Old Oct 05, 2002, 01:23 PM
wilerbee is offline
Find More Posts by wilerbee
Hong Kong
Joined Jan 2002
Photo 4 shows the retracts that I use in the A-4. I can't find them anymore, shame. Oh the nose gear does not have steering, although I have already figured out how to modify them. These and other similar gears can be easily modified to make them rotate 90 degress so the wheels will lie flat inside the wing when retracted, I didn't do it here due to the weight constraints. I'll be happy to share my findings if anyone is interested.
wilerbee is offline Find More Posts by wilerbee
Old Oct 05, 2002, 02:50 PM
uncljoe is offline
Find More Posts by uncljoe
Col.Hooligan Air Force
uncljoe's Avatar
Phoenix,Arizona
Joined Jul 2001
battery source
Wilerbee
I purchased the 1700 thru DMA a Vendor here on E-Zone, The 1700's cps will result in shorter flights , But at a half a pound less will turn it into a fast plane ... Also I removed the rudder servo since I noticed no adverse yawing , Flies great at the CG & control settings suggested by Jean Paul
Enjoy the Scooter
Semper Fi
Joe
uncljoe is offline Find More Posts by uncljoe
Old Oct 05, 2002, 08:28 PM
wilerbee is offline
Hong Kong
Joined Jan 2002
Uncle Joe,
Did you use zapped cells in your Jepe ? By the way, thanks for the tip on getting my cells. Also, the c.g. measurement in the instruction, did you take the measurement at the centre of the wing or at the wing root ?
Old Oct 05, 2002, 09:47 PM
gregg f is offline
Find More Posts by gregg f
Purple power
gregg f's Avatar
shadow hills,ca
Joined Apr 2000
Originally posted by wilerbee
Uncle Joe,
their zapped, cg measured from the center..........gregg
gregg f is offline Find More Posts by gregg f
Old Oct 05, 2002, 09:51 PM
uncljoe is offline
uncljoe's Avatar
Phoenix,Arizona
Joined Jul 2001
I did order the zapped cells, had the pack 10 cells per stick x2 =20 cells big bucks but worth it cg was 165mm
Semper fi
Joe
Old Oct 06, 2002, 07:21 AM
wilerbee is offline
Hong Kong
Joined Jan 2002
Thanks uncle Joe and Gregg. You guys are ace !!
Old Oct 23, 2002, 11:59 AM
wilerbee is offline
Hong Kong
Joined Jan 2002
The final touches on my Jepe A-4. The Road runner art and the name of the pilot is from a website I found. I also ordered some Li-polymer batteries to try out. Lets you guys know how it works out.
Old Oct 23, 2002, 12:00 PM
wilerbee is offline
Hong Kong
Joined Jan 2002
photo 1
Old Oct 23, 2002, 12:01 PM
wilerbee is offline
Hong Kong
Joined Jan 2002
photo 2
Old Oct 23, 2002, 01:05 PM
Herb is online now
Find More Posts by Herb
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Wallet zapping vs LiPo suction
Very nice detailing. How did it fly with the LiPo cells, did you get as much power as with the NiCd's ? Perhaps you can post a video here of one of your flights.
"Unfortunately, the dry lithium-polymer suffers from poor conductivity. The internal resistance is too high and cannot deliver the current bursts needed for modern communication devices ...",
in "The Lithium-Polymer Battery: Substance or Hype?"
http://powerpulse.net/powerpulse/arc...a_080601a1.stm
Herb is online now Find More Posts by Herb
Old Oct 23, 2002, 01:53 PM
Plane Crazy is offline
Find More Posts by Plane Crazy
Flying Welder Pilot
Plane Crazy's Avatar
Reno, Nevada
Joined Jan 2001
Great Looking! Love the graphic details. Interested to hear your results on th LiPo's. I did not have the guts or the wallet to give them a try.
Gordon
Plane Crazy is offline Find More Posts by Plane Crazy
Old Oct 23, 2002, 04:30 PM
Robert Belluomini is online now
Find More Posts by Robert Belluomini
EDF Jet Jam 2016, June 16 -19
Robert Belluomini's Avatar
United States, KY, Crestview Hills
Joined Dec 2000
Your A4
Willerbee,
Your A4 looks phenominal!!!!!!
I can imagine the effort you put into detailing it.
I really look forward to getting mine done and flying.
Regarding batteries I am flying the sanyo 2600NiMH in my hotliner and I am very impressed. The voltage characteristics are higher than the cp2400 and the extra capacity does not hurt either.
Bob
Robert Belluomini is online now Find More Posts by Robert Belluomini
Old Oct 23, 2002, 09:19 PM
Kevin Cox is offline
Find More Posts by Kevin Cox
EDF Jet Jam 2016, June 16-19
Kevin Cox's Avatar
St. Louis Intl, Missouri, United States
Joined Jan 1997
"Wallet zapping vs LiPo suction" Hehehe, funny Herb
Looks great Willerbee.
Kevin Cox is offline Find More Posts by Kevin Cox
Old Oct 23, 2002, 11:11 PM
hoser is offline
Find More Posts by hoser
shut up & fly
hoser's Avatar
United States, FL, Miami
Joined May 2001
wilerbee...well done looks fabulous!!!
what is the thickens of the gear wire looks thin for a 5+ pound plane?
how did you do the panel lines and the small lettering ?
hoser is offline Find More Posts by hoser
Old Oct 24, 2002, 12:40 AM
wilerbee is offline
Hong Kong
Joined Jan 2002
Will commence ground testing of LiPO before committing to flight !
hoser, the struts are 1/8" thick, i did them a bit longer so it appears skinny, should hold o.k. but landings atill have to be close to perfect !! The panel lines are done with a Sharpie on the molded panel lines, the letterings are sprayed on.Would liked to have the wet transfer decals used by the RC jet set but too long of a wait. The decals are very scale.
Completed my 3.4 oz Tiny Danny Troy Scratchbuilt Indoor and Micro Models 28 Sep 26, 2002 05:51 PM
My first 4 channel? scream-n-leap Parkflyers 2 Aug 22, 2002 01:42 AM
Looking for Color Schemes for my Jepe F16 Joe Elston Electric Ducted Fan Jet Talk 7 Jun 28, 2002 06:39 AM
JePe A-4 Skyhawk Sture Smidt Electric Ducted Fan Jet Talk 51 May 28, 2002 03:04 PM
Jepe A-4 - retracts? ROG? randallp Electric Ducted Fan Jet Talk 17 May 01, 2002 06:19 PM
