Old Jul 21, 2014, 05:15 PM
Joined Feb 2014
problems with over heating
Just finished my Dumas kit 1241, 40" Chris Craft mahogany boat.
It is powered by a Graupner 600, 7.2 volt motor and an electronic marine speed controller. The kit doesn't allow for air or water cooling in the build.
First day out, boat ran great until the motor burned out. It was very hot to touch.
My other boat is 18 years old, a Dumas Chris Craft Cobra. The old motor was a bit slow so I installed the same Graupner motor. While it did get hot, it hasn't yet burned.
Anyone have any suggestion?
Ron been is offline Find More Posts by Ron been
Old Jul 21, 2014, 08:17 PM
Resistance is futile
circuitfxr's Avatar
United States, FL, Wildwood
Joined Jul 2005
Sounds like you need to install a water cooling system. There are many different systems available. You will need a pickup tube, some silicon tubing. and a cooling coil for around the motor. A small water exhaust tube would be helpful too. these systems are not expensive, but require some work to install.
circuitfxr is offline Find More Posts by circuitfxr
Latest blog entry: Introspective on work and play
Old Jul 21, 2014, 08:19 PM
Joined Oct 2011
To much boat for a small motor?
To much prop for a big boat and small motor?
Probably all of the above.
dobydog6507 is online now Find More Posts by dobydog6507
Old Jul 21, 2014, 08:38 PM
r/c ships and workboats
bellingham, wa
Joined May 2006
also how freely dose the shaft spin. Prop size and motor size all matter.
keith S is offline Find More Posts by keith S
Old Yesterday, 05:16 AM
Boaters are nice people.
Sneek, Netherlands.
Joined May 2004
Hi Ron,
A 600 motor for a 40" hull is very optimistic, if you expect the boat to get (and stay) on the plane for a longer period of time.
I'd go with a 700 motor on 4S (provided the 700 motor turns about 1300 - 1600 rpm/Volt).
A 700 motor also should be watercooled, preferably can- and brushtab cooling, like the 700BB 9,6V Neodym in the picture:
Inlet, if possible, behind the prop.
Some picturs of your build would be nice to be able to tell what will work best.
Regards, Jan.
pompebled is offline Find More Posts by pompebled
Old Yesterday, 06:49 AM
Joined Dec 2004
There is one universal answer which applies to the problem of a motor over heating or burning up, TOO MUCH PROP!!!!
Any motor will work in any boat, providing that the load (propeller) is the right size to allow the motor to come to its normal operating RPM’s.
I can state for sure that a motor which can turn a propeller under a static load (in a test tank), will NEVER BURN UP WHEN IN OPERATION IN A BOAT, NO MATTER THE SIZE, as long as you use the same propeller that was used in the static test.
frankg is offline Find More Posts by frankg
Old Yesterday, 02:14 PM
Joined Feb 2014
The prop is the one that came with the kit, a 3 blade prop. The boat is not designed to plane. The Dumas kit doesn't talk about cooling although it makes sense. Not quite sure how to design the thru hull water pick-up but the photo of the 700 motor does let me see how to design the cooling coil.
The kit does talk about the Dumas 2025 motor. Does anyone have any experiebce with it?
Old Today, 05:31 AM
Sneek, Netherlands.
Joined May 2004
Hi Ron,
Check out the pictures in my MAS build thread to see how I go about installing in-and outlet for watercooling:
http://www.rcgroups.com/forums/showthread.php?t=1551192
Regards, Jan.
Discussion Weird motor over heating problem Frank Church Power Systems 4 Jul 12, 2014 12:52 PM
Discussion Need help with over-heating modified Stampede Augy_IA Off-road Cars 6 Mar 30, 2012 04:37 PM
Discussion Help with motor over heating? bjaffee Electric Plane Talk 8 May 29, 2009 04:10 PM
Discussion Custom CDR triple over heating, pulls to much current with suggested prop UAVPilot Power Systems 7 Jul 22, 2008 11:13 PM
Over heating with 400DH and CC25 Rudy Ackerman Mini Helis 2 Aug 27, 2004 01:13 PM
