Old Apr 19, 2014, 01:57 PM
Happy FPV flyer
Kilrah's Avatar
Switzerland
Joined Sep 2006
It's a serial port.
You can use all 16 channels (not 12) out of the box.
Kilrah is online now Find More Posts by Kilrah
Old Apr 19, 2014, 04:32 PM
Australia, NSW, Sydney
Joined Dec 2013
Originally Posted by capn View Post
Thanks, Fred!
Does anyone know what the purpose of that unused, white connector in the battery compartment is?
Also, to use the radio in 12 channel mode, will I need to do any firmware updates? Or, can the radio be used for all 12 channels as it comes when purchased?
capn
Just set it to D16 mode in radio setup and then bind with your receiver (aiming your using sbus or 2 x8r's).
skquad is online now Find More Posts by skquad
Old Apr 19, 2014, 04:40 PM
United States, CA, Camarillo
Joined Jul 2012
Thanks, Fred!
capn
I take it you're asking about the Internal RF mode setting LR12. That mode is planned for when FrSKY makes available/introduces their announced long range 12-channel receiver. Apparently intended for FPV, so it probably won't support telemetry.
Since the serial port is inside the battery compartment, it's likely for a future product like a Bluetooth wireless Trainer connectivity. No one seems to know what it's actually for.
Barry2020 is offline Find More Posts by Barry2020
Old Yesterday, 01:07 AM
Son, Norway
Joined Sep 2004
Maybe it is the connector where you would send and receive data when using the mysterious SP2UART sensor. If so, not the best location.
Fred
flarssen is online now Find More Posts by flarssen
Old Yesterday, 04:28 PM
Joined Apr 2010
DSMX/DSM2 Module Hack
Hi guys,
I'm new here. I've been flying rc for a few years now at my local field. I've recently ordered a Taranis and x8r combo from Aloft Hobbies, It should be here early this week. I've read through every page of this thread, all I can say is wow, you guys have done some really nice mods!
Anyways I'm going to do the removable antenna mod, with a RP-sma cable, UFL and 2dbi antenna.
Also I happened to acquire a dx5e which I'm going to steal the rf module from it. theres also a Spektrum integrated case on its way to me from ebay. I've read on other sites that Dx5e module requires a serial data stream to function (not PPM). From fooling around with companion9x and the Taranis simulator, I've been unable to figure out how to get this option on the TX. Is there some special patch or something that needs to flashed to the Taranis firmware to allow DSM2/DSMX serial data to be sent to the external pins?
Thanks for your help,
gun_mike is offline Find More Posts by gun_mike
Old Yesterday, 04:32 PM
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
Originally Posted by gun_mike View Post
Hi guys,
If you install the latest version (R2940) it will include DSM2 mode.
pmackenzie is offline Find More Posts by pmackenzie
Old Yesterday, 07:28 PM
Joined Apr 2010
Thanks for your reply.
Old Yesterday, 08:33 PM
Kerbob's Avatar
Knoxville, TN
Joined Apr 2008
Is there a place where you can put notes on a model or a mod that will give you a notes page? I've got too many models and it would be nice to have my notes at my fingertips on the radio. I currently use Evernote for this.
Adding voice tags to the switches is great, but it doesn't completely replace a need to have additional notes.
Kerbob is offline Find More Posts by Kerbob
Old Yesterday, 09:03 PM
Sparky "Electrics Rule"
bobf's Avatar
Mission, BC Canada
Joined Jul 2002
I believe version 2.0 has that option.
bobf is offline Find More Posts by bobf
Old Today, 12:45 AM
Joined Jul 2011
Hello everybody!I need to install booster 1w on my Taranis!But when I install it and turn the radio on it shows "antenna problem"Have anybody installed booster?Help me please!
andrew199936 is online now Find More Posts by andrew199936
Old Today, 01:34 AM
fly by night
BCSaltchucker's Avatar
Joined Sep 2011
Hey Can you Taranisites check my wiring?
I am wiring up my special AIO goggles plug. I use a special snap-on DIN to power my goggles from the 9x/9xr, and also to bring Headtracker PPM into the radio trainer port PPM - without using a messy tangle of wires. I just need to to be sure this is going to work. I did plug in a 1/8 jack and test the continuity. And I compared to how my 9x is wired up using continuity with the same 1/8 jack.
9x wiring, I have been using 1.5 years powering my goggles and running headtracking, works great:
Taranis wiring: (12V + and - tapped at the lipo plug)
I think I will do the antenna mod - put in a SMA on a coax pigtail I have. Just so I can use my patch some times.
BCSaltchucker is online now Find More Posts by BCSaltchucker
New Product FrSky Taranis - 16 Channels, Full Telemetry, RSSI Rotozuk Radios 27262 Today 03:40 AM
Question FrSky Taranis - assimilating web info mcshaz Radios 3 Jun 29, 2013 12:06 AM
Discussion is the FrSky Taranis next step after Turnigy 9X 9Ch tormodnt Radios 2 May 20, 2013 12:37 PM
Wanted FrSky Hack module, Flydream Hack or JR module Fentonflyers Aircraft - General - Radio Equipment (FS/W) 4 Dec 21, 2012 02:37 PM
