Old Nov 19, 2012, 08:17 PM
Joined Nov 2012
ducted fans
hi all,
if i use these ducted fans (link below) will a quadcopter fly? or should i build a tricopter? assuming i use proper multicontroller (kk) and provide it with proper power needs. I was thinking of cutting out a piece of foam and putting the fans in an X configuration for a quadcopter and just poping them into a hole in the foam.
Thanks!
http://www.hobbypartz.com/88e-adf64-300xl-kv5250.html
djdsails is offline Find More Posts by djdsails
Old Nov 19, 2012, 09:01 PM
Actively makin humans obsolete
Razor_Racer's Avatar
Northern Virginia
Joined Jul 2007
Quadcopters need counter-rotating props in order to control yaw. EDFs only rotate one way, so you can't make a quad.
Since tricopters rely on a pivoting motor, it would be possible with EDFs.
(EDF quads have been made but with other ways of controlling yaw)
Razor_Racer is offline Find More Posts by Razor_Racer
Old Nov 21, 2012, 06:04 PM
Joined Nov 2012
like what ways?
Old Nov 21, 2012, 06:10 PM
Staying Frosty
Hellsiege's Avatar
United States, CO, Colorado Springs
Joined Feb 2008
Did you forget about your Other thread with the same subject?
Hellsiege is offline Find More Posts by Hellsiege
Latest blog entry: Construction Projects - Updated
Sold used OS 90 ducted fan with pipe and byron fan chad cotsamire Aircraft - Fuel - Engines and Accessories (FS/W) 0 Sep 03, 2012 04:11 PM
Sold 2 Turbax Fan. 2 K&B .45 Ducted fan engines one new Green Fuel Boy Aircraft - Fuel - Jets (FS/W) 2 Jun 16, 2012 11:58 PM
For Sale Rossi .81 Ducted Fan Gas Engine W Fan & Shroud mikiebarking Aircraft - Fuel - Engines and Accessories (FS/W) 0 Jun 06, 2012 11:55 AM
For Sale 2 Turbax Fan. 2 K&B .45 Ducted fan engines one new Green Fuel Boy Aircraft - Fuel - Jets (FS/W) 0 Mar 02, 2012 06:33 PM
Sold (Ducted fan parts) New/ never used JMP pressure vent and BVM mixture valve- both $20 540RCflyer Aircraft - Fuel - Jets (FS/W) 1 Feb 25, 2012 03:43 PM
