Old Feb 23, 2003, 02:05 PM
Etonic is offline
Find More Posts by Etonic
United States, VA, Chesterfield
Joined Jul 2002
LED Wiring info for DIY kit - Less than $20 and 1hr
Ok Guys,
Here's step by step instructions for installing the LED Do-it-yourself kit I am selling. I will be installing them in a GWS Beaver.
THE ENTIRE SYSTEM (Incuding wire) weighs in at 14g or 12g without slide switch!
This first picture shows what you'll get in the kit.
You'll also need:
-solder and iron
- Radio Shack Wrapping wire (30 ga in 4 colors)- $2.79
- Felt marker to mark the wire for polarity if using one color of wrapping wire.
-Clear tape
6 more pics follow!
Etonic is offline Find More Posts by Etonic
Old Feb 23, 2003, 02:08 PM
Etonic is offline
Joined Jul 2002
Strobe circuit
Here is a simple diagram for the strobe circuit.. shown 5 posts down
Old Feb 23, 2003, 02:09 PM
Etonic is offline
Joined Jul 2002
Strobe circuit
Here is the strobe circuit.. I will try to upload a circuit diagram - the current one is too large!
Old Feb 23, 2003, 02:11 PM
Etonic is offline
Joined Jul 2002
Step 3
Now attach the appropriate resistor to one side of the LED.
FOR STEADY OUTPUT
Red - 150 ohm
Green- 75
White- 75
Yellow-150
Orange-150
FOR STROBE OUTPUT(With 2 or more LED's)
Red - 75 ohm
Green- none
White- none
Yellow-75
Orange-75
FOR STROBE OUTPUT(With 1 LED)
Red - 150 ohm
Green- 75
White- 75
Yellow-150
Orange-150
-Measure the wire run from the power leads to the LED location.
- Cut 2 pieces of wire to that length.
- Twist the wire together- at least 2 twists per inch to reduce any chance if interference.
Here's the picture...
Old Feb 23, 2003, 02:17 PM
Etonic is offline
Joined Jul 2002
Step 4
- Mark the positive wire with a marker. The positive side of the LED is the side with the LONGER lead.
-Solder + and - connections for steady and/or strobe.
-I would reccomend shrinkwrapping or taping these connections AND the stobe board!
Old Feb 23, 2003, 02:19 PM
Etonic is offline
Joined Jul 2002
Step 5
Now...
- CAREFULLY hook-up the power lead to the Rx.
MAKE SURE THERE IS NO CHANCE TO SHORT A CONNECTION.
TURN ON YOUR TX before applying power.
This will allow you to determine the colors if they were not marked during construction--this step can be skipped if you marked each LED color/operation while constructing the set!
Old Feb 23, 2003, 02:22 PM
Etonic is offline
Joined Jul 2002
Step 6
- Tape the LED's to the desired locations...
- Use a wide piece to cover the exposed leads at each LED.
- When running a LED run near the Antenna....Try to keep 1-2in away...The strobing output can cause interference--A toroid has been installed and should eliminate and interference- but PLEASE do a range check!
Old Feb 23, 2003, 02:27 PM
Etonic is offline
Joined Jul 2002
Step 7
Here's a pic of the completed installation..
The picture does no justice--I left the shudder open to capture the strobe output.
The LE has steady and the TE and tail has strobe output!
Old Feb 23, 2003, 02:28 PM
senor_paco is offline
Find More Posts by senor_paco
senor_paco's Avatar
San Antonio
Joined Dec 2001
Cool!. How much with shipping, and will you do Paypal? I'm hot for it! At least 1 for my SS, and if it works ok, Another for my Zagi. May need more lights for that, but hey, screaming at about 40mph right off the street at night, that'll give the bneighborhood kids something to gawk at!
If you won't do paypal, giomme an address to send the MO
senor_paco is offline Find More Posts by senor_paco
Old Feb 23, 2003, 02:44 PM
Etonic is offline
Joined Jul 2002
KITS
Hi Everyone,
For anyone interested.
The Kit above is $17.50 shipped (6 aircraft color ULTRABRIGHT 8000MCD LED's, resitors, Strobe board, Rx conn., and micro switch)
Here's a link to the sale:
http://www.rcgroups.com/forums/showt...732#post776732
Mark
Old Feb 23, 2003, 08:22 PM
Etonic is offline
Joined Jul 2002
Strobe circuit
OK I'll try to get the strobe wiring diagram uploaded.
Its pretty straight forward....
Old Feb 24, 2003, 10:16 AM
William A is online now
Find More Posts by William A
Tacoma, WA, USA
William A's Avatar
Joined Jun 2001
Hi Mark,
Got your email, can't wait to check out your LED setup.
Drawing circuits is a pain, ain't it ?
Here's something that might help.
(Circuitmaker student version)
http://www.microcode.com/downloads/student.htm
William A is online now Find More Posts by William A
Old Feb 26, 2003, 12:15 PM
Etonic is offline
Joined Jul 2002
circuit board pic
Here's a better picture of the strobe circuit. When you get the kit with the strobe, you must make these 2 solder connections.
- I cut the Rx connector down into 2 lengths. I twisted the ends of each length together and tinned them with solder.
- You now have 2 wires joined together- one has the Rx connector the other has bare leads.(2 coiled wires in picture)
- Solder the tinned leads to board as shown - DO NOT REVERSE POLARITY- I marked the positive with a "+" as you can see. This will serve as your power into the board and for the steady LED output!
- Now solder the leads attached to the toroid (donut shaped object) to the board as shown. You may want to twist these leads after soldering to further reduce RF noise.
- The toroid equipped leads are for the stobing LED's
- All LED's are wired in PARALLEL to these 2 outputs!
- Wrap the whole board in tape or shrinkwrap!
- That's it!
Old Mar 04, 2003, 01:45 PM
hopsterguy is offline
Find More Posts by hopsterguy
hopsterguy's Avatar
Westerly, RI, USA
Joined Oct 2002
Okay, got it today. Looks good. Time to get some wire from Rat Shack! If the winds calm down tonight maybe I'll try a Slow Stick flight.
hopsterguy is offline Find More Posts by hopsterguy
Old May 02, 2003, 03:24 PM
Tram is offline
Find More Posts by Tram
Fly it like you stole it..
Tram's Avatar
Florence, Al
Joined Oct 2000
Now this is what I'm talking about.. Can more lights be added? I am going to get this from you...
Tram is offline Find More Posts by Tram
Latest blog entry: Wow.. 3 years..
Discussion GWS C3-LP Lipo chargers (less than $20 USD) Inflexo Batteries and Chargers 40 Feb 01, 2008 12:42 PM
Suggestion "Last" link for threads with less than 5 pages willhaney Site Suggestions / Complaints 4 Aug 18, 2007 08:25 PM
Sold FS: Hacker C50-15XL Grey Can Kevlar Series, Less Than 20 Flights! ($190 Shipped) freezin Eskimo Aircraft - Electric - Helis (FS/W) 3 Jun 12, 2005 06:30 PM
Sold FS: Hacker C50-15XL Grey Can Kevlar Series, Less Than 20 Flights! ($190 Shipped) freezin Eskimo Aircraft - Electric - Airplanes (FS/W) 1 Jun 10, 2005 02:36 AM
MiniBOP Parkflyer Special Ezone Price (more than $20.00 off) less than 20 kits left birdofprey Parkflyers 0 Sep 15, 2004 10:34 AM
