Old Oct 18, 2014, 08:11 PM
Rocketman209 is offline
Find More Posts by Rocketman209
Arlington, TX
Joined Dec 2002
Scale Build Off 4 - SE-5 Peanut scale
Hey guys, this is my first build off. I am starting this thread in order to join, but I don't have much to show yet. My build is small, and I have completed the drawings, so I should have some progress soon. I enjoy small builds, as they remind me of all my rubber FF stuff I built when I was young. Sticks, tissue and dope! lets see what develops. I enjoy small builds, so I thought I would post some pics of some prior builds. The Albatross never made it to RC, But the Martinside and the Bristol did.
Rocketman209 is offline Find More Posts by Rocketman209
Old Oct 18, 2014, 09:44 PM
TPfingston is offline
Find More Posts by TPfingston
Retired and Lovin' it!
United States, KY, Sturgis
Joined Jul 2007
I'm looking forward to your build, Rocketman. I have some small gear that I'd ordered several months ago for a 'someday' build. Best wishes!
Tony
TPfingston is offline Find More Posts by TPfingston
Old Oct 19, 2014, 02:41 PM
Arlington, TX
Joined Dec 2002
I love building small. The trick is to think LIGHT. I have weighed 4 - 5 lb / cubic ft balsa, and I use thinned elmers for glue. its about 1/4 the weight of CA and it will sand nicer. Then use thinned dope, and hopefully it will turn out nice. You end up spending about 6 $ for an airframe. I should have some bones shots tomorrow.
Old Oct 19, 2014, 03:10 PM
baldguy is online now
Find More Posts by baldguy
I eat glue
Canada, NS, Yarmouth
Joined Jul 2006
My favourite rubber peanuts so far are my Voisin Hydroplane, and Dumont 14bis. The Voisin weighs 10 grams, and the 14bis is 9.5 grams.
baldguy is online now Find More Posts by baldguy
Old Oct 20, 2014, 06:34 PM
PETERRAKE is online now
Find More Posts by PETERRAKE
Norfolk, England
Joined Sep 2001
Should be nice and interesting that you chose the SE5 rather than the SE5a. Maybe I can pick up some tips about building small and light because I have a few ideas in mind.
Pete
PETERRAKE is online now Find More Posts by PETERRAKE
Old Oct 21, 2014, 12:47 AM
Arlington, TX
Joined Dec 2002
OK, I will bite. I have been unable to find the difference between the SE-5 and the SE-5a. I hope I don't have to change the name of the build...
Old Oct 21, 2014, 03:09 PM
Pat Lynch is online now
Find More Posts by Pat Lynch
a.k.a Maltone
Pat Lynch's Avatar
Australia, NSW, Goulburn
Joined Jan 2005
Mostly the shape of the fuselage under the nose. The Se5a had an added 'chin' area below the engine - I think to accommodate a different engine bottom end. The radiator may be deeper too. Check for a wedge-shaped addition in any side views.
Pat (working from a dubious memory....)
Pat Lynch is online now Find More Posts by Pat Lynch
Latest blog entry: Best Laid Plans....
Old Oct 21, 2014, 03:24 PM
I eat glue
Joined Jul 2006
Se5 didn't have a headrest.
Old Oct 21, 2014, 03:43 PM
Lnagel is offline
Find More Posts by Lnagel
Senile Member
Lnagel's Avatar
Moab, Utah, USA
Joined Apr 2003
Pat is correct in that the nose of the Se5a had a chin added to the bottom of the engine cowling. Another difference is that the Se5 had a short exhaust that was about the same size as the manifold whereas the Se5a had a long exhaust that extended to behind the cockpit. Baldguy is correct in that the early Se5 did not have a headrest. However, the later versions of the Se5 did have a headrest. The early and late versions of the Se5 also had different windscreens and different wing tip angles. The late model Se5 wing tips carried over to the Se5a.
Larry
Lnagel is offline Find More Posts by Lnagel
Old Oct 21, 2014, 09:31 PM
Arlington, TX
Joined Dec 2002
Thanks guys, It sounds like I am building a late model SE-5. I am not used to figuring this out after starting a model.
Old Oct 22, 2014, 04:02 AM
Norfolk, England
Joined Sep 2001
And, just to further complicate an already muddled situation some SE5s were upgraded to SE5a. Ignoring all the minor nose shape, exhaust and headrest details, the most obvious difference, and the important one, is wingtip shape. The Se5 had heavily raked tips(giving a quite pointed tip) whereas those on the 5a were fairly blunt. That alone is what obviously separates early SE5as from late SE5s.
The attached shows the 5a tip style.
Sorry, didn't mean to cause confusion (for a change). Which ever type it is it should fly well.
Pete
Old Oct 24, 2014, 12:33 AM
Arlington, TX
Joined Dec 2002
Maybe I will just build it, and treat it like modern art. I will let the beholder interpret SE-5, or SE-5a.
Wings and stabs off the board tomorrow. pics to follow.
Old Oct 24, 2014, 09:30 AM
T_om is offline
Find More Posts by T_om
The Junk Man
Jacksonville, Florida
Joined Jul 2006
EXACTLY how I built my FW-190 concept test model.
As long as anyone looking at it doesn't say "nice looking Spitfire" I am good to go.
Tom
T_om is offline Find More Posts by T_om
Old Oct 25, 2014, 06:05 AM
Norfolk, England
Joined Sep 2001
Never a bad thing when a 190 can't be mistaken for a Spitfire.
Old Oct 25, 2014, 01:42 PM
E-Challenged is offline
Find More Posts by E-Challenged
E-Challenged's Avatar
United States, CA, Garden Grove
Joined Oct 2000
I try to achieve "folk-art level" when detailing my scale models. If I should accidentally do better, that's white powdered-sugar frosting on a devils food cake.
E-Challenged is offline Find More Posts by E-Challenged
Build Log Scale Build-Off 4: 48 inch Stearman by Aerodrome RC SubManEric Scale Kit/Scratch Built 96 Jun 01, 2015 03:15 AM
Build Log Scale Build-off 4 - Fly2Build 1/8 Grumman Goose falconhob Scale Kit/Scratch Built 111 May 29, 2015 02:07 PM
Contest RCG Scale Build-Off 4 Steve85 Scale Kit/Scratch Built 214 May 05, 2015 08:41 AM
Build Log Scale Build-Off 4 – Scratch-Built Depron Grumman Albatross Sopwith Mike Scale Kit/Scratch Built 88 Apr 23, 2015 08:23 AM
Build Log Scale Build-Off 4 – ManzanoLaser 52" Ryan PT-22 Lnagel Scale Kit/Scratch Built 54 Jan 23, 2015 04:27 PM
