Old Oct 11, 2010, 11:47 PM
JMP_blackfoot's Avatar
Birthplace of Aviation
Joined Jul 2003
Cheap thrills with Ramrod
Not absolutely sure this belongs here, but here goes:
I have just maidened what I call my Ramrod 100. It is a scaled down Ramrod 250, with a wingspan of 25 inches and a wing area of 100 sq.in.
I had aimed for a total weight of 2 oz. max, and the final product weighs 53 gram (1.9 oz.).
The model is built mainly from 1/32 balsa, with the exceptions of the wing spars of 1/16, and wing and tailplane trailing edges, which are cut and sanded from 3/32 sheet; the pylon is a piece of 3/32 sheet. Covering is laminating film, of the semi-matt kind.
I reduced the number of ribs of both the wing and tailplane, with a 40 mm spacing.
Power is a GWS LPS B2B 5:1 geared motor which I had laying around and a 5x4.3 GWS prop. Battery is 2xKokam 135 mAh 4 gram Lipo cells of many years' vintage. They still work OK for about 7 minutes of motor run. ESC is one of my own trusty JMP7 and the receiver is an FrSky V8R4 which weighs 2.7 gram when the wrapping is removed.
Ramrod 100 flies on rudder and throttle only. The servo is an even older Wes Technik 2.5 gram type (nowadays, I would use the $4.29 "HobbyKing Ultra Micro Servo 1.7g for 3D Flight".
I had to guess at the rudder size, the resulting control is positive, yet not unduly sensitive. This was a surprise as I remember how critical any change of the rudder tab the 1/2A power models of my youth seemed to be. Also, the 1° wing incidence relative to the tailplane, and the 85% C.o.G. position shown on the Ramrod 250 drawing came out well. A classic case of "straight from the building board". This says much about the excellence of Ron Saint Jean's design, which can be scaled up or down with always good results.
The only thing I would change is the motor gear ratio, down to 4:1, to either give a quicker climb with the same prop, or the same climb with a smaller prop. With a smaller prop, the glide will certainly improve. Not that it doesn't glide, it is in fact quite good at showing where the smallest thermal is and circling lazily with the local buzzards to take advantage of it, but the drag of a stationary prop should be minimised if possible.
So, there you have it, cheap thrills in a small package.
JMP_blackfoot is online now Find More Posts by JMP_blackfoot
Old Oct 12, 2010, 03:50 AM
Palmettoflyer's Avatar
Mount Pleasant, SC
Joined Jun 2002
Very Nice!
We don't see many R/T only designs anymore. Nice work.
Palmettoflyer is offline Find More Posts by Palmettoflyer
Old Oct 12, 2010, 04:48 AM
Joined Jul 2003
Well, frankly, an elevator would add next to nothing to the flying of this type of converted free-flight model.
I have been flying rudder-only models again recently, and really enjoying it.
Old Oct 12, 2010, 08:10 AM
Napa, CA
Joined May 2007
Refreshing view of an old classic! Beautiful workmanship; thanks for sharing!
tri-pacer is offline Find More Posts by tri-pacer
Old Oct 12, 2010, 09:14 AM
Dereudre Bernar's Avatar
Saint Denis France
Joined Apr 2002
Jean- Marie
What do you use for covering, very nice. I am loocking for something light for my next project the Lerat Bince.
If you are in the Paris region next sunday, remember, we have our 4A meeting in Persan-Beaumont @@@@
Best regards
Bernard
Dereudre Bernar is offline Find More Posts by Dereudre Bernar
Old Oct 12, 2010, 09:34 AM
Dog is my co-pilot
brokenspar's Avatar
Denver, CO
Joined Jan 2004
Nice work!
brokenspar is offline Find More Posts by brokenspar
Old Oct 12, 2010, 09:40 AM
Albdag's Avatar
Oosterhout, The Netherlands
Joined Apr 2010
Nice work!
Most of the sailplane's I build as a teenager in the mid seventies were rudder only. I used to build my own radio equipment from plans I found in an old book about radio controlled boats. No problems bringing her down? I do remember some bitter disputes when I wanted to go home but my plane didn't.
Should give it a try once more.
