Old Dec 07, 2015, 11:05 AM
mrexcel is offline
Find More Posts by mrexcel
mrexcel's Avatar
Joined Jul 2009
Conversion of 3D plane kit to F3P
Hello,
I have 2 of these kits. One is already assembled and flies great. Now I am thinking of slicing the 2nd kit to 2, and make 2 F3P planes. I know I am going to lose printing on one side. But that is fine for me.
RC-FACTORY EDGE 540
http://robotbirds.com/catalog/produc...oducts_id=8035
I have couple of options.
1. Lemmon Rx which about 1.5 grams
2. Deltang 3 CH rx which is just .28 grams
3. AR 6410 brick
4. 1.5 - 5 grams servos
5. V911 brick with brushless upgrade
6. Various motors in the range of 5 to 30 grams
7. Batteries 2-3S ranging from 180mAh to 2200mAh
8. many ESCs ranging from 3A to 60A
9. CF rods from 0.28mm to 5mm
I am sure this has been done already. Please throw your ideas and advice on how to build a slow flying F3P with this 3D plane kit.
Cheers
mrexcel is offline Find More Posts by mrexcel
Old Dec 12, 2015, 08:20 AM
pmackenzie is offline
Find More Posts by pmackenzie
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
-The micro brick servos are not good enough for a full size model. They are barely good enough for a micro
- The Lemon rcvr is quite light, get the one without any connectors. (Or remove all the connectors if you already have one)
- If you want to save a bit of weight get the DT 7 channel rcvr, it will be easier to solder all the wires to.
- For servos either Spektrum 2010, or the 2.9 gram HobbyKing ones. Both of these have a proven contest record.
-2S is all you need, capacity depends on your final weight
- 4 to 6 amp ESC is all you need. Turnigy 6A works very well. Light option is a YEP7, but you will need a BEC with it.
Motor again depends on your final weight.
pmackenzie is offline Find More Posts by pmackenzie
Old Dec 12, 2015, 08:54 PM
mrexcel is offline
mrexcel's Avatar
Joined Jul 2009
Thank you for the information!
Old Dec 16, 2015, 04:16 AM
mrexcel is offline
mrexcel's Avatar
Joined Jul 2009
I instead made a 24" model from scratch to fit my brick. I am using a HK 2 gram servo for Ailerons and 1.5 gram servos for rudder/elevator.
The air frame weight 24grams. It was 14 grams before the strengthening and landing gear. 10 grams were added in that step.
I test flew it with a 2X, 200mAh batteries from H8 mini and it flew great with the 10g motor from HK. I am going to try change the motor to 5g and check with 100mAh, 2S as well.
Question questions about first scratch built F3P plane Sierra_bravo Indoor Pattern/F3P 20 Nov 30, 2015 09:26 AM
Sold SOLD - Fancy Foam Vrolet V1 F3P 3D kit with servos - $45.00 Shipped and Insured. GTMAXX Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 3 Feb 29, 2012 09:28 AM
Cool Donuts-Models.com "ELITE PRO" F3P/3D kit for sale on rcgroups aero104 Indoor Pattern/F3P 1 Jun 07, 2009 10:50 AM
For Sale Donuts Models "FUSION" F3P/3D kit NIB aero104 Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 4 Jun 07, 2009 10:48 AM
Discussion Scratch built planes for F3P-AM or indoor 3D dkselw Indoor Pattern/F3P 2 Sep 10, 2008 07:36 PM
