Joined Apr 2007
Thanks!
Thanks so much for posting this. Saved me a bunch of time. I replaced my ZenMuse cable. I got a bad one that was shorted. Blew Q2. Thanks to these pics and schematic, I was able to identify the blown part. New one on order. $3.62 for 10 of them I'm sure I can use them in other projects around here.
Through the microscope.
-Craig
cw76 is offline Find More Posts by cw76
Old Nov 26, 2014, 05:21 PM
Joined Oct 2014
Welcome, but that's Q1, not Q2. Typo?
Q1 is the SOIC8 you've had nuke there, an AO4407A, which is also half of the 3 pair of FETs that are used on the ESC boards. If you pick up some of the other half of those, the AO4430, you'll be able to repair some ESCs as the FETs are all I've seen go bad on them so far, aside from mechanical damage when an arm bends or breaks.
Old Nov 27, 2014, 07:29 PM
Canada, BC, Castlegar
Joined May 2014
Thanx for this . Great stuff . It doesn't surprise me about the FETs blowing as they did . Typical .
RickC_RCAV8R is offline Find More Posts by RickC_RCAV8R
Latest blog entry: RIX V22 Osprey Fuselage : Part3
Sold Phantom 2 controller with main board fronnie Aircraft - Electric - Multirotor (FS/W) 3 Oct 20, 2014 03:12 PM
Sold DJI Phantom 2 power board (does not power flight controller) For parts or repair. Lroc130 Aircraft - Electric - Multirotor (FS/W) 1 Oct 19, 2014 04:19 AM
Found Phantom 2 Circuit board Lroc130 Aircraft - Electric - Multirotor (FS/W) 0 Oct 08, 2014 01:20 AM
For Sale Viacopter Flyduino 2 axis board Carbon fiber case for Alexmos 2 axis boards Chad2323 Aircraft - Electric - Multirotor (FS/W) 0 Oct 07, 2014 06:26 PM
Question QRX350 Power Board Schematics RickC_RCAV8R Multirotor Talk 0 Jun 26, 2014 01:57 AM
