Old Jul 15, 2014, 11:12 PM
United States, FL, Port St Lucie
Joined Aug 2004
W a second pilot manning the second transmitter of course
Jacksmobile is offline Find More Posts by Jacksmobile
Old Jul 18, 2014, 06:45 AM
joshgluck's Avatar
United States, NJ, Middletown
Joined May 2012
Originally Posted by Jacksmobile View Post
Well I pulled the trigger on my 4th used Hitec eclipse 7 from the sounds of it it's gonna be a while before we get our transmitter so this gives me 7 more electric model Jets to put in the air... this is practice for my main goal of an eleven channel modellbau F86D 20 lbs turbine I have been collecting parts for the last 2 years and now have 98% of all parts needed except an 11 channel transmitter, so now what will I need to do to set up 2 Hitec eclipse 7 w/ XPS modules to operate an eleven Channel plane any suggestions???
main control surfaces on one transmitter and landing gear and brakes, air brakes and maybe the turbine kill switch on the other ....
Taranis and XPS are awesome... Here's a 13channel setup w taranis, dual Nanos and an x10+.
Description:
Description:
joshgluck is offline Find More Posts by joshgluck
Old Jul 18, 2014, 07:19 PM
Joined Sep 2011
Jim, how about a sneak peek at the 3.5" color display ?
xfedex is offline Find More Posts by xfedex
Old Jul 18, 2014, 08:33 PM
North Plains Oregon
Joined Jul 2006
Tx
You could use an aluminum box, maybe with plastic sides like earlier radios.
This way you could vary the cut out for various size components.
When the design is cast in concrete then maybe an molded case.
Darryl Usher
Darryl Usher is online now Find More Posts by Darryl Usher
Old Jul 18, 2014, 08:46 PM
PGR
Low AltiDude
PGR's Avatar
United States, CA, Costa Mesa
Joined Jun 2004
At this point I'd settle for coroplast and duct tape if it meant getting my hands on one of the new transmitters.
Pete (who's only kinda kidding)
PGR is offline Find More Posts by PGR
Old Jul 18, 2014, 09:33 PM
Xtreme Power Systems
Lake Havasu, AZ
Joined Jun 2005
Nothing too exciting, looks like the old iPhone display. I was just looking at various options because I really don't like the display that comes with these stock boxes. I don't like the display the Taranis uses either because it "bleeds" even worse than these stock display we have now.
JimDrew is offline Find More Posts by JimDrew
Old Jul 18, 2014, 10:06 PM
Joined Oct 2010
Can't argue that, but if you wait until you get to "perfect", then every day, some better component will become available (ad infinitum) and the radio will never happen.
Build and sell it with the best you've got right now and then just upgrade future models to replace the earlier ones (the way every manufacturer does it), and maybe even offer a component upgrade (a better screen for example) that can be retrofitted onto an earlier released radio.
And if it's not possible to retrofit an earlier radio, then tough, the user can just buy the newer radio if he just has to have the new one (like how the Aurora A9 was replaced by the 9X).
I happen to have an original A9, and the newer 9X holds no big upgrade that I just have to have, so I'll happily keep and use the A9 until the XPS3216 arrives.
You have the basic framework for the radio already (it's been discussed a lot in the past), so just build it, and we will buy. Then build the next "improved" one, and we'll then buy that one too if it's that much more improved over the first one.
As far as I'm concerned, all the electronics available that you offer right now works great, so if all we get is what we've already got except for the system improvements that your very own brand TX will offer, then we're all good to go. I don't care much what screen you choose to use as long as it functions for it's purpose.
Treeline is online now Find More Posts by Treeline
Old Jul 18, 2014, 11:11 PM
Lake Havasu, AZ
Joined Jun 2005
I am just looking at future options while coding is tinkered with.
Question Progress of skills, what order to learn progressively hard manuvers? learn2turn 3D Flying 20 Jul 22, 2011 11:42 PM
RBC Beaufighter (work in progress!, long progress) stuart warne Scale Kit/Scratch Built 10 Apr 13, 2003 09:33 AM