Albdag is offline Find More Posts by Albdag
Old Oct 12, 2010, 01:38 PM
Joined Jul 2003
It is a laminating film which was supplied by:
SORETRAC
214, ave. du Président-Wilson
93210 Saint-Denis La Plaine
01 49 17 57 00
SORETRAC - Rue René Cassin - Zac de la Villette aux Aulnes - 77290 Mitry Mory - France - Tél. : + 33 (0)1.60.21.71.00 - Fax : + 33 (0)1.60.21.71.17
Catherine VAZ
03 44 56 44 19
06 64 47 88 42
Film de pelliculage DRY Brillant 26µ (STC) : 9,20/100 m²
Film de pelliculage DRY Mat 28µ (STC) (25g/m²) : 14,50/100 m²
I use the matt kind, because I prefer the final appearance. I also use the same film on larger models, and dope Jap tissue over it. It makes for a drum-tight covering which looks quite convincingly good. The weight of my sample is actually 22g/m² (this includes the adhesive). It is quite easy to work with, much more so than the various ***kotes.
In the US, a slightly thicker equivalent is Doculam found here:
http://www.oregonlam.com/thermrf1.htm#1512500
If you are in the Paris region next Sunday, remember, we have our 4A meeting in Persan-Beaumont @@@@
Bernard,
Ce week-end, je serai en Pennsylvanie avec Bob Selman au KIEF:
http://www.pafunfly.com/
Salue les copains de ma part.
Bons vols.
Jean-Marie
Old Oct 12, 2010, 04:29 PM
Joined Jul 2003
I haven't had it in a boomer thermal yet, I mean the kind which will keep my Halftone up for twenty minutes on the glide. There is enough rudder authority to spiral the Ramrod 100 down (I hope)
A small investment in time and money you won't regret, I'm sure.
Old Oct 12, 2010, 04:46 PM
Saint Denis France
Joined Apr 2002
Jean-Marie,
Thank you very much. I live 15 minutes walking from Soretrac St Denis
Bons vols
Bernard
Old Oct 12, 2010, 04:57 PM
Joined Jul 2003
Bernard,
J'espère que l'adresse est encore valable. Celle de Mitry-Mory l'est en tous cas.
Old Oct 12, 2010, 05:39 PM
scrubs's Avatar
Rio Rancho NM
Joined Dec 2004
Very, very nice. The last year or so I've been flying various mini FF StarDusters in the 18-22" range at a little under 30 gms. Considering the RC equipment I've got gathering dust, upping the size a bit to build something similar is an interesting idea. For that matter a PZ brick would drop right into a 22" version.
bill
scrubs is offline Find More Posts by scrubs
Old Oct 12, 2010, 07:59 PM
Canada, ON, Hamilton
Joined Oct 2005
Thanks JMP. Great looking little model. That's where all the "real fun" is.
JohnAV8R is online now Find More Posts by JohnAV8R
Old Oct 12, 2010, 09:57 PM
"Butchering Balsa since 1971"
CashRC's Avatar
USA, TX, McKinney
Joined Dec 2003
I like your Ramrod, JMP..you have a real nice little ship there.
I'm with you on the inset spars, I have an Easybuilt Hornet that's been sitting in my stash of kits for 2 years because I just have a slight fear of inset spars. They are a real pain in the keister, IMHO....
CashRC is offline Find More Posts by CashRC
Old Oct 12, 2010, 11:23 PM
Joined Jul 2003
CashRC,
A good tip is to slightly round off the edges of the spar before threading the ribs onto it. Also, try each rib individually onto the end of the spar before commiting to final assembly. Not really that difficult.
Discussion Cheap thrills! Skycruiser Flying Wings 13 Aug 11, 2007 02:59 PM
Sold Cheap Thrills - Fokker Eindecker 111 - SOLD ! Wolfman Aircraft - Electric - Airplanes (FS/W) 5 Dec 21, 2006 09:09 AM
Discussion Cheap Thrills from NW Hobby Expo Rex A Lott Electric Plane Talk 0 Feb 17, 2006 01:23 AM
Cheap Pylon Thrills on $10 motor Stevens AeroModel High Performance 6 Aug 15, 2003 07:27 PM
