Old Sep 17, 2014, 05:16 PM
United Kingdom, Scunthorpe
Joined Dec 2011
Hobbyking 6 channel transmitter
Hi,
I have a Hobbyking 6 channel transmitter V2 and it seems to have a pretty short range. I was flying my quadcopter today and as I flew it a little bit higher ( height of a lamp post), the signal seemed to have been lost and the whole thing starting falling down towards the ground, lucky it recognised the signal just before the ground so I could apply some throttle and reduce the impact. What has happened to my transmitter??? I opened it up and found the wire going into the antenna bit was lose so I soldered it back into place. Could that of affected it? I flying in an estate with quite a few houses around me, if that affects anything.
Aviator001
Aviator001 is online now Find More Posts by Aviator001
Old Sep 18, 2014, 08:37 AM
HobbyKingCSNYC's Avatar
United States, NY, East Farmingdale
Joined Dec 2013
Originally Posted by Aviator001 View Post
Hi,
Aviator001
That is indeed a very short range and not consistent with the TX's specs. A loose solder joint could certainly affect the range so if you've now fixed that have you flown the quad since?
Flying in an estate with quite a few houses around should (I say "should" because there are no guarantees) not have an effect on the TX or RX though I would suggest you be VERY careful around other houses/people/pets/cars... etc!
Rob
HK CS NY
HobbyKingCSNYC is offline Find More Posts by HobbyKingCSNYC
Site Sponsor
Old Today, 03:21 AM
Joined Dec 2011
Hello,
I stripped back some of the plastic on the wire when soldering and made sure there was a good joint. Still bad range though. The receiver is mounted on the bottom of my quad with the antenna left hanging to make sure there are no obstacles in the way. I flew up to the height of a lampost and was not standing that far away when it wouldn't respond to my roll inputs, the quad then responded suddenly and flipped over and crashed. Luckily its only bent landing gear but I really want more range on my transmitter because I want to start filming with it. Any help??
For Sale New Airfield 6 channel transmitter and 6 channel receiver pjpj1963 Aircraft - General - Radio Equipment (FS/W) 2 Sep 13, 2014 07:43 PM
Sold JR XP6102 6 Channel Transmitter with FrSky V8 2.4GHZ conversion + 2 receivers + extra shawn595 Aircraft - General - Radio Equipment (FS/W) 1 Oct 18, 2013 04:47 AM
Sold DX6i DSMX 6-Channel Transmitter Blackanthem Aircraft - General - Radio Equipment (FS/W) 1 Oct 08, 2013 03:06 PM
For Sale spektrum DX6i DSMX 6-Channel Transmitter Only ED3 Aircraft - General - Radio Equipment (FS/W) 6 Sep 30, 2013 08:40 PM
Alert buddy code for 6 channel 2.4 gig hobbyking transmitter/rec muckemm Hot Online Deals 0 Nov 24, 2012 12:08 AM
