United States, IL, Chicago
Joined Dec 1996
Hi folks
Unfortunately, the guy at the camera shop either didn't get stock or doesn't work on commission, so photos are still being done my favourite way Once I get this digital camera thing, I will post some additional shots, though the whole ball of wax should end up in a QEFI review article.On the motor mount. I've gone with an AeroVee. The MaxCim 13Y fits it just fine, and I think I've figured out a way to keep the motor from twisting in the mount, with a tastefully bent piece of wire, a short 4-40 bolt and a couple of screws! So far, it would have been too much work to strip a few gm out the balsa frame, the canopy is all ply and somewhat strategic (it supports the wing!) though I have knocked the firewall down from 50gm to under 40gm. I used the kit's 1/4" ply firewall rather than make a 1/8" ply copy - it's all cut far too accurately to go using knife-cut replacements willy-nilly. The top decking from firewall to canopy will be made removeable. I figure the fuselage is stiff enough without it as permanent structure, given my vibe-free power, and it will provide usefull access to the ESC. That's sitting on the handy fuel tank plate, BTW. I am changing the fuselage servo mounting. The kit has three standards servos mounted upright in the bottom rear of the cabin. These would stretch patience getting to them and are mounted on a lot of ply. I'm probably going to mount mine inverted in the back of the cabin, accessed from underneath. There's only two fuselage servos of course - though mounting the rudder servo centrally does make it easier to hook up the closed loop rudder cables. The kit supplies all pushrod / pull/pull hardware, though I'll use kevlar thread vice the kit's wire, to allow for using a Dean's whip aerial fitted internally in the aft fuselage. Next decision! Do I use a couple of handy standard servos on rudder & ele, with Hitec 225s on the ailerons, or get brave and use 225s in the fus, with HS81MGs on the ailerons? I'm getting one of the aftermarket sprung UC assemblies for her. There's a choice of Robart's or one from a William Wallace who has advertised his wares in RCM for some years. The latter unit comes with bungee covers, Robart's doesn't. Anyone got any experiences of these sprung undercarriages ? [B] Observations so far ? [B] You'd have to look very hard to find a better quality of cutting and wood selection in a kit. The instructions are fine - as long as you read them carefully, then carefully read the step ahead, just in case, and take equal care in assembly. They are describing how to assemble a big 3-D jigsaw puzzle in the case of the fuselage and many pieces might not fit if left until later. You could build the model right out the box and it would make a fine electric scale model. It is a 1/5th scale model, not an "IMAA Legal (just)" Cub shaped high winger. The wing span is spot on for 1/5th scale and it incorporates a lot of detail touches - the skylight in the roof is incorporated, though a tad under-width, for example. "Piper's Golden Age", by Alan & Drina Abel, with Paul Matt, is invaluable reading for Cub-ites. Photos might be clearer, and colour info and more photos on the J3 shown dropping a guy off onto a truck would be invaluable (probably yellow / black). There's also a L4 with a trike gear and those who don't fancy painting a dummy engine might look at a conversion to a J-11 Cub Special (I'm tempted!). Next comes the rear decking, fuselage doublers and stringers Regards Dereck |
Joined Dec 1996
Okay, I've been slacking. Have stuck a lot of bits of wood around the fuselage, but it doesn't look much different yet.
For light relief, I "assembled" the fin and rudder. Took longer to find the pieces than glue them together, and that includes cutting some lengths of stick for the ribs. All the laser cut pieces have some form of jig cut into them, so they just lock up naturally, and the 'ribs' fit into notches (which were all the right size) cut so all the stick ends are square cuts. The tailplane is pretty much ditto of course. It's nearly un-natural building like this! I actually bought me a digicam today - an Olympus 730. Once I have figured out enough of its zillion features to reliably take a photo and get it to a directory on my computer, you might get lucky and see how this beast falls together. For anyone hoping for a conversion revelation - this one is another Sig electric model, with only the alternate glow power plant drawn on the plan. Looks like the only big changes will be the firewall, radio fit - fus and wing - and I might redo the ailerons to make myself feel better. The kit's ailerons are fine for E-power but I have to mess with something ... My wife's taking me to San Francisco Sunday, back next Wednesday. Real bummer Building will stagnate...Regards D |
Sterling, VA
Joined Jan 2002
Sig Cub
Dereck
Enjoy your trip to San Fran, hope you and Sue have a good time. Should give you enough time to fiddle with and learn how to use the Digital Camera. We expect a bunch of photos of the Cub when you get back. Really need to get started on mine!!!!! Brian Allen Veni Vedi Volavi I came I saw I flew |
Launceston Tasmania Australia
Joined Aug 2000
Dereck, good choice on the Olympus 730. I have the 700, and was sold on its 10x optical zoom, just about everything else I looked at was only 2 or 3 x optical. I had a 3 x optical, and found it just wasn't good enough for model aeroplane piccies.
Just another lot of money model aeroplanes have cost me cheers Peter from the state of Tas in the land of Oz (Ex AF40G powered J3 owner) |
Joined Dec 1996
Hi Peter
Thank you for the confidence boost on my choice! So far, I've been through one set of AA's, haven't actually taken what could be called a photograph yet and have mastered turning it on and off, I think. My Olympus OM2n was at least understandable. Do I need five fully customisable "personal picture modes" in addition to the usual array of program modes, plus the real photo modes. Did I spend all that, and it still has a real manual mode buried down there? Still, Sue's happy - we now have a digital camera ![]() Just built the top hatch on the Cub, fits inbetween the centre ribs what eventually take the wing joiner tubes. So far, about everything has fitted way above what I could dream about hand-cutting. Have ordered a Banka Photopaak of a blue fus/yellow winged "US military J3". I aren't going to get overly passionate about going "scale", but want it to look something like a "real one". It'll all be Monokote, as I figure I'll end up painting some fiddly bits, plus the cabin interior, cowl and suchlike so compatible paint will come in real handy. I think I'm going to get some waterbased clear poly varnish and seal all the woodwork to be painted, so one coat of paint should do it. Wish I'd had that thought earlier - there's a hint to anyone contemplating this sort of model. I'd liked to have done the cabin first, but am not sure where the batteries will end up. Suspect the pilot will be cut off at the pass, can't see there being room for full seats and a full length pilot over the battery somehow. Have to be strong - this model is intended to fly and be a little more stand-out than the hordes of yellow 81" Cub-ish devices, not something to attack Top Gun with. Regards Dereck |
A CG thought:
Servos aft out of cabin, at least under the seat. Also use a separate bellcrank for the pull-pull; make servo changes easier. Cells ahead of dash. What type of pack configuration do you have in mind? Here's a photo from a Kadte owner with an idea on how to get the cells further forward: |
| Thread Tools | |
| Help CG for 1/7th Sig Cub | madkiwi | Sport Planes | 0 | Feb 19, 2003 05:53 PM |
| OK now for the battery question on my Micro Cub | ecost | Parkflyers | 0 | Dec 03, 2002 09:48 PM |
| Where can I buy replacement wings for my GWS Cub? | ecost | Parkflyers | 3 | Sep 22, 2002 11:22 PM |
| Pow Pow Power Wheels Now your drivin for real! | JStory | Electric Plane Talk | 1 | Nov 01, 2001 11:18 PM |
