Go Back   RC Groups > Aircraft - Electric - Airplanes > Foamies (Kits)
Old Feb 19, 2001, 05:47 AM   #1
Bill Glover's Avatar
Twin Jet - how it flies
Thought I'd post some comments on the Twin Jet's flying performance and characteristics.
To first summarise my build and setup, I'm using 8x2400s with the stock 6v S400s. My mods. are:
1. CAM 5.5x4.3 props
2. Tape hinged elevons
3. Air inlet under front edge of canopy (like Twin Star)
4. Hollowed out rear fus. to let air flow straight through and out at the back
5. Elevons bent flat (to remove reflex) - Jurgen's idea
6. Clear tape to protect fus. underside
7. Some USAF decals etc. from scrap box
All up weight is 42.0 oz, which is 10.5 oz over the quoted weight. my 8x2400s (instead of 7x1700s) account for 2.9 oz of that, the CAM props and adapters 1.5 oz at most ... your guess is as good as mine where the other 6 oz came from!
The control throws are exactly as stated in the instructions, I needed the outermost hole on the servo arms and second innermost on the elevon horns to get this. I'm using exactly the same mixer/throw settings on the TX as for my PJ, which is handy!
OK, now the good bit. This model is very impressive, I flew it at three IC sites over the weekend and the immediate reaction from most people was "I gotta get one of those"!
With the flattened elevons I have moved the CG back slightly so it balances just behind the bumps under the wing (with fingers just touching them). In flight it needs a little down trim (the thickness of the TE, maybe 2 or 3 mm) but there is no trim change between power on and off, so the standard thrustline is fine. With this setup the model is fast, smooth, and stable. Low fast passes are a breeze ... no "zooming". This model looks and sounds superb on a fast, low pass. I use some up trim for solo launching - with this the model just pulls out of your hand and climbs out. I reset the trim to neutral on climbout.
Inverted is rock steady, needs some 'down' held in (as you would expect) but flies inverted circuits and low passes with no problem. However, it will not do an outside loop, I think when pitching to higher angles of attack inverted the airflow breaks away at the rear of the wing and the elevons lose effectiveness.
Roll rate is excellent - at speed (and the model is fast) I would estimate 2.5 rolls per second on full stick deflection. But it is not too sensitive for general flying - no exponential or dual rates are required. Pitch response is fine, but not so sharp as roll. Loops, reversals, immelmans, etc. are no problem.
Slow speed handling is superb, there is no real stall and tight turns are completely safe. I was flying circles and figure eights at low speed just above the ground ... the ability to fly well both fast and slow was one of the things that people were most impressed with. It doesn't drop the nose in slow turns like my PJ does - feels really well sorted.
I managed to get the model to spin - pull sharply nose up, then just as it runs out of speed apply full up and left (or right). Because of the mixing one elevon goes fully up (45 degrees plus) while the other is neutral. If you time it just right the sudden drag on one side causes enough yaw to pull it into a spin! Couldn't get a stall turn though.
The glide is steeper than the PJ, and more height is lost in turns. This is a good thing as you can lose a little height without picking up too much speed. Landings are not too fast, it slows up well when you flare.
At the IC sites I had the timer set to 8 mins and didn't hit BEC cutoff. The packs came out only slightly warm - exactly the same setup (motors/cells/props) in the Twin Star caused them to get pretty hot ... that model wasn't fast enough to let the props unload in flight (too much pitch).
As you would expect, the TJ handles wind and turbulence well (better than the PJ).
The standard battery retention works well and seems completely secure, though it's a little fiddly getting the rubber band around the pack (I use a length of 3/16" dowel to pick up the band once the pack is in). You also need to slide the pack in with the model inverted .. otherwise it sticks on the velcro.
In summary, this is a great model, particularly with the elevons bent flat to reduce the reflex a little. There are a few QA problems - like the supplied elevon pushrods being too short - that Multiplex need to sort out (if they haven't already), and my personal view is that the standard "foam plus tape" hinges are too stiff.
