OK, I found this one. It looks to be the same as yours.
http://www.inzpan.com/Fw_190_Cockpit_p/600003.htm |
Found out yesterday that because of the size, my Butcher Bird will be coming via triuck to the LHS, not by UPS.
It will be delayed a few days, but saving $84 on the shipping will be worth it. The TW retract will be here today so I will probaly go over & pick it up tis evening. BTW: Anyone that has already purchased the mechanical retract that wants to upgrade it for use W/the electric mains & control board, actuator is available seperately. http://www.robart.com/products/retra...rsion-actuator All you need to do is mount it where the servo would be located & use the same pushrod set-up.. I'm going to run over later & P/U the TW retract. I'll dismantle it & take some PIX of the actuator. I'll post them later tonight. |
BTW: Here is the scheme I'm going with.
Pretty close to the TF theme. A little airbrush work ought to make for a pretty good depiction of this particular Wurger. ![]() I can get the decals here.http://www.callie-graphics.com/airplanes.php Between the TF graphics & the ones from Callie, I can make an accurate color/markings scheme.
Did they want your broken fuselage back? I'm hoping that they don't want mine back. I can repair it & use it as a spare to experiment W/paint & such.. |
Durham, NC
Joined Jul 2002
TF FW190 video and pictures
4th flight done this past weekend. Still needs more elevator throw on landing
video link
Lier, Norway
Joined Nov 2003
Any idea how long the stroke of the aircylinder is? And the partnumer on the Sierra tailwheel retract? Seems like a good solutions, but I will install electric on the mains and I would then like electric on all. A lado actuator should be good ;-) |
Then, you can use the Robart control board to sequence all 3 retracts. I got some time in the hanger room before my 4 year old granddaughter arrived. I managed to fabricate some new sidemounts that will anchor into the servo deck. These were made from .040" extrusions. That is the maximum thckness that will allow the unmodified OEM pivot bushings to be utilized. ![]() The holes for the pivot busings are located 5/8" from the bottom & are .150" diameter. I took a 5/32" drill bit (.1563") & dressed it down to .150". If you have a #25 drill bit, that should be close enough. I had to dress the burrs from the hole on the brackets W/a file. Make sure that the bushings allow the cylinder to pivot freely W/the mount screws tightened down securely. I made the brackets 1 1/2" long & located the holes .20" from the ends to allow the mount screws to engage near the center of 2" long 3/8" harwood blocks that I glued under the servo deck. ![]() I located the cylinder @ a slight angle to the servos so that it will operate in a straight line W/the TW retract pushrod. I haven't decided whether to make a bellcrank or a sliding guide to prevent torque from the rotating motor from being transmitted to the pushrod. I'm leaning towards a sliding guide. There's ample room on the deck behind the servos for a slide guide. ![]() I'm working on a simple sliding guide shoe right now & will finish it after breakfast. |
I've finished my shoe & guide for the forward located electric actuator to operate the TW retract W/O torquing the pushrod.
Since this is a 1st prototype, changes were made along the way. The 1st picture is is of the pieces I made from .040" extruded aluminum angle. .040" is about ideal. .030' would probably be OK but that would be minimum for strength & anything over .040 would be heavier than neccesary. ![]() The guide plates (upper left) had the vertical leg reduced from .415 to .315. The .810 dimention was just the original extrusion dimension & that was about right so it was not altered. The vertical leg of the shoe doubler (middle right) was reduced from .490" to .360" to allow clearance for the actuator clevis. The finished shoe hieght is the same .810" as the extrusion. The guide plate doublers (lower left) are sized so that when applied flush W/the outside edge of the guide plates, there will be clearance to allow the shoe foot ample clearance. The final lengths for the guide was 1 1/2" & the shoe ended up @ 1". Glue & clamp the shoe doubler to the shoe. ![]() Since this part will be relying on the adhesive alone, it would be best to use something like JB Weld. Make sure the base legs are flush. Glue & clamp the doublers to the guide plates. ![]() The outer edges should be flush & there should be clearance for the shoe base leg to slide. Since these parts will be secured W/screws later, 5-miute epoxy would be OK. Glue the completed guides to some .060" aluminum plate W/5-minute epoxy. ![]() Use the shoe W/doubler to assure slide clearance. Do not use ecess epoxy. You do not want epoxy to squeeze into the slot for the shoe. Just use enough to secure the assembly until screws can be applied. Leave a ledge on @ least 1 end for ease of shoe insertion on the finished product. Since this part will be worked W/power tools, (heat will be an issue) secure both sides of the guide plates W/4-40 screws. Sand the bottom of the screws flush on a disc/belt sander W/a fine grit disc/belt. Grind all edges flush except for a small ledge @ the end of the guide slot. Radius all corners. ![]() The shoe should be worked by hand tools to prevent heat from affecting the glue bond. Radius all edges of the shoe & file the base thickness (if needed) to allow the shoe to slide freely. Place the file flat on a non-slip surface & work the shoe base across the file to evenly reduce the thickness of the shoe base as needed for a free sliding fit W/O excess clearance. Drill a 5/64" hole in one end of the shoe for the clevis bolt & a 1/16" hole in the other end for a pushrod clevis. The guide plate should have 4 holes drilled for srews to anchor the plate to the servo deck. Here are the finished shoe & guide plate along W/the actuator modified as described in the previous post. ![]() Here is the entire assembly mocked up on the bench to show the straight line relationship. ![]() On my fuselage, the distance from the deck to the TW retract pushrod is approximately 5/8" & all the dimensions reflect that value. In the next post I will illustrate the installation in the fuselage. The actuator & mount weigh 1.58oz, just .02oz more than a standard 60oz in servo. The shoe & guide W/screws weigh .71oz. This complete set-up weighs only .73oz more than a standard 60oz in servo. Even if the TF Fw 190 A ARF would allow the actuator to be installed integral W/the TW retract, (it won't) the weight savings in the tail (1 6 oz) by this set-up would reduce any ballast needed in the nose substantially. The forward location is very near the CG so the nose ballat savings would be about 7oz. |
| Thread Tools | |
| Discussion Top Flite Giant Scale P40 Warhawk ARF | mick1404 | Giant Scale Airplanes | 4 | Sep 29, 2012 09:26 AM |
| Sold Top Flite F4U Giant Scale Corsair Kit NIB $250 | sagomon | Aircraft - Fuel - Airplanes (FS/W) | 4 | Jul 12, 2012 04:45 PM |
| Sold P-40 giant scale by Top Flite LPU | Karpinski4137 | Aircraft - Fuel - Airplanes (FS/W) | 2 | Jul 03, 2012 02:10 PM |
| Wanted Top Flite FW-190 canopy and cockpit kit | edbu1 | Aircraft - Fuel - Airplanes (FS/W) | 2 | Jun 10, 2012 12:28 PM |
| Sold Top Flite Giant Scale Corsair receiver ready LPU | TFOA | Aircraft - Fuel - Airplanes (FS/W) | 6 | Feb 27, 2012 04:13 PM |
