Old Mar 07, 2016, 01:40 PM
newnoodle is offline
Find More Posts by newnoodle
Joined Jan 2016
Mini-HowTo
Flysky/Turnigy Fs-i6 Antenna mod
The Fs-i6 has not bad range and signal strength, but I still want to do something with it because I have many antennas which I don't use right now. And in this video I'll so you how I modified the antenna.
This is the first time I have done a video, so sorry for bad quality
Turnigy/Flysky FS-i6 Antenna mod (Extend signal and range) (3 min 39 sec)
newnoodle is offline Find More Posts by newnoodle
Old May 07, 2016, 04:44 PM
robertpirao is offline
Find More Posts by robertpirao
Joined Apr 2016
Hi. Nice video! Can you post a new link to the antenna wire. The link is broken. Tanks!
robertpirao is offline Find More Posts by robertpirao
Old May 08, 2016, 04:42 AM
srnet is offline
Find More Posts by srnet
Stuart
srnet's Avatar
UK, Cardiff
Joined Dec 2008
Did you do a controlled test, say a low power ground range test, before and after the mod to check how much range improved ?
And as a general point if the 11dBi is to be believed then you now have a highly directional TX antenna, meaning you have to keep it at just the right attitude and position or the range to the RX is probably much worse than with the normal supplied antenna.
srnet is offline Find More Posts by srnet
Old May 13, 2016, 03:20 AM
nivapilot is offline
Find More Posts by nivapilot
Joined May 2015
Have you done any testing for range?
Can you recommend a GOOD hi-gain antenna?
I have done the mod to my i6, and use it mainly for boats, so a hi-gain would be beneficial to me.
nivapilot is offline Find More Posts by nivapilot
Discussion Any way to add Li-po or Li-Ion on Turnigy TGY-i6 / Flysky FS-i6 ??? Gyroguru Radios 7 Feb 25, 2016 01:44 PM
Discussion Is the Turnigy TGY-i6 the same as FlySky FS-i6 Paul80 Radios 4 Nov 20, 2015 03:00 AM
Discussion Turnigy TGY-i6/Flysky FS-i6 nothernoob Electric Plane Talk 1 Sep 21, 2015 11:47 AM