Bill Glover is offline Find More Posts by Bill Glover   Reply With Quote
Old Feb 19, 2001, 07:34 AM   #2
p471701
Guest
Posts: n/a
bill:excellent review! i think you covered everything with good detail......gregg
Old Feb 19, 2001, 09:14 AM   #3
Mark Haigh's Avatar
Bill. Good review, I agree the T-jet is a blast. I flew mine this weekend, brilliant fun.
I am running with the supplied motors and Gunther props and I am well pleased with the performance. I particularly like doing high speed passes, the props really make a cool noise.
How did you flatten the ailerons? I am experiencing zooming, even with loads of down trim (which I dont like). I tried to bend the surfaces rear edges down but felt that they may break. Would it be better to remove the surfaces and flatten them on the bench?
Mark Haigh is offline Find More Posts by Mark Haigh   Reply With Quote
Old Feb 19, 2001, 10:18 AM   #4
Mark, I just bent the elevons flat using my fingers & thumbs. I had already cut them off in order to re-hinge with tape top & bottom, but you could probably do it with them still attached. Don't just bend the extreme TE down, you need to take the whole upward curve out of the elevon. That foam is pretty tough, if you've got any offcuts lying around, try snapping or tearing them!
If you go with tape hinges, make sure you clean the foam up first. Meths is completely safe for this. I experimented with masking tape first, and couldn't get it to stick to the foam at all until I'd cleaned the surface! So far the tape hinges are staying put, I will use cyano if they do start to lift.
The Gunther and CAM props both have the same stated pitch (110 mm) and are probably similar in performance on this model. However I think the CAMs are slightly more efficient .. the blades are rigid and don't flex like the Gunther ones. They are also a little quieter as they are further from the wing and fin TEs (due to the prop adapters). The Gunthers are very light (and free!) though. The howl they make sounds great at an IC site, but not so good in a local park. The CAMs still sound pretty good, a club member came rushing up from the car park yesterday to see what was being flown!
Old Feb 19, 2001, 02:43 PM   #5
Gold Member
Jurgen Heilig's Avatar
Hi Bill,
I fully share your impressions on the TJ, however mine weighing only 964g on 8/2000 NiMH should outperform yours . By the way: The weight of the model was a first calculation by MPX - actual production models are about 100g heavier. I had no problems with the elevons - just bend them up and down a couple of times.
My motors are getting pretty hot on 8 cells. I guess in summer 8 cells would be too much. Waiting for my brushless FUN400-28. Jürgen
Jurgen Heilig is offline Find More Posts by Jurgen Heilig   Reply With Quote
Old Feb 19, 2001, 02:58 PM   #6
Danny Troy's Avatar
Bill, If no one posted this fix for the stiff elevons (foam plus tape) here's my fix.
I used thicker hinge tape since the addendum to the building instructions stated the included tape wasn't working out, and warned of using it. After applying the thicker tape
(Multiplex sells it) I simply turned the Jet over and ran sandpaper,which I folded into a "V" shape, over the hinge joint area. I did this until I went almost completely through the foam. The result was a hinge that has very free movement, looks good from above, and is perfectly positioned.
Danny Troy is offline Find More Posts by Danny Troy   Reply With Quote
Old Feb 19, 2001, 03:40 PM   #7
Neil Morse's Avatar
Thanks for the excellent flight report, Bill. Actually, I hate this kind of report because they always seem to end up costing me money!
Neil
Neil Morse is offline Find More Posts by Neil Morse   Reply With Quote
Old Feb 20, 2001, 03:57 AM   #8
Neil, did I forget to mention that the TJ only performs acceptably with 2 x brushless motors/controllers and minimum of 20 cells? Coreless digital servos are also vital, plus piezo gyros on roll & pitch. Get that platinum credit card out !!
Joking aside, I think this model is a winner and a cheap option for anyone who already has a model that uses 7 or 8-cell sub C packs (like a Twin Star, for example).
Old Feb 20, 2001, 04:11 AM   #9
Gold Member
Bill, stop it please, don`t give me any more ideas . No kidding - 20 of the new 1300SCRs would fit without problems!
Old Feb 20, 2001, 04:22 AM   #10
Hi Jurgen, your model is 8 oz (226 g) lighter than mine, is that all down to the cells ??? My 8x2400 packs weigh 480 g.
