Old Jan 03, 2015, 10:38 PM
Canada, ON, Newmarket
Joined Jul 2013
The dihedral function of dihedral box in the A-Justo-Jig - which also serves to join the two 3 foot panels - is fine but you can also use a digital 'inclinemeter' which has been used by woodworkers for about a decade.
Here is a link to one I've had that time - a Beall Tilt Box -
http://www.bealltool.com/products/measuring/tiltbox.php
This one has magnets along two edges so the instrument will lock onto to the two panel pipe supports in the A-Justo-Jig. It can be zero'd to 0 degrees on any surface so the base on which the A-Justo-Jig doesn't have to be 0 degrees to the horizon.
I've seen similar digital inclinemeters pop up on popular wing/thrust/stab incidence meters, replacing the bubble level/pendulum meter.
good luck,
Michael
2michaely is offline Find More Posts by 2michaely
Old Jan 03, 2015, 11:02 PM
Joined Feb 2008
Since my bench top is flat (+/- .020") I just zero the inclinemeter to the bench and set each panel to the desired dihedral angle, cinch it down and it stays put. Works fine.
Gene
Alpha35 is offline Find More Posts by Alpha35
Old Jan 09, 2015, 08:39 PM
United States, MN, Waseca
Joined Jan 2011
Are there any new jigs available?
twalther is online now Find More Posts by twalther
Old Jan 09, 2015, 10:19 PM
United States, AZ, Surprise
Joined Jul 2002
twalther, I have a "wing" jig that I would sell. Everything is good
(no broken parts) that I'd like $80 + shp. for.
John
jcyr1 is offline Find More Posts by jcyr1
Old Feb 03, 2015, 03:51 PM
Joined Feb 2015
Rib hole Marker
I was recently given a A-Justo wing jig and want to use it to construct a plane but after doing some research on the web, I discovered that I'm missing the plastic part(s) that is used to locate the rod holes in the wood ribs. If anyone has this and would be willing to make me a copy on poster board, then I could construct one out of plastic. If you can do this, then I'll send mailing address information.
mhudson is offline Find More Posts by mhudson
Old Feb 03, 2015, 06:02 PM
Joined Feb 2008
I made a cad drawing which I can probably dig up if all else fails.
GeneH
Old Feb 04, 2015, 04:24 PM
Joined Aug 2009
I believe this is the replacement item posted earlier in this thread
Hopefully it's self-explanatory since it's not mine originally.
gumppy is offline Find More Posts by gumppy
Old Feb 04, 2015, 09:06 PM
Joined Feb 2015
This is what I was looking for. Self explanatory and great detail on the attached rib layout PDF's. Thanks to everyone who responded
Wanted A-Justo-Jig vintagesailplnr Aircraft - Sailplanes (FS/W) 5 May 23, 2010 09:40 PM
For Sale for sale The a-justo-jig wing jig slo poppy Aircraft - General - Miscellaneous (FS/W) 13 Apr 18, 2010 03:44 AM
Sold Adjusto-Jig wing assy jig LouE Aircraft - General - Miscellaneous (FS/W) 2 Apr 14, 2010 09:41 AM
Wanted A-justo jig rib locators rayjay Aircraft - General - Miscellaneous (FS/W) 1 Feb 04, 2010 07:22 PM
eBay: Complete A-Justo Jig set RickTatem Aircraft - Electric - Airplanes (FS/W) 0 Apr 09, 2002 05:59 PM
