If you want to go the mechanical rout this post should offer a “maybe” solution!
http://www.rcgroups.com/forums/showp...&postcount=148 By the way RGinCanada for me it's the wife who says " I've been thinkg" that gets me nervous! Last time we ended up with a baby! |
It's really just a software issue. A lot of ESCs have been hacked. You might want to ask around, DIY Electronics maybe, and see if your ESCs have been.
Any electrical means would need to be able to handle the power you'll feed your motor. As for the length of the leads being an issue, that's not true. The unpowered lead goes into a high-impedance input on the ESC. All the EMF effects are within the motor - the ESC is just watching the voltage on the line to detect the zero-crossing, and it has special logic to account for the pulses crossing 0 before the real zero-crossing. Andy |
![]() Duncan's work is art. I had forgotten about that gearbox. |
There it is!
RG, hereby the pics I have of my concoction, the boat as it was didn't go that far, trial on the water was one of seconds because I had a prop lock, ....don't ask I've turned much wiser
![]() At the second run the pull rope of the motor broke and I gave up doing that PT hull on IC The trick is the push and pull off the servo on the module, I've attached mine with a spring like push rod with a lever. The push rod acts as a servo saver but also lets the gears, when switching, mesh somewhat gently!I'm sure you'll come up with something if you go this way! Boo
I will be the first to admit that my biggest experience with brush-less goes back to my old life as an industrial Automatons techniction, and the Brush-less set ups I worked with where called Variable frequency drives and typically where these giant things running off of 480v
I think, if pressed, I could still program a Allan Bradley 1305 VFD.... in any case, yes, flopping the wires would "work", but at the very least, I wouldn't slam it into reverse at full throttle. |
Kamloops BC Can.
Hi RG,
I used an old mechanical speed controller in my logging barge to forward and reverse the windshield washer pump to flood and empty the ballast tank. If you have a 3 way switch on your transmitter, you can control the mechanical speed switch reversing your leads. Really simple and cheap. (speed control switch is operated by a servo) |
| Thread Tools | |
| Discussion What's the Highest Altitude You've Been? | HoosierGuy | Electric Sailplanes | 27 | May 27, 2012 09:22 PM |
| Discussion I've been thinking of buying this J3 PIPER, but I'm confused | racerzeke | Beginner Training Area (Aircraft-Electric) | 2 | Jan 15, 2007 10:13 PM |
| I've been thinking... | Doahh | Electric Power Cars | 1 | Jun 21, 2004 04:03 PM |
