Old Jul 26, 2015, 12:15 PM
chuckwww is offline
Find More Posts by chuckwww
Joined May 2015
Measuring battery strength EC3 connector (Parkzone Radian)
I'm not quite sure where to start and I have searched, but this must be a common issue: What's best practice for keeping up with how much time is left on my 1300mAh three cell? I try to keep up with how much flight time, but that's not always a good indicator if I'm mostly soaring without the throttle engaged. I do have a standard Volt/Ohm multimeter unit, for example, though not sure what measure.
Thanks for any suggestions,
Chuck
chuckwww is offline Find More Posts by chuckwww
Old Jul 26, 2015, 12:29 PM
davidmc36 is online now
Find More Posts by davidmc36
No bounce, No play.
davidmc36's Avatar
Canada, ON, Ottawa
Joined Oct 2010
Easy way:
http://www.hobbyking.com/hobbyking/s...rm_2s_4s_.html
Also easy:
http://www.hobbyking.com/hobbyking/s...15Mhz_FM_.html
Real time:
http://www.hobbyking.com/hobbyking/s..._mAh_V3_1.html
Measuring voltage between flights with you meter will give a pretty good indication of charge remaining:
http://i36.photobucket.com/albums/e1.../LIPOCHART.jpg
davidmc36 is online now Find More Posts by davidmc36
Old Jul 26, 2015, 04:20 PM
ggcrandall1 is online now
Find More Posts by ggcrandall1
ggcrandall1's Avatar
USA, GA, Marietta
Joined Aug 2005
Originally Posted by davidmc36 View Post
Easy way:
Also easy:
I have one of these and it works very well. I think this is the way to go. It's cheaper than the one below.
Real time:
Glen
ggcrandall1 is online now Find More Posts by ggcrandall1
Old Jul 26, 2015, 08:05 PM
chuckwww is offline
Joined May 2015
This is super, thanks to you both!
Sold (2)ParkZone 11.1V 1300mAh Li-Po batteries w/EC3 Connector JRjoe Aircraft - Electric - Batteries & Chargers (FS/W) 0 May 24, 2015 02:36 AM
Sold 11.1V 1300mAh LiPo Battery with EC3 Connector davidjrojas Aircraft - Electric - Batteries & Chargers (FS/W) 0 Jul 22, 2014 04:52 PM
Discussion Battery cable felt off the battery under run, ec3 connector waterprooof Racing Boats - Electric 3 Jun 19, 2014 12:08 AM
Sold 11.1V 1300mAh Li-Po Battery with EC3 Connector by ParkZone (PKZ1033) DonQ8401 Aircraft - Electric - Batteries & Chargers (FS/W) 3 Aug 13, 2013 01:19 PM
Wanted Parkzone 1300mAh Li-Po Battery with EC3 Connector (trade new E-Flite 40AMP ESC V2) CGReload Aircraft - Electric - Batteries & Chargers (FS/W) 0 Aug 15, 2009 03:11 PM
