Old Mar 25, 2014, 08:35 AM
FloridaFlyBob's Avatar
United States, FL, Fort Myers
Joined Nov 2011
Question
Antenna's for 5.8 relay
I'm almost done putting my 1.3 ground station together. I'm adding a 250mw 5.8 vtx for a relay to my goggles. I have a pare of CP antenna's, but I rather use the stock Antenna's. Is anyone using the stock antenna's for their relay? Probably will be 30-50 feet away if that much.
FloridaFlyBob is offline Find More Posts by FloridaFlyBob
Old Mar 25, 2014, 08:41 AM
xwingnut's Avatar
The Great NorthWest
Joined May 2007
I've used both and at that distance it doesn't matter. The stock antennas work well when my GS is 75' away and that's using the Immersion 10mW repeater.
xwingnut is offline Find More Posts by xwingnut
Old Mar 25, 2014, 08:46 AM
RTFM
octane81's Avatar
Antarctica
Joined Oct 2010
Stock antennas are fine , unless you fly with your head sideways
octane81 is offline Find More Posts by octane81
Old Mar 25, 2014, 08:54 AM
Joined Nov 2011
I do have a tendency to lean a lot when I'l landing with my planes. lol I think that's called body English.
Old Jul 15, 2014, 07:19 PM
Joined Aug 2013
It is better to use clovers or skews , unless you are alone .. If there are people moving around the immediate area the rubber duckies will get the odd drop out and reflection and or blocking.
I use a rubber duckie on a10mw 5.8 relay transmitter to my goggles but find I need to use a skew on the goggles end to prevent minor interruptions . the linear to circular mismatch at that range is np and the duckie on the relay is better , in the fact it does not tend to interfere with the main receiver which is a 5.8 diversity on a pole above it .
outbackkanga is offline Find More Posts by outbackkanga
Question What antennas for 5.8 Diversity Rx for penetration? CactusJackSlade FPV Equipment 7 Feb 20, 2014 09:56 PM
Discussion 5,8 helical antenna for long range nickboul FPV Equipment 3 Dec 22, 2013 07:11 AM
Discussion 1.3 to 5.8 GHz FPV Video Relay Unit for increased Video Range 488 FPV Equipment 35 Dec 06, 2013 01:00 AM
Sold ImmersionRC 600mW 5.8 GHz Transmitter V2 & 5.8 GHz SpiroNET Omni SMA Antenna Set Chad2323 FPV Equipment (FS/W) 5 Nov 12, 2013 04:03 PM
Discussion 5.8ghz relay for ground station llrc FPV Equipment 4 Oct 09, 2013 09:11 PM