I think the motor cooling can be improved, to start with I opened up the intakes a little ... the rim around each is very thick, so I carved the foam away to streamline the airflow and let more in.
I also intend to try covering the open bottom of each motor cutout with a flat plate. This would force the cooling air to flow along /through the motor and exit at the rear. I suspect that a lot just spills out downwards at the moment. However the heat will dissipate quicker on the ground with the motor bays left open.
I spent 5 minutes flexing the foam hinges back and forward but the servos still stalled at full throw ... too stiff for me (just personal preference)!
One small thing I forgot to mention in the original post, on anything other than smooth grass the elevon horns were picking up a lot of debris .. so were obviously contacting the ground on landing. To avoid shock-loading the servos (and hinges) I trimmed the horns back to the pushrods (I wasn't using the outermost 2 holes). Of course this also reduces weight and drag and so makes the model fly faster
Old Feb 20, 2001, 02:47 PM   #11
Gold Member
Hi Bill,
My 8/2000NiMH Pack weighs 364g. The rest is exactly 600g. I am using a Standard JR C-17 receiver, 2 HiTec HS-55 and two schulze slim-15be directly soldered to the motors. I use the same props you do. I cut some holes into the fuselage insert, but that was only a 5g weight reduction. Perhaps you used (a lot?) more glue? My balsa keel beam was very light too. Jürgen
P.S.: You should use the outer holes, as per instructions! Much smoother and less slack.
Old Feb 21, 2001, 04:06 AM   #12
I actually weighed my 8x2400 packs last night (rather than quoting the 'official' weight) and they are 499 g each (with 4mm gold connectors and velcro). That accounts for quite a lot of the difference, I guess the bare airframes must vary a little depending on the moulding process. I'm also using a standard (not micro) RX and HS55 servos, my single 40/60A ESC weighs 42.5 g with all cables. With cyano there isn't a lot of scope for using excess glue!
I could not get the recommended control throws without moving in 2 holes on the elevon horns, that was using the outermost hole on the (long) servo arms. However I do always set up elevon mixing so that full elevator and full aileron together give 100% servo travel (otherwise you reach a point where nothing happens when applying roll and pitch at the same time). Personal preference again.
I think the model may be fast enough to try CAM 4.7x4.7 props ... what do you think? I'd expect acceleration and climb out to be slightly reduced, but top speed up a little.
Old Feb 21, 2001, 05:09 AM   #13
Gold Member
Hi Bill,
I use the same setup on the elevons, but with the long servo arms on the HiTec HS-55 I get about 17mm of throw. Ok, that is not quite 20mm, but more than enough. On aileron I even went down to about 12mm.
As I wrote somewhere else here: The top-speed is limited by pitch and rpm. A Graupner (or APC) 4,7x4,7" should give you a higher speed. Jürgen
Old Feb 21, 2001, 10:26 AM   #14
OK, I prefer the recommended control throws ... you have 15% less elevator and 20% less aileron! Good to know that my TJ rolls faster than yours (almost makes up for being so much heavier)
I will try the CAM 4.7x4.7s, just ordered a pair.
Do you know what static current the NiMH cells deliver with the 5.5x4.3 props and standard motors?
Old Feb 22, 2001, 12:53 AM   #15
Gold Member
I would guess about 11A static, going down to about 9A in flight, but I will measure it for you tomorrow. Jürgen
how to put landing gear on a twin jet? burro breath Pusher Prop Jet Models 2 Jun 16, 2005 10:10 PM
Twin jet and Cockpit Master... kepople Electric Plane Talk 3 Jul 25, 2001 12:28 AM
Where to buy a Multiplex Twin Jet? James Frolik Electric Plane Talk 5 Jul 13, 2001 07:47 AM
Cracked Nacells on Twin Jet--How do you fix them??? TopGun Foamies (Kits) 5 Jul 11, 2001 05:11 PM
My New Twin-Jet (R.I.P.) Steven DiStasio Electric Plane Talk 12 May 28, 2001 07:38 PM
11
