Old Jul 26, 2016, 02:25 PM
dashunde is offline
Find More Posts by dashunde
Usual suspect.
St. Louis MO
Joined Feb 2007
High quality self righting 25-30" options?
Hi all,
I'm looking for a high quality alternative to the Aquacraft Recoil 26.. a all-purpose "beater", but no abs plastic.
Must be self-righting, quality aluminum hardware, water-cooled inrunner/esc, solid construction.. not known for mounts pulling out, cracking, etc.
I have a Leopard 4074-2150 that I'd like to use (3s/4s) if the right hull/hardware is found.
ARTR/RTR is not required, but I'd rather not buy it piece-by-piece either...
Ideas?
dashunde is offline Find More Posts by dashunde
Old Jul 26, 2016, 11:37 PM
CaptCB is offline
Find More Posts by CaptCB
CaptCB's Avatar
United States, CA, Orange County
Joined Aug 2011
I do not think what you are asking for, exists.
All the "self righting" boats I have seen, are for kids to play with, and beat up, so, they are ABS, and CHEEP!
Fiberglass is way more expensive, and makes for a much heavier hull. Every fiberglass boat that I have ever seen "flipped", has been there, till it was retrieved.
CaptCB is offline Find More Posts by CaptCB
Old Jul 27, 2016, 01:47 PM
pompebled is offline
Find More Posts by pompebled
Boaters are nice people.
Sneek, Netherlands.
Joined May 2004
Hi dashunde,
I agree with CaptCB; what you're looking for is either a typical hull build up with parts purchased seperately to fit the boat, which requires some homework and/or copying succesfull builds, or you order a hull from a reputable boat manufacturer in the state you want it (drive train installed, minus the motor, floodchamber installed, hardware bolted onto the transom, etc.).
Do you have a budget limit?
To keep the shipping reasonable, I'd look 'local' first before you check out manufacturers in Europe, like MHZ, Hydro& Marine, ToysPort, just to name a few.
Not knowing what kind of boat you're after, this Aeromarine Titan 29 is a nice base to build on:
http://www.offshoreelectrics.com/pro...?prod=Aero-T29
Adding the floodchamber would be something to do yourself, I imagine.
As the Titan is rather flat, not designed with a floodchamber in mind, fitting one in may compromise the size and position of the heavy items, such as the motor end battery, so experimenting with those weights in the hull may be a good idea to establish if a floodchamber will result in a well behaving boat.
A hull with more freeboard is easier in this respect, like the Jetchopper30.
Regards, Jan.
pompebled is offline Find More Posts by pompebled
Old Jul 27, 2016, 07:59 PM
royalcasa is offline
Find More Posts by royalcasa
United States, FL, Lake Mary
Joined Sep 2014
my self righting boat, second from the bottom (Kyosho)
top to bottom
stock blackjack 49.5 mph
Mod KOS 65mps
Mod Segad 55mph
Mod Kyosho 48mph
36 CF fightercat not finished
royalcasa is offline Find More Posts by royalcasa
Old Jul 27, 2016, 08:20 PM
AirDOGGe is offline
Find More Posts by AirDOGGe
Just Plane Nutts
AirDOGGe's Avatar
United States, CA, Mountain View
Joined Dec 2011
Originally Posted by dashunde View Post
Hi all,
Ideas?
Not a lot to pick from in that catagory. The following are self-righting. Most, if not all have 4-layer fiberglass hulls (not sure of the Kyosho). A radio and ESC are required for the first one, but it already has a motor:
http://tobsd.com/ViewDetails.aspx?ProductID=912
These just needs the radio...4-layer 'glass hull for lots of strength:
http://tobsd.com/ViewDetails.aspx?ProductID=939
http://tobsd.com/ViewDetails.aspx?ProductID=938
This one most definitely should handle your motor.... 35.5" Kyosho EP Jetstream 888 VE:
http://www.rcplanet.com/kyosho-ep-je...FYqIfgodNxECSw
AirDOGGe is offline Find More Posts by AirDOGGe
Old Yesterday, 01:49 PM
Sneek, Netherlands.
Joined May 2004
Of those boats, the Asura would be my favourite:
DTRC H750 Asura 2 Mono RC Boat Self Righting (2 min 32 sec)
Regards, Jan.
Old Yesterday, 03:58 PM
dashunde is offline
Usual suspect.
St. Louis MO
Joined Feb 2007
Guys, because I'll mostly run this one on ponds, the calm-but-small area in front of our dock and out in the big waves alongside our boat/seadoo.. I think I'm switching gears a bit..
I'm now taking a hard look at the Toysport Onyx 23" with its submerged drive, tight turning ability and 45mph capability.
http://www.rcgroups.com/forums/showthread.php?t=2311484
Discussion Self righting, 30"+ JohnVH Racing Boats - Electric 9 Jul 06, 2016 08:08 AM
Discussion Lightest fpv options then Lightest quality fpv option Sunin FPV Equipment 6 Feb 25, 2016 05:05 PM
For Sale 24" self righting stepped mono hull 100.00 plus shipping f.a.r.m.e.r Boats (FS/W) 7 Sep 26, 2015 02:06 PM
Sold RTR joysway offshore warrior highly modified self righting 220.00 shipped f.a.r.m.e.r Boats (FS/W) 4 Oct 25, 2014 10:55 PM
Discussion High quality self healing cutting mat? arukum17 The Builders Workshop 2 Mar 31, 2008 09:34 AM
