Old Jul 27, 2014, 07:51 PM
Joined Apr 2008
servo shelf life
I just opened 6 new-in-package Proline servos by AMC and found that none of them worked!
I could see one or two failing but all six? What the heck.
These are the Kraft servos that Proline used with deans connectors.
Anyone know the secret?
avinut is offline Find More Posts by avinut
Old Jul 27, 2014, 07:59 PM
St. Mary, Maryland, United States
Joined Dec 1996
Are they 4 wire? LOL
Chris True is offline Find More Posts by Chris True
Old Jul 27, 2014, 08:52 PM
Joined Apr 2008
No, just3 pin deans connectors
Old Jul 27, 2014, 10:30 PM
59 years of RC flying
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
As I recall, Proline servos were not compatible with other RC systems because they used negative input pulses. Specifically, though they used kraft mechanics, they would not work with Kraft receivers, which used positive pulses like most other radios
To test or use them you would have to build adapters.
Servos don't have any particular shelf life. I have servos from the 1970s and all I have tested still work.
Daedalus66 is online now Find More Posts by Daedalus66
Old Jul 28, 2014, 09:45 AM
Florida
Joined Aug 2004
I used those ProLine servo's for years. You have to invert the pulse from the receiver to the servos to use them with modern Tx/Rx's though. That is rather combers um to do (takes a bit of electronics) but if you have the know how and time, it works.
Rodney is offline Find More Posts by Rodney
Old Jul 28, 2014, 10:34 AM
Fly R/C writer
Redlands, Ca
Joined Dec 2004
Pulse inverters. Ace RC used to make them but they are out of business. Try EMS ELECTRONICS. Mark Schwing. He knows about them things!
Mike Lee
mlee8249 is online now Find More Posts by mlee8249
Old Aug 09, 2014, 05:22 PM
Joined Apr 2008
I was testing them with a servosizer so shift shouldn't be a factor.
Old Aug 09, 2014, 07:47 PM
S.A.D. member
ivanc's Avatar
United States, TX, Round Rock
Joined Dec 2004
What is a "servosizer"? Can it change the PWM polarity?
ivanc is offline Find More Posts by ivanc
Old Aug 09, 2014, 08:11 PM
AndyKunz's Avatar
Illinois
Joined Sep 2001
Servo exerciser. Just a servo driver that goes back and forth.
Not usually.
Andy
AndyKunz is offline Find More Posts by AndyKunz
Site Sponsor
Old Aug 11, 2014, 04:17 PM
Joined Apr 2008
Rodney---------
explain a little further please. have been using servos (including ProLine) for a long time and I have never heard of this.
What is PWM polarity Ivanc?
Old Aug 12, 2014, 09:50 AM
richard hanson's Avatar
United States, UT, Salt Lake City
Joined Oct 2007
Jim Fosgate lives down the road (actually up the mountain) from me - he added the "inverter " to mine a few years back.
he still flies a Proline (along with Spektrum)
richard hanson is offline Find More Posts by richard hanson
Old Aug 12, 2014, 10:15 AM
Florida
Joined Aug 2004
Most if not all current servos require a positive going pulse on the signal line that has a duration of 0.5 to 1.5 milliseconds every 20 milliseconds. The old Proline used a negative going pulse of the same duration and frame rate so, to use a modern input with the old Proline servo, you need to invert that signal on the signal line. By negative going, I mean that the signal line was held at the positive voltage on the servo bus and would be dropped to ground or zero volts for that 0.5 to 1.5 millisecond signal pulse.
Old Aug 12, 2014, 10:42 AM
Joined Oct 2007
yup
Discussion what is the shelf life of servos\batteries? flyonline Slope 5 Dec 26, 2006 07:32 PM
Do new Nicads have a shelf life? Sal C Power Systems 7 Oct 30, 2004 09:48 PM
Motor shelf life? Vonbaron Electric Plane Talk 5 Jan 26, 2002 11:53 AM
Shelf life of epoxy? mtayl Power Systems 0 Sep 07, 2001 10:49 AM
Shelf life of a kit? MMGM Electric Plane Talk 7 May 05, 2001 12:51 AM
