Old Jun 21, 2016, 10:41 AM
dnbarrie11 is offline
Find More Posts by dnbarrie11
RV7guy
dnbarrie11's Avatar
Chandler, AZ
Joined May 2004
Interesting Maintenance item
I build all of my planes with maintenance in mind. I use servo frames in the wings. I'm willing to sacrifice a few grams for the ability to swap a servo in a few minutes.
I was going through all of my planes in prep for Sacramento this weekend. On my X3 my left flap was showing some slop. Actual pushrods and kwik links were solid and solid on the servo and flap horn. WT F was causing this? I could see no shift in the servo.
Turns out the screws holding the servos down in the frames were loose. This was causing the servo to lift slightly. Tightened them and all is good. I used a small amount of Goop on the screws to serve as locktite but still removable.
Went through all of my planes and repeated the process. Most of the screws were loose to some degree. Even with no actual vibration in the airframes, we have to get them to and from the field in our cars. I'm sure over time this can cause things to loosen up. Obviously in my case.
Ready to go now!!
Darwin N. Barrie
Chandler, AZ
Team Futaba
dnbarrie11 is offline Find More Posts by dnbarrie11
Old Jun 21, 2016, 11:19 AM
Dyno Don is offline
Find More Posts by Dyno Don
Dyno Don's Avatar
United States, AZ, Surprise
Joined Jun 2003
Great tip!
Dyno Don
Ready to go now!!
Darwin N. Barrie
Chandler, AZ
Team Futaba
Dyno Don is offline Find More Posts by Dyno Don
Old Jun 21, 2016, 03:53 PM
tkallev is offline
Find More Posts by tkallev
LSF303-AMA Fellow
tkallev's Avatar
USA, IL, Wheeling
Joined Jan 2003
Guess all that buzzing after a hot charge can have undesirable side effects ...
tkallev is offline Find More Posts by tkallev
Old Jun 21, 2016, 05:15 PM
RV7guy
dnbarrie11's Avatar
Chandler, AZ
Joined May 2004
You must.....
Hey TK,
You must fly JR I was going to install a micro JR servo in all my open class planes just to let me know I had the thing on
Darwin
Old Jun 21, 2016, 06:32 PM
beach1 is offline
Find More Posts by beach1
Hey hey hey....JR servos may be noisy, but there are good.
beach1 is offline Find More Posts by beach1
Old Jun 21, 2016, 07:10 PM
mlachow is offline
Find More Posts by mlachow
Joined Oct 2005
Sailplane landings would never cause things to come loose.
I'll take my 1000hz JR servo on XBus any day over those old pulse width servos.
mlachow is offline Find More Posts by mlachow
Old Jun 22, 2016, 08:23 AM
RetoF3X is offline
Find More Posts by RetoF3X
F3B and F3K
RetoF3X's Avatar
United States, TX, Dallas
Joined Mar 2009
1kHz update rate? Wow, probably needed when you fly 11s speed runs .
Back to topic, an F3J pro told me that he regularly checks all servo screws (frames and also for the servo arms). For him, wooden servo frames also wore out too quickly, i.e. the screws loosing their grip in the frame.
These controlled landing crashes in F3J seem to take their toll on the material.
Reto
RetoF3X is offline Find More Posts by RetoF3X
Old Jun 22, 2016, 09:12 AM
mlachow is offline
Joined Oct 2005
No, just a compensation for old age. Modern radios have been wonderful in reducing the time for the stick input to get to the model. Good compensation for slowing of reflexes. It's strange that radios take a digital position, convert it back to a pulse width that then has to be measured and finally used to drive the servo. The pulse width stuff is 1960's technology when everything was analog.
While most non-powered sailplanes don't have vibration, there is still wear and the landing shock abuse. I guess the E-guys will need to check even more frequently .
If you land hard enough to damage a hinge line, imagine what you do to the servo mount. The usual solution is to tie the top and bottom skins together and add outboard bearings in the wings. That takes some load off the servo mounts, spreading it out a bit more. Cross tails are a separate problem. It's easy to apply a lot of force to the pushrod with a wide rudder or stab compared to v-tails.
Big surfaces, little light weigh servos, it's your tradeoff of weight vs maintenance issues. After a few years, the metal gears still need to be replaced and the hinge lines might need some CA, etc.
I guess the question is how many crashes, er, landings between screw tighenings. Were they just frames or did the frames also have outboard bearings?
Old Jun 22, 2016, 09:59 AM
Avaldes is online now
Find More Posts by Avaldes
Avaldes's Avatar
United States, CA, San Luis Obispo
Joined Aug 2006
Sounds like a perfect application for torque stripes.
Avaldes is online now Find More Posts by Avaldes
Old Jun 22, 2016, 10:56 AM
seaspb is offline
Find More Posts by seaspb
building season is here.
seaspb's Avatar
United States, OR, Silverton
Joined Nov 2008
I use purple loctite and a small drop at that.
seaspb is offline Find More Posts by seaspb
Discussion Item withdrawn no interest dankar04 Rocketry 0 Dec 26, 2015 11:14 AM
Discussion A news item of interest... RCWorks Life, The Universe, and Politics 17 Dec 21, 2015 05:15 AM
Discussion Multirotor Maintenance Item Sundayflyer32 Multirotor Electronics 0 Feb 14, 2014 10:55 AM
Yippee! Australian Flyers/Interesting Item 100NITRO Micro Helis 4 Aug 18, 2004 03:37 AM
Yippee! Australian Flyers/Interesting Item 100NITRO Aircraft - Fuel - Airplanes (FS/W) 2 Aug 17, 2004 01:58 AM
