Old Apr 20, 2014, 07:43 AM
Joined May 2013
1800kv or 2200kv platform?
what would be a good foam trainer scratch build plat form for use of a 1800kv or 2200kv motor with a 25amp esc and 2200mah 3cel battery..i bought these cheap on craigslist and was hoping to use them ...
hddave42 is offline Find More Posts by hddave42
Old Apr 20, 2014, 08:28 AM
Flying Foamies
speedactyl's Avatar
Philippines, NCR, Makati City
Joined Jun 2012
try a polyhedral glider type planes for starters or high wing type slow planes.
these planes are near foolproof even on 3ch , relatively stable.
speedactyl is online now Find More Posts by speedactyl
Old Apr 20, 2014, 08:42 AM
Joined May 2013
what size prop would you recommend for either the 2 motors and could you point me a set of plans that I could study as I will be building this out of dollar tree foam board..
Old Apr 20, 2014, 09:19 AM
maurice076's Avatar
United States, MI, Warren
Joined Aug 2011
Hi hddave42,do you have the weight of the motor,or the part #?It will help narrow choices down.
That's a big battery,so you may have to scale up a plan to be bigger.
maurice076 is offline Find More Posts by maurice076
Old Apr 20, 2014, 09:25 AM
slebetman's Avatar
Malaysia, Selangor, Kajang
Joined Jun 2009
KV doesn't say much about the performance of the system except how fast the prop should be spinning. Higher KV simply means that the motor prefers to spin at a faster speed which requires you to use a smaller diameter prop if you don't want to burn out the motor. A lower KV simply means that the motor prefers to spin slower allowing you to use a larger prop or even a small prop with higher voltage.
You can get high thrust with high KV. You can also get high thrust with low KV. But generally the lower the KV the higher thrust you can get (either because you can use a larger prop or you can use a higher voltage battery).
The real question is, how many watts? Alternatively, what is the weight of the motor?
There's an old rule of thumb of watts/lb to tell you what sort performance an airplane has. But I personally use a different rule. I've noticed that there is generally a 1:10 thrust to weight ratio when it comes to brushless motor. Good quality motors can do better but even the worst cheap motor has roughly 1:10 thrust to weight ratio provided you use the right prop.
So, if I'm building an aircraft that's going to be roughly 300g and want a 1:1 thrust to weight ratio I'll look for a motor that weighs roughly 30g. Then I'll size my ESC, battery and prop around that motor.
slebetman is offline Find More Posts by slebetman
Old Apr 20, 2014, 09:39 AM
Flying Foamies
speedactyl's Avatar
Joined Jun 2012
can you indicate the Brand and model of that motor? because you can have different motors rated on different amp with similar KV maybe we can compute and estimate setup.
http://www.ecalc.ch/motorcalc.php?ecalc&lang=en
Old Apr 20, 2014, 12:53 PM
Joined May 2013
one is a HB2822 Brushless Motor, 1800 Kv
Hobbywing 30A Speed Controller..the
HB2822 Specification are...Max efficiency: 90%
Shaft Dia: 3.00mm
Weight (about): 29g
Unload current: 0.8A
Max current: 10.5A
Lipo Battery: 2S-3S
Recommend Propeller: 8*6(Or 9*6)
Thrust: 330g
.........Hobbywing 30A ESC specification: are ...
Output: Continuous 30A, Burst 40A up to 10 Seconds
1.2 Input Voltage: 2-4 cells lithium battery or 5-12 cells NiCd/NIMh battery
1.3 BEC: 2A / 5V (Linear mode)
1.4 Max Speed:
210,000rpm for 2 Poles BLM, 70,000rpm for 6 poles BLM, 35,000rpm for 12 poles BLM
1.5 Size: 45mm (L) * 24mm (W) * 11mm (H)
1.6 Weight: 19g
2.1 Safety Arming Feature:
Regardless the throttle stick position, the motor will not spin after battery connected.
2.2 Throttle Calibration:
Throttle range can be configured to provide best throttle linearity,
fully compatible with all market available transmitters.
2.3 Programmable Items:
Brake Setting: brake enabled / brake disabled.
Battery Type: Li-xx(Li-ion or LiPo) / Ni-xx(NiMh or NiCd).
Low Voltage Protection Mode(Cutoff Mode):
Gradually reduce the output power / Cutoff the output power.
Low Voltage Cutoff Protection Threshold (Cutoff Threshold):
low / medium / high.
Start Mode: normal / soft / very soft.
Timing: low / medium / high.
Reset: reset all the programmable items to their default settings.
2.4 Full Protection Features:
Low voltage cutoff protection / Over-heat protection / Throttle signal lost protection
Old Apr 20, 2014, 12:59 PM
Joined May 2013
the 2200kv is a ..BL-2212/6 .. the other esc I have is a hobbyking 25-30 a ... the battery I have is a Gforce 2200mah 40c ...hope this helps....thanks for the advice...
Old Apr 20, 2014, 04:18 PM
Flying Foamies
speedactyl's Avatar
Joined Jun 2012
http://modelaero.com/product/SM2212-6G.html
http://www.hobbymaterc.com/hobbymate...del-p-151.html
hi. hddave would this be close to your specs. if so check on the recomended prop.
Old Apr 20, 2014, 06:49 PM
Joined May 2013
yes those are the exact motors that I have,,,now we know that much ,are there any scratch build trainer planes that would be good for these motors...
Old Apr 20, 2014, 07:12 PM
Flying Foamies
speedactyl's Avatar
Joined Jun 2012
for the 2200kv good for funjet or skysurfer type planes if you want something fast
wing types would be long and narrow or delta
the 1800kv would work for profile 3d planes or slow flying planes.
wing types would we wide wings. like a slowstick or nutball
check the scratchbuild section of the forum under foamies and find planes that closely match the motor setup.
Old Apr 20, 2014, 07:24 PM
Joined May 2013
i have been looking at a lot of planes... i kinda like the cub with a full airfoil wing and full body fus. ..
Old Apr 20, 2014, 08:12 PM
Flying Foamies
speedactyl's Avatar
Joined Jun 2012
seems the cub would do well on that 1800kv
Old Apr 21, 2014, 04:29 AM
Joined May 2013
yea the cub would be a nice start, now I just have to find some planes and go to work..lol...thanks guys for all your help
Discussion Bring on the Thermals Ready for Tugging Or Cradle Platform Launch gva1956 Thermal 0 Apr 10, 2014 02:08 PM
Question Angle of Incidence of sailplane using a Launch Platform or cradle. gva1956 Sailplane Talk 5 Mar 27, 2014 11:16 PM
Question Lx2e motor question 2650 or 2200kv? havoc161 Off-road Cars 2 Mar 03, 2014 11:34 AM
Found WTB FPV Platform aircraft Skywalker or similar maxumflux FPV Equipment (FS/W) 1 Feb 25, 2014 09:43 AM
Wanted Wanted wing or pusher fpv platform. I really want wing Daman691003 FPV Equipment (FS/W) 12 Dec 20, 2013 02:47 PM
