Old Apr 02, 2014, 10:07 PM
United States, CO, Johnstown
Joined Nov 2013
P-38 Spinners with MAS CR props
I have been reading this thread quite closely I have a V2 P-38 that I am putting together. I bought the MAS CR Props. Was wondering if you used different spinners or just filed down the stock spinners to fit the props. Thanks Larry
llwalkman is offline Find More Posts by llwalkman
Old Apr 02, 2014, 10:35 PM
Plane Fanatic
DeathWarmedUp's Avatar
Australia, QLD, Gympie
Joined Jul 2007
I used a Dremel and a fine file on mine to fit the MAS. Just go slow - test fit - grind - repeat.
DeathWarmedUp is offline Find More Posts by DeathWarmedUp
Old Apr 05, 2014, 04:22 AM
Frontenac, KS
Joined Jan 2003
I used dremel tool to sand the backplate. Then, added 5x11x4 plastic bushings behind the prop washer.
PatternFlyer is offline Find More Posts by PatternFlyer
Old Apr 07, 2014, 10:54 AM
Yes it was Abby Normal
Joined May 2012
Well my V1 sans landing gear belly lander retrofitted with B-25 motors and B-25 counter rotating props and reduced wing dihedral flies great....although flight times are now reduced to around 5 minutes.....belly landings have proven to be hard on the plane as the tail feather bottom sections have been severed off twice now.....I guess a taller grass landing zone is better fitting for belly landings....the props suffer no damages at all.
TwistedGrin
TwistedGrin is offline Find More Posts by TwistedGrin
Discussion Banana Hobby P-51 w/2.4 GHz Tx/Rx cypherpix Electric Warbirds 9 Nov 26, 2008 03:32 PM
For Sale (NEW) F-Model P-38 Cowls Orion Pax Aircraft - Electric - Airplanes (FS/W) 13 Oct 30, 2008 07:22 PM
New Product New Phase 3 P-38 = EMI P-38 repackaged? shschon Electric Warbirds 16 Nov 25, 2007 11:57 AM
Discussion New E-flite P-38 pda4you Foamies (Kits) 1 Jan 12, 2007 11:04 PM
New Product New web shop, New product *EMI P-38 Forked Tail Devil * infinityhobby Product Announcements 60 Nov 03, 2006 06:48 PM
