Old Sep 11, 2014, 07:55 PM
Bodywerks's Avatar
United States, AZ, Tucson
Joined May 2004
Question
Spektrum receiver for my Supra?
Guys, I need a receiver for my (new to me) Supra. I'm running a JR 12x that is still DSM2. I've run an AR7610 in an eflite mystique that I have specked out without issue, but I've also specked out DLGs with both AR610 and 6260 receivers, so I'm not sure that's a good way to judge the quality of the receiver. I like the features of the AR9310 carbon receiver but it's pricey, and might be too big?
Thoughts? Experiences?
Bodywerks is online now Find More Posts by Bodywerks
Old Sep 12, 2014, 12:42 AM
Mark Canfield's Avatar
Carlsbad, Calif
Joined Mar 2007
1st - DON'T SKIMP ON YOUR RX
2nd - See First
Mark Canfield is offline Find More Posts by Mark Canfield
Old Sep 12, 2014, 01:05 AM
Bodywerks's Avatar
Joined May 2004
That doesn't help me. I know about not skimping. I also know that sometimes more expensive doesn't necessarily mean more better. If the 9310 is expensive because it is robust and proven, great! but will it fit in these tiny-fused gliders, specifically in my Supra Pro? And maybe it's just expensive because it is a 'carbon safe' receiver.
I have read that the OG AR7000 is one of the best receivers in the Spektrum line-up for range, redundancy, and reliability. Anybody using these in f3j type gliders?
Old Sep 12, 2014, 03:46 AM
SBSS, SVSS, SCCMAS, EBRC
Don McCullough's Avatar
United States, CA, San Jose
Joined Jan 2004
The AR7000 is no longer available. A shame as it was rock solid and has preset fail safe . To me, that is a must. All of the carbon-ready receivers have preset failsafe. For 2-meter ships I use the small six-channel AR6260 carbon fuselage receiver. It has two receivers, preset failsafe, and the longer antennas are easier to arrange even in a non carbon or carbon-safe fuse. For my larger planes the AR9310 is my choice for more antenna diversity and ALES.
Easily fits in my Xplorer.
I am trying out the Orange DSM2/DSMX with good results with my JR 11X on DSMX. All summer I flew a Radian and Radian Pro with it. I just put two in my Xplorer TD and ALES fuselages using S.BUS for the wing. So far so good. I like the option of the simpler wiring as I was having problems with the old wiring harness. Considering using JR DMSS with Xbus but that is an another topic.
Don McCullough is online now Find More Posts by Don McCullough
Old Sep 12, 2014, 05:21 AM
F3B
satinet's Avatar
Warwickshire, England
Joined Sep 2006
what's a carbon safe receiver and what's "preset" failsafe?
satinet is offline Find More Posts by satinet
Old Sep 12, 2014, 05:57 AM
Joined Oct 2005
I've used 9300's and 9310's inside fuselages where there is a litte more room. The antennas wires can be routed around the fuselage to suitable locations. When space was more limited, or you don't want the longer antennas, then the 8000 or 7600 now 7610 worked fine. The 7000 is just a pain mounting in a sailplane.
Most of the spektrum RX's offer you the chance to do failsafe setting or hold when you bind them.
mlachow is offline Find More Posts by mlachow
Old Sep 12, 2014, 08:37 AM
Bodywerks's Avatar
Joined May 2004
Thanks for the info. I ordered the 9310. Sorry I missed out on your offer mlachow.
Old Sep 12, 2014, 05:31 PM
Joined Jan 2004
Carbon Fuselage receivers have long antennae suitable for mounting outside of the carbon fuselage wall, have two or more receivers, and preset failsafe. Preset failsafe is Spektrum-speak for failsafe where each channel goes to a pre-defined setting with signal loss. For example I use about half crow and some rudder offset. Can be a great indicator of loss signal and reduces the risk of a flyaway. Luckily has not happens to me but a club member had this happen. Once the plane got lower he had full control. Tuned out to be bad antennae placements.
Old Sep 14, 2014, 04:01 AM
Jets:)'s Avatar
New Zealand, Auckland
Joined Aug 2006
I have ar6255 in the nose of my supra pro 2.4friendly fuse
One antenna vertical in front of the carbon hatch
One horizontal laying across(left to right) the servo tray
Jets:) is online now Find More Posts by Jets:)
Question I was wondering how to power my receiver for my tricopter CryWolf Power Systems 1 Aug 16, 2014 01:16 AM
Found Wanted: RX for my Spektrum DX3r jtice Aircraft - General - Radio Equipment (FS/W) 3 Oct 05, 2013 10:00 PM
want to trade my genuine spektrum satellite receiver for a clone reciever f.a.r.m.e.r Non R/C Items (FS/W) 2 Feb 01, 2013 07:26 PM
Wanted Trade my jet for a Spektrum AR6200 receiver hbsurfer Aircraft - General - Radio Equipment (FS/W) 1 Mar 24, 2011 05:32 PM
Discussion Anyone Using a Spektrum 6200 6 ch Receiver in a 2.4 Friendly Supra Bruce T. Sailplane Talk 8 Jan 25, 2008 08:41 AM
