Apr 22, 2015, 11:10 PM
bluemeane's Avatar
Flip32+ 'Deluxe' help needed
I have this FC and am trying to build a tricopter with it:
http://www.readytoflyquads.com/the-flip32-deluxe-523
I have no clue where to plug the tail servo in... Any help would much appreciated!!!!
Apr 23, 2015, 02:26 PM
Fly Hiiii
fdaremi's Avatar
Servo goes to motor 1. Then tail motor to motor 3, right front motor to motor 4 and left front motor to motor 5. Skip motor 2.
Apr 23, 2015, 04:58 PM
bluemeane's Avatar
There are only 4 server connections though. Not five. So is it just 1 to servo and then down the line for the other three pins to the three motors?
Apr 23, 2015, 05:17 PM
Fly Hiiii
fdaremi's Avatar
The picture in the top left shows 6 motor outputs. I have flip32 (non delux) and connected servo and motors like I told you.
https://www.dropbox.com/s/20hyl634j4...02_am.jpg?dl=0
Apr 23, 2015, 05:22 PM
Fly Hiiii
fdaremi's Avatar
You can try it. It doesn't burn anything. You need only one positive wire and one ground wire from one one of your ESCs ti fire up your fc. For two other escs just plug their signal wires.
May 04, 2015, 07:44 AM
bluemeane's Avatar
I am still a little confused as if you look in the pictures of the board it only has 4 signal input pins in the top left hand corner.... Almost like this board was made to only be a quad setup.
May 04, 2015, 09:25 AM
Fly Hiiii
fdaremi's Avatar
Do you have EZ connection cable for the EZ connection motor port? (Left top)
Oct 10, 2015, 12:58 PM
My esc's have no bec,so I need to run 5v from my pdb to the deluxe board. Where do I run it? Do I need to use the ez connectr labeled ch1-8gv and tap the 5v and grounds leads from it to get the power to it? It's labeled as rc-input.
